Clutch pedal
Old Jan 23, 2021 | 06:36 AM
JUSTINC2001's Avatar
JUSTINC2001
Default Clutch pedal
So I found out there was a leak in my slave cylinder so I changed it and bled it as much as I could by myself well it stayed 1” off the floorboard for the engagement but I was able to drive it so I was fine with it. But I got my car this morning and there was like A little pedal pressure and I to pump it up and I pumped up while car was on and then finally a built up enough pressure into it where I was able to drive it to work and I kept pressure the whole way to work
but when I get home I’m going get under the car and make sure everything is right and I’m going to get my friend to help me bleed it the rest of the way but what do y’all think about this
Old Jan 23, 2021 | 06:37 AM
JUSTINC2001
And also I did check the fluid before and after driving it to work and it stayed the same it is at max
Old Jan 23, 2021 | 08:55 AM
travlee's Avatar
travlee
Master
Sounds like you stil have air, are you bleeding by yourself? If so bribe a buddy to come help
Old Jan 23, 2021 | 11:32 AM
JUSTINC2001
I am going to do that today but my question is whenever I was bleeding all I seen was brown liquid pouring out like water I wasn’t really seeing Air is it easy to see or do I have to pay attention if I am doing it without a clear tube as I do not have one and cannot leave right now to go get one
Old Jan 23, 2021 | 12:13 PM
travlee's Avatar
travlee
Master
Here is how I always did it, clear tube always used.
One person pumps about 15-20 times holding pedal down on last pump, person on the ground cracks and bleeds.....repeat until you have pressure
Mullen
Jul 2, 2017 08:10 PM
Hidestar6
Nov 22, 2016 10:04 AM
Caseythefalcon
Jul 20, 2015 06:10 PM
TheWoods
Oct 15, 2012 10:55 AM
Deedilus
Jun 8, 2011 06:16 AM
