2004 350Z-370Z Touring Coupe GenoGunn
Old Mar 1, 2021 | 07:02 PM
genogunn's Avatar
genogunn
Default 2004 350Z-370Z Touring Coupe GenoGunn
Went to replace spark plugs and found oil in number 4 plug well .So usually it’s the valve cover leaking. I bought new covers and gaskets, my left side was way bad , the seal was cracked and exposed to the inside metal.On that side no oil leaked. Right side (passenger) was brand new. But whoever did it , used to much gasket maker and it caused my valve cover to warp and therefore leak. My intake manifold was filthy, upper and lower plenum needed cleaned as well. All my breather hoses were rock hard , like glass, so I replaced three of them from Z1, silicone. My fuel pressure damper was badly damaged too. So new one there. I went to start her and she sounded like she wasn’t getting enough oxygen. Are the PCV valve on the new valve cover working valve? Or just to plug the hole? I changed it and she sounds good again.
I’m a DIY not a professional, do I need advice on this. I’m good mechanically, do bare with me.
Top end 2004 350 Z
My engine bay
Finished
Complete and detailed
Ready for work
Side shot of engine bay
Another view
Tear down
Valve cover and IVT solenoid
Intake
Tear down
Front shot
Dirty plenum
Filthy
Fuel pressure damper and evaporated canister
Intake manifold and fuel rails
A double
The engine bay
Wire harness
Double again
ecop_z33
May 30, 2020 01:18 PM
savedbygrace
Jan 23, 2018 08:26 AM
chrism67177
Sep 2, 2012 07:03 AM
skn5002
Feb 11, 2012 05:29 PM
SuperBlack350z
Feb 28, 2008 01:14 PM
