P0305 - Change Valve Cover Assembly or just Gasket?
Old Oct 4, 2021 | 01:21 PM
waiseelay's Avatar
waiseelay
Default P0305 - Change Valve Cover Assembly or just Gasket?
Hi All,
Car threw me a P0305 code. Took the coil pack out and it was covered in oil. I'm going to order a new set of spark plugs and coil packs and just replace them all since I'm still running the OEM ones.
My question here is, do I need to change the entire valve cover assembly, or will just the valve cover gaskets be enough to stop the oil from leaking?
Gaskets:
13270-8J102 (https://www.nissanpartsdeal.com/)
13270-8J112 (https://www.nissanpartsdeal.com/)
Assembly:
13264-AM600 (https://www.nissanpartsdeal.com/)
13264-AM610 (https://www.nissanpartsdeal.com/)
Spark Plugs:
PLFR5A-11 (https://www.nissanpartsdeal.com/)
Coil Packs:
Hitachi IGC0007 Ignition Coil (Amazon)
Old Oct 5, 2021 | 10:47 PM
g3rard's Avatar
g3rard
Had the same issue and I only replaced the gasket.
Old Oct 6, 2021 | 06:30 AM
i8acobra's Avatar
i8acobra
You need the assembly. The gaskets are only perimeter gaskets, they don't come with spark plug seals. This is a VERY common failure an the VQ35 engine.
Old Nov 24, 2021 | 06:03 AM
KaizerWilhelm's Avatar
KaizerWilhelm
I'm doing this no as I type this. No sense in not doing the entire assembly. You can get the valve covers and all related gaskets from Z1 for around $450 shipped. Just do it all and call it good.
NOLAGG
Nov 6, 2013 09:45 PM
JaimeNismo
Jul 25, 2013 07:42 PM
matronix07
Nov 2, 2011 08:22 AM
redlinedifterzx
Nov 21, 2009 04:51 PM
Z_HighSpeed
Jul 19, 2009 03:52 PM
