I need help - My Convertible Top Won't Latch
Old May 12, 2025 | 04:00 PM
li25's Avatar
li25
Default I need help - My Convertible Top Won't Latch
Hi, I'm new here.
I bought a 06 roadster couple of months ago and I have a problem closing the convertible top. The motors worked perfectly but at the end of the sequence, the latch had an inch gap to the windshield. I have to pull down the hardest I can to lock the top. I tried replacing the top(not the frame) but it didn't work. I suspect it was the alignment of the frame, but does anyone have an idea?
Old May 12, 2025 | 04:48 PM
travlee's Avatar
travlee
Master
If its a new top, it needs to stretch
Old May 12, 2025 | 05:24 PM
li25's Avatar
li25
I've been letting it stay shut since April 22, and today is the first time I've taken it off after the new top. I guess I need to wait longer?
Old May 12, 2025 | 05:44 PM
travlee's Avatar
travlee
Master
In the sun will help
Old May 17, 2025 | 11:21 AM
MoneyPitZ's Avatar
MoneyPitZ
As travlee said, you do want to leave the new top to sit out in the sun for a while. It sounds like the latch issue was prevalent before you put a new top on though, so hmm.
I have heard (and have been dealing with for almost two years) issues with the rear latch so this is interesting to see. When you pull the latch all the way down and get the top to fully lock, does it seal correctly? (As in, does it mount flush with the windshield?)
Also, be careful with forcing it down. ZR tops, as I have learned, have many fragile mechanisms and such that may break if you try and forcibly make it latch. You run the risk of breaking something else.
MoneyPitZ
Oct 19, 2025 07:46 AM
bmurphy
350Z Roadster
May 31, 2024 06:14 AM
Legacyali
Mar 12, 2023 04:39 AM
Smity350
Nov 8, 2022 06:17 AM
Will Sanchez
350Z Roadster
Apr 14, 2016 10:49 AM
