Driving me crazy... help needed!
I have a 03 touring with about 7800 miles on it. For the past month it is emitting an unusal rattle from the dash area. It only happens between 4K & 5k RPM and is most pronounced in third gear. This leads me to belive that it is an engine speed cause not vehicle speed.The noise is hard for me to duplicate but does increase and decrease with engine speed. It is really starting to **** me off and I was wondering if anyone else has had a similar noise/rattle.
I'm mad too. It's not so much the dash in the beginning, but it seems like it's coming from the front wheels. It sounds almost like....hard to duplicate, like you said. Kind of like maybe the wheel is warped, so the faster it goes around, the more vibrating. But they are not warped. I've had my rotors checked out, but they were fine. No one else seems to hear/feel the noise except my boyfriend, who also drives it regularly. The problem didn't start until about 8K miles. Once when I had it checked out, they said that the bolt was loose and they tightened it, but it didn't really help. Then my dad looked at it and noticed that all the tires had different pressures. Making them equal helped get rid of some of the rattle, but not completely.
Where are you taking yoru Z for service?
Originally posted by doc3763
You are the proud owner of feathered tires. Read all the info on here about tire feathering. They are probably playing stupid b/c they don't want to fix it. IT is a big mess!
My 3 pod gauge area has started to rattle lately. I'm trying to decide if it is worth a trip to the dealer, or if I should just pull it apart myself and see what is up. I'm leaning toward the later.
Originally posted by Benzo
It is funny you say that because it sounds like the sound it coming from that area, but when I press on it the noise does not subside. Does it happen at higher RPMs or all the time?
Just to give you a laugh, the dealer told me this was a sports car with hard suspension and rattles were normal :-(
-check the tape deck
( i know who uses the tape deck nowadays...someone else put a tape in the deck!)-solved one problem.
-check the sunglass holder...yesterday something started rattling...and it was the sunglasses inside the holder(on top)
-then any kind of change...fallen through your pockets inbetween the chairs...etc.
basically...eliminate everything you could think of because the suspension is "bouncy" anything is bound to rattle from whatever we put in the car.
look at my siG...no rattles!~
and i'm in the chicago area where the roads SUCK!
( i know who uses the tape deck nowadays...someone else put a tape in the deck!)-solved one problem.-check the sunglass holder...yesterday something started rattling...and it was the sunglasses inside the holder(on top)
I bought a new car to get rid of the damn rattles in my maxima. This car rattles JUST AS MUCH.. and I had a 2" drop w/ kyb AGX's.. Nissan cannot get their cars right.
My security light rattles, there is a creak coming from the rear on slow sharp turns, my seat creaks when you put pressure on the front right of it, and most annoying, their seam to be a rattle behind the navigation unit.
This sucks... I am embarressed to drive people around in my "new car"
Bankston Nissan on Preston Rd.
If you ever take your car to get serviced at Bankston Lewisville ask for Joe Lott.
Try checking your steering column lever? Make sure it is up and tight. Sometimes if it is not all the way up there is a rattle sound by the gauges. My guages rattle sometimes, but not all the time.
Thanks for all of your replys. I had the car in the dealer yesterday and they adjusted the some pieces on the A pillar. This seemed to work but the dreaded noise it returned this morning. It seems to be more sensitive to temperature. When it is warm outside the rattle is not as pronounced. It seems to be coming from the center of the dash by the windshield, but when I press on certian areas there is no reprieve. I am going to look at it more closely this weekend.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
