View Poll Results: How badly does your shifter rattle under normal to high-load operation?
As expected, as per many, many reviews prior to release.
81
63.78%
It's rattling quite a bit, but I'm not worried.
22
17.32%
PLEASE! Make it stop! This is embarrassing!
24
18.90%
Voters: 127. You may not vote on this poll
Shifter Rattle - YOU rate it.
Old Oct 2, 2002 | 11:37 AM
HouZton's Avatar
HouZton
I replied to your post as expected, which is no rattle.
The stick vibrates, but with a tight precise gear box, I think the vibration is normal.
Old Oct 2, 2002 | 12:09 PM
LowFuel's Avatar
LowFuel
Not enough options on your poll here. Mine's not rattling at all to speak of, after 3400 miles.
Old Oct 2, 2002 | 12:51 PM
NissaNZ's Avatar
NissaNZ
Can you actually see it rattling side-to-side or is it just slight vibration when you have your hand on it?
Old Oct 2, 2002 | 12:56 PM
InternetABYSS's Avatar
InternetABYSS
Default GIZMO please get out of my car.
MY car is tripping me out....drive by wire defect, grindy gears, squeaky brakes.....Weird thing is....been driving since I picked up from the dealer friday...second gear no longer grinds..but now 3rd does...very weird. Brakes stoped squeaking too.
I think my car has gremlins in it. LOL ...geez.
Old Oct 2, 2002 | 01:00 PM
droideka's Avatar
droideka
It's like a JACKHAMMER! See it and hear it. My wife said, "Oh My!"
Old Oct 2, 2002 | 01:03 PM
infinite z's Avatar
infinite z
Jason what the hell is going on with your Z man? Has anyone else had the same problems? Droidekaus, I've got 2300 miles and no shifter rattle either. I do have a small vibration in like 3rd gear sometimes, but nothing severe. I'd get that checked out.
Old Oct 2, 2002 | 04:05 PM
2003z's Avatar
2003z
Default Vibration, by design
From SportZ, Fall 2002
"The engine is mated to a close ration 6-speed gearbox or a 5-speed automatic. While the shift **** on the former is very nicely done - leather wrapped, delivering quick and downright fun shifts with a throw of force similar to the Z32 - it's somewhat wobbly side to side when in gear and transmits a good deal of vibration from the drive train when the RPMs are pushed into the upper range. This vibration was enough to even get the shifter **** rattling around at the torque peak at 4800 rpm. When quizzed about the vibration, Nissan said that they looked at fixing it, but adding rubber isolators to clean up the vibration would have killed the precise gates and shift feel, so they consciously decided to leave it the way it is."
Performance over smoothness. I'll take that any day!
Old Oct 2, 2002 | 06:26 PM
droideka's Avatar
droideka
Default Re: Vibration, by design
Dude, you totally rock. I've always known about the vibration issue, but to see in *print*, "This vibration was enough to even get the shifter **** rattling around at the torque peak at 4800 rpm. " makes me feel a whole helluva lot better. That's EXACTLY what mine does and it's quite loud. The way this thread was going with no one else confirming a hellacious rattling via an actual post (survey notwithstanding), I was starting to feel all alone out here.
Case closed. If it breaks, I've always got my warranty.
Thanks,
Brad
Old Oct 2, 2002 | 06:35 PM
rouxeny's Avatar
rouxeny
Hmm, my shifter has a lot of vibration, but no actual audible rattle. At low speeds, the vibration isn't that bad, but when I wind it up, it really shakes a lot. Way more than my Accord, which doesn't shake at all. Not that that's any better...
Makes it hard to drive with your hand on the stick. I know you're not supposed to, but I'm kind of used to doing it. The vibration makes my hand go numb and then it's hard to do my job.
Old Oct 2, 2002 | 07:15 PM
relldog's Avatar
relldog
I've got 1500+ miles and no shifter rattle what so ever. Small vibration, but I've never driven a manual without a little vibration. It's normal.
relldog
Old Oct 2, 2002 | 08:52 PM
brackethead's Avatar
brackethead
3600 miles. Put me down for 4) no rattle. Have been to 6K+ rpm's several times.
Old Oct 3, 2002 | 06:20 PM
kj301's Avatar
kj301
Default Shifter
I have almost 800 miles on my Z and i think the rattle has gotten better.
KJ
Old Oct 3, 2002 | 06:45 PM
nizl's Avatar
nizl
Default Re: Re: Vibration, by design
Originally posted by droidekaus
Thanks,
Brad
droidekaus's real name is "Brad"?!?!?!
This changes EVERYTHING!!!
Old Nov 7, 2002 | 08:38 AM
droideka's Avatar
droideka
Default Re: Re: Re: Vibration, by design
Whatever, Mr. Walker!
Old Nov 7, 2002 | 08:40 AM
ares's Avatar
ares
Veteran
haha, mine doesnt rattle, but if I have my hand on the shifter, I can feel it vibrating, and the watch on my wrist will hang down and rattle against the console. my parents were wondering what the noise was.
should I look into this as a warrentied defect?
oh and whats up with people calling posts "attempts for points" if no ones caught on yet, the points are reletivily useless. about the biggest thing you can do is have your name highlighted in a color, or get rid of a warning.
Old Nov 7, 2002 | 08:50 AM
jmark's Avatar
jmark
No rattle, great shifter! Slight vibration. No worse than the S2000.
Old Jan 4, 2003 | 10:36 AM
ZZtopp's Avatar
ZZtopp
2000 miles, no rattles. The only noticeable vibration occurs above 4000 RPM, and it is less than my old Z32 or Z06. No problems here.
Old Jan 4, 2003 | 11:03 AM
  #38
kgb's Avatar
kgb
Default No rattle at 500 miles
My shifter vibrates less than I thought it would based on comments I've read on this board and the magazines. There's a "normal" amount of vibration to me across the rev band.
Old Jan 4, 2003 | 05:50 PM
  #39
6kLaunch's Avatar
6kLaunch
I have experienced NO rattle at any RPM>.
Old Jan 4, 2003 | 06:25 PM
  #40
bhobson333's Avatar
bhobson333
I haven't heard any rattle at all from my shifter at 1400 miles. I think I have detected a pattern in the posts here, though. Those that are driving the Z the way it's SUPPOSED to be driven (F*ck the bogus breakin recommendation in the owner's manual ) aren't getting any rattle. Those that are keeping it below 4000 RPM are getting rattle. Maybe the rattle is only evident at a certain RPM and we are passing through that RPM so fast it never gets a chance to rattle!
