5000 miles between Mobil 1 oil changes ok??
Old Aug 2, 2004 | 11:09 AM
halflife78's Avatar
halflife78
Default 5000 miles between Mobil 1 oil changes ok??
I will be switching over to Mobil 1 10w30 and the Mobil 1 M1-110 filter shortly when I go in for my first oil change. My question was is 5000 miles ok between changes of the oil? The car is used for driving back and forth to work and in town. I don't race and I have never been over 80 in the car and probably won't get over 80 for awhile.
I'm not sure what the recommended change intervals are on synthetic oil so I figured it can't hurt to ask.
Old Aug 2, 2004 | 11:21 AM
MonkeyBoy's Avatar
MonkeyBoy
Some synthetics can last a very long time, Mobil 1 included. 5000 miles is a good oil change interval when using Mobil 1, so you should be fine. If you like check this out for more info on an independent test.
neptune.spacebears.com/cars/stories/mobil1.html
Old Aug 2, 2004 | 09:32 PM
johnsZ's Avatar
johnsZ
I am on synthetic, and figure 6000, but I watch the color.
so far, 16K, there is very little discoloration after 3000 since the last change.
this also indicates that very little of the bearings are wearing, and not much blowby. pretty happy so far.
Old Aug 3, 2004 | 05:22 AM
PoWeRtRiP's Avatar
PoWeRtRiP
make sure you use a quality oil filter, some of the cheap ones only last 3k
Old Aug 3, 2004 | 07:00 AM
halflife78's Avatar
halflife78
I plan on using the Mobil 1 M1-110 filter with the oil.
Old Aug 13, 2004 | 04:17 PM
n8vz's Avatar
n8vz
as long as you check oil level periodically, it should be fine.
Old Aug 19, 2004 | 12:32 PM
dr_gallup's Avatar
dr_gallup
Nissans "Schedule 2" maintenance only calls for oil & filter changes every 7,500 miles or 6 months using dino oil. That is all that should be required to keep your warrenty. I do 6 months or 6000 miles with Amsoil ASL 5W-30.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
