Will 275/40/18 rub with 1.2" drop ?
Old May 7, 2006 | 04:41 PM
deadcop's Avatar
deadcop
Default Will 275/40/18 rub with 1.2" drop ?
Hey guys,
Question about tire rub. My rear wheel size is 9,5 with +20 offset .The tire is BFG KDW (1st generation) 275/40/18 . The car is lowered using Eibach springs with 1,2 inch drop in the rear. Will this rub? I heard that KDW’s are wider then any other tires of the same size.
Should I have a fenders rolled or just get SPC kit and run more negative camber? I would rather deal with faster tire wear then corrosion and chipping paint.
Waiting for opinions..
Old May 7, 2006 | 07:29 PM
kcobean's Avatar
kcobean
You *should* be ok. I have 275/35-19's on my car with the same offset rear wheel. The 275/40/18 is .5cm wider, but it's on a 1" smaller rim. No rolling should be needed, nor should more neg. camber.
Edit: It's late and my math sucks.....Your tire would be 1.375 cm wider, not .5.....You still will probably be ok given the .5" smaller radius than my wheels. That extra .5" of vertical travel room is a LOT with these Eibach springs.
Old May 8, 2006 | 08:37 AM
deadcop's Avatar
deadcop
Thanks Kelly
Old May 8, 2006 | 08:51 AM
Noah@AAM's Avatar
Noah@AAM
Nope!!!!
Old May 8, 2006 | 08:52 AM
deadcop's Avatar
deadcop
Originally Posted by Noah@AAM
Nope!!!!
I guess you'll have a chance to find out on Wed morning? Maybe earlier!
Old May 8, 2006 | 10:36 AM
Osix350Z's Avatar
Osix350Z
No rubbing.
Old May 10, 2006 | 01:50 PM
gimpster621's Avatar
gimpster621
ure fine....i was running 19x10.5 with a 23 offset no issues
Old Feb 15, 2021 | 10:43 PM
Ashten Morrison's Avatar
Ashten Morrison
how about 18x10.5 with a 15 offset
Old Feb 15, 2021 | 10:57 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by Ashten Morrison
how 18x10.5 with a 15 offset
Lowered, 95% chance you will need to roll. I rubbed with only 19mm drop and a set of 9.5 +15. Once rolled I can run pretty much anything up to 305 with conservative offset 11s (and have).
Phenom
Aug 7, 2023 05:12 PM
xav_350z
Sep 20, 2007 09:57 AM
chris'smax
Sep 15, 2006 10:51 PM
deadcop
May 9, 2006 06:48 PM
ZinMiami
Nov 21, 2004 07:32 PM
