Need Advise on Replacing Brake Calipers
Old May 11, 2007 | 04:46 PM
wolster's Avatar
wolster
Default Need Advise on Replacing Brake Calipers
I feel it's finally time to change my OEM brakes and rotors (I'm a little over 70K and brakes are getting squeaky) and I'm looking at replacing with a Stoptech Stage 2 brake kit. I want to go ahead and replace the calipers also but I can't seem to find anywhere that sell regular calipers. All the places I check either sell big brake or OEM calipers. Any ides on a particular brand of caliper that will go with the Stoptech Stage 2 brake kit and where to buy? If I replace the calipers will I need to replace anything else? For those who have the Stoptech brake kit what's your experience with them? Thanks for your help.
Old May 11, 2007 | 06:45 PM
Dave@altered's Avatar
Dave@altered
Im confused...If you are not looking for OEM or a BBK then what other caliper choices do you have?
Old May 11, 2007 | 07:17 PM
TENGAI's Avatar
TENGAI
Huh???
Buy someone's OEM brembo's from the classifieds if you're not looking to go overboard. Stoptech stage II for the brembo's is a great match if you want a bit more out of them and would like a nice set of rotors, lines, and pads.
Just my $.02
Old May 11, 2007 | 08:43 PM
wolster's Avatar
wolster
Sorry for the confusion Dave. I don't know if I'm using the right technical terms but please bear with me and I'll try to clarify. I was searching online for replacement calipers to go with the Stoptech Stage 2 brake kit I want to get. The only calipers I found were for big break kits, but I don't need a big brake kit since I'm not going to be doing any heavy track racing . I want to replace my stock calipers with calipers that look and perform better and can fit regular brakes. Do you know where I can get them and what the average price is? Are there any brands I should consider? Thanks.
Old May 11, 2007 | 09:23 PM
blaukal's Avatar
blaukal
wolster -- let me try to help you out, although if you search around the brake forums on here you can pick this up (including the classifieds in the marketplace): the stage 2 kit is made to either fit your non-Brembo calipers, or your Brembo calipers (whichever you have). The calipers by themselves, if you are looking to buy them separately, are pricey. Look at the parts in the Stage 2 kit -- lines, fluid, rotors, pads. The only thing missing is the calipers. You should be able to find the Stage 2 kit for around $700 (MSRP is $800). The full BBK is around $3-6k, depending on what you're buying (brand, size, pistons, etc.). You can buy someone's OEM Brembos (full setup) for less than $2500.
In my opinion, if you're thinking about buying the stage 2 kit, and you want to upgrade your calipers, you're looking at either the option suggested by Tengai (buy someone's OEM Brembos when they upgrade to a BBK), or going all out and getting a BBK (see, for example, this Rotora thread: https://my350z.com/forum/showthread....light=calipers ).
EDIT: note that the stage 2 kit is specific to what type of caliper you have, so you're going to need to decide on whether you're getting bigger calipers up front.
350z82
Oct 1, 2015 06:25 PM
