engine shut off in the middle of third!
Old Dec 10, 2007 | 09:45 AM
Anu2g's Avatar
Anu2g
Default engine shut off in the middle of third!
wtf...i was driving today under moderate acceleration in third, and my engine just turned off...at first i thought the vdc had kicked in since it was wet outside..but it turns out my engine shut off (i just had to stomp the clutch and drop it to get it to start back up since i was already moving).
i haven't done too much research on this..but could this be because of the '06 oil consumption bs?
Old Dec 10, 2007 | 09:48 AM
Kieran@DrivenDynamics's Avatar
I'm thinking the RL kicked in which caused the engine to shut off. I could be wrong take it to the dealer and see what they say.
Old Dec 10, 2007 | 09:51 AM
MasterRacer's Avatar
MasterRacer
Check your oil level much? And its not B.S
Old Dec 10, 2007 | 09:57 AM
Anu2g's Avatar
Anu2g
WOW
I just popped my hood...
My pop charger was completely detached from the Venturi ring!! I've heard of ppls pop charger falling off...but detaching from the Venturi ring? That's kind of weird.
What should I be doing now? Should I open up the plenum and check if anything got into my engine? This is some extremely noobsauce crap to happen to me. I'm guessing I should clean the MAF sensor?
Old Dec 10, 2007 | 09:58 AM
Anu2g's Avatar
Anu2g
heh...when i said bs, i just meant its bs that the dealers put us through that crap
Old Dec 10, 2007 | 10:01 AM
Originally Posted by Anu2g
WOW
Yup I was right, the RL kicked in.
Sucks man but atleast you caught it early enough.
Old Dec 10, 2007 | 10:04 AM
Anu2g's Avatar
Anu2g
What does RL stand for?
Old Dec 10, 2007 | 10:06 AM
MasterRacer
whoa that bites a Donkey D!CK, I have a pop charger as well and I have that damn thing on TIGHT! I hope nothing got into your engine dude, NO MONEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 10, 2007 | 10:19 AM
Anu2g's Avatar
Anu2g
well, at least the prob is solved...i put it on nice and tight. hopefully it wasn't like that for long. either way, i will prob be getting a new engine from nissan...not very comfortable to know something like this happened though.
Old Dec 10, 2007 | 11:11 AM
abui01's Avatar
abui01
Reading ur first post without reading any further to what happened, my immediately thought was "he must have an aftermarket intake, most likely a JWT popcharger," after looking at your sig... there it is! "JWT" and I know you don't have the twin turbos from JWT so it obviously was the popcharger. Happens all the time buddy, people's car shutting off because of that mod, that's y I preached "Stock Airbox FTW!!!" for 2 yrs, no one believes me =P
Old Dec 10, 2007 | 11:13 AM
Rice Limiter...
Old Dec 10, 2007 | 11:34 AM
rockinbboy's Avatar
rockinbboy
Yeah well the JWT Pop charger problem usually has been either higher speeds / accelerations. Granted he has a JWT pop-charger sounds like it fell off...something I can't say I've heard of really. Hope nothing got into your engine. How far did you drive it? Did you pull over and check it out immediately? I think if something got sucked into your engine you would have heard it by now.
GLWTF (good luck with the fix) I like to make up acronyms on the fly.
Old Dec 10, 2007 | 11:45 AM
Anu2g's Avatar
Anu2g
Originally Posted by Kieran@DrivenDynamics
Rice Limiter...
Yea, i hit the rice limiter all the time...i need to get it removed
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
