Weird problems after supercharger
Old Jan 29, 2008 | 06:01 PM
tapuout33's Avatar
tapuout33
Default Weird problems after supercharger
Just curious if anyone had problems with their heating system after installing a supercharger or turbo. I guess I never paid attention but during the winter now I start my car up in the mornings and put the heater on and 15 to 20 mins later the car is still blowing cold air. The only way I get hot air coming from the heater is when the car is moving. Very weird and also the temp gauge for outside air temp is off by 10 to 15 degrees. Is this just a coincidence?
Old Jan 29, 2008 | 06:11 PM
bigslim350Z's Avatar
bigslim350Z
I had the same issues. The temp gauge for outside was off by 10-15 degrees, but I got heat if it was turned all the way up. If the thermostat was backed off a bit, then I got cold air. I'm curious why this happens. I'm assuming that the supercharger sits right by where whatever the sensor they use for the outside air is located but the heating thing has got me.
Old Jan 29, 2008 | 07:50 PM
djParis's Avatar
djParis
Retired Racer
Check your coolant levels, sounds like your low.
Old Jan 29, 2008 | 08:49 PM
Alberto's Avatar
Alberto
Cranky FI Owner
dj kinda has it right. Its likely that you have air in your cooling system! My car did the same thing-accumulated over a 1 year period bad enough to overheat the car after a run to 160mph BAD! Built and stock block FI set-ups should be purged 1X a year IMO. I bought a kit to help you do it 100% correctly, no need to mess with the stupid factory purge open, close, open, close while somebody revs it. Try to handle this ASAP even though its cold you dont want air in the system. Id offer to help you out its so easy with the right stuff, takes all of 15 minutes.
Old Jan 30, 2008 | 03:14 AM
bigslim350Z
I just got my new radiator installed so it should be purged, but I might have to see you at some point to do it again, maybe towards the end of summer or something.
Old Jan 30, 2008 | 07:14 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Purging via the factory location is very tricky and for some not an adequate solution. Let me know when you want to do it David I'll help you out.
Old Jan 30, 2008 | 07:21 AM
iStan's Avatar
iStan
ZR
How new? This may be the cause of the air in the system.
Old Jan 30, 2008 | 07:31 AM
TeAm PrOSpEc's Avatar
TeAm PrOSpEc
The heating thing happened to me after a header install! try running your car with the rad cap off. every once in a while rev the engine. Squeeze the upper hose and release quickly. try this for a couple of min and keep filling it up via rad cap this will solve the prob. and as far as the thermo guage goes, wrap the SC with a thermo sheild.
Old Jan 30, 2008 | 08:15 AM
bigslim350Z
so new I haven't got my car back from Function Tuned yet
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
