NEED HELP!! >>>>>NoVA Emissions<<<<<<<
Old Jun 26, 2008 | 02:14 PM
ibkarlito's Avatar
ibkarlito
Exclamation NEED HELP!! >>>>>NoVA Emissions<<<<<<<
Issue: Car has been modified - throwing codes and failing readiness = failure for VA emissions.
Too lazy to swap out necessary components to get passed. Does anyone have a similar experience?? SOMEONE - PLEASE provide me with usable knowledge.
Has anyone ever received a "waiver" on emissions for VA??
If ANYONE has a legitimate hookup for a GUARANTEED PASS - IM me please! (Cash and Beer for Incentive )
****SIDE NOTES - If your feed back does NOT APPLY to Virginia Emissions Laws/Regulations or you have "I think" advice, please keep it moving - Thanks!****
Karl (Mistress)
__________________________________
Old Jun 26, 2008 | 02:32 PM
.steeeeZ33.'s Avatar
.steeeeZ33.
@ J&D auto
lower your car as much as u can.... so they will waiver u...
Old Jun 26, 2008 | 02:33 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
his **** is almost touching the ground that's why i'm thinking it should be straight
Old Jun 26, 2008 | 02:35 PM
ibkarlito's Avatar
ibkarlito
Your in MD?? Does that apply to VA as well??
Karl
Old Jun 26, 2008 | 02:37 PM
.steeeeZ33.
@ J&D auto
inMD, they will waiver you if they have any doubt that theyw ont **** up ur car...
if the emmissions station has any doubts on doing ur emissions without breaking ur car someway, they will give u a waiver.. at least here in MD..
they couldnt get my friends truck over the rollers cuz his control arms are 1.5 inches off the ground. so they waivered him...
they will waiver me cuz my front lip is 3 inches off the ground.
Old Jun 26, 2008 | 02:39 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Karl lower your front all the way and roll up to the emmissions place scraping LOL
Old Jun 26, 2008 | 02:49 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Hey Karl that is how i got my waiver as they said i couldnt drive over the rollers but i really have no clue about va laws............sorry.Check with some of the g35driver guys they may be able to help out also.
Old Jun 26, 2008 | 02:53 PM
ibkarlito's Avatar
ibkarlito
Thanks bro!
Old Jun 26, 2008 | 02:56 PM
superchargedg
Damn Noobs
Originally Posted by ibkarlito
Thanks bro!
Also what codes are you throwing as i may be able to help.
Old Jun 26, 2008 | 03:00 PM
PhiSig's Avatar
PhiSig
Wheel Whore
I looked into this a while ago, and this is what I found, VA emissions inspection will plug into your OBD port -- as long as you are not throwing codes and they don't use a Sniffer you should be fine.
Gotta clear those lights and drive the car for 50 miles or so without them coming back on -- you system will then be ready for the emissions diagnostic tool used by the inspector.
Old Jun 26, 2008 | 03:20 PM
ibkarlito's Avatar
ibkarlito
The codes are generated from the HKS Vpro - I can eliminate codes and pass my readiness IF I just simply put my stock injectors in and run the stock PCM. Down Pipes have fowlers - should be no issue.
Im really interested in hearing more about this "waiver" and if it applies to VA??
Thanks bro!
Old Jun 26, 2008 | 03:28 PM
superchargedg
Damn Noobs
Thanks bro!
Allright man i do understand now.
ibkarlito's Avatar
ibkarlito
I've got a reader and I'm aware of what needs to happen in order to pass emissions....
I'm just looking for a "hookup" and or some sort of "waiver" that applies to VA. If ANYONE can elaborate on legitimate info on a "possible waiver" that would be great!!
Thanks for the info bro!
Karl
Old Jun 26, 2008 | 03:31 PM
ibkarlito's Avatar
ibkarlito
Are you running a standalone, injectors and straight pipes???? If so - did you get passed??
Old Jun 26, 2008 | 04:19 PM
4SHIZZIL's Avatar
4SHIZZIL
I get CAT COVERTS all the time...when mine was due, the drive to DVM my light tripped. I was so pizzzzzzed.
Went to my shop, they cleared it for free and told me to drive at least 50-75 miles...
I66 west I went. Made it back to the Nissan in Chantilly with no codes....passed me then headed to DMV.
good luck man. Dont go to the dealship because they are all low concrete...take it to a shop near my crib con su amigos...
they can hook you up....I will call you in a bit.
Old Jun 26, 2008 | 06:06 PM
ibkarlito's Avatar
ibkarlito
yeah - check out that 3 amigos joint for me and let me know. Thanks!
Hot Cu
Mid-Atlantic
37
Mar 2, 2006 05:43 PM
Hot Cu
Mid-Atlantic
Feb 22, 2006 04:03 PM
Daewoo
Mid-Atlantic
115
Sep 26, 2005 05:47 PM
alex30327
Dec 24, 2002 06:47 AM
