Anyone ever clean their fuel injectors?
Old Jun 14, 2010 | 06:40 AM
viceversa's Avatar
viceversa
Default Anyone ever clean their fuel injectors?
Well as some of you know i'm having this issue with my engine pinging right when i hit the gas. Could be just bad fuel but I have since then filled up elsewhere and used a octane booster. The slight pinging is still there and now I'm starting to explore my options.
Right now I plan on changing out my spark plugs (maybe one step colder), inspecting/cleaning the fuel injectors and cleaning off my MAF. I began looking over the procedure for removing the fuel injectors in the factory repair manual and it looks overwhelming. has anyone ever took off their injectors just to clean them or should I just avoid that all together?
Old Jun 14, 2010 | 08:22 AM
Chen's Avatar
Chen
Octane booster does not do anything. It can actually help cause the injectors to clogg. I would run some seafoam through a vaccume line, change plugs, pour some seafoam in the gas tank and motor as well.
Old Jun 14, 2010 | 02:22 PM
Barnabas's Avatar
Barnabas
National Z Club President
I have never done it. Isnt there a place in PA that does flow cleaning??
Old Jun 14, 2010 | 04:13 PM
ZZZRated's Avatar
ZZZRated
if you have a cold air intake check the intake pipes may be pinging off the body somewhere.
Old Jun 14, 2010 | 04:16 PM
Barnabas's Avatar
Barnabas
he is talking about engine ping
Old Jun 14, 2010 | 07:38 PM
Chen's Avatar
Chen
dunno. a friend of mine actually made his own flow pressure tester but im not sure if it cleans it or not.
Old Jun 14, 2010 | 07:41 PM
BonesZ33's Avatar
BonesZ33
pre-ignition ping could be caused by using low octane fuel, make sure you are using 91 or 93 whatever is available in your area, Change your spark plugs, check for vacume leaks, and since our 350z,s don't have fuel filters, check the fuel pump screen to see if anything is caught in your tank. You would probably throw a code if an injector was bad so i wouldn't jump to that conclusion just yet. Start with the simple things first, I wouldn't drive the car either. You'll ruin engine components. I've done it before with another car.
Old Aug 12, 2010 | 05:44 PM
zcar03's Avatar
zcar03
My DW 600cc injectors are out of the car, can I clean them... I dont have time to send them out as Im towing the car mon am to a tuner....
Old Aug 12, 2010 | 06:33 PM
djamps's Avatar
djamps
I got a set of OEM injectors (35k miles on them) if you wanna try swapping them.
Old Aug 12, 2010 | 07:01 PM
4SHIZZIL's Avatar
4SHIZZIL
every 5 or 6 tanks with BG44K, once every six months i do the MOA by BG too its a full system flush
american lube
ft
hills
and I think elite can do it.
about 150 for the Full system flush 25-30 a can for the fuel tank BG44K
Old Aug 13, 2010 | 05:01 AM
zcar03's Avatar
zcar03
Im thinking I can just spray them with some carb cleaner for now...
Old Aug 16, 2010 | 05:03 PM
RedlineDesign's Avatar
RedlineDesign
DO WORK!
My buddy Kirk at The Boost Lab down in FL does an awesome job, has great prices and very quick turn around.
Old Aug 17, 2010 | 04:56 AM
Bigalow's Avatar
Bigalow
doesnt shell promote cleaner elements in their V power 93 fuel? that might be an option.
_bit
Oct 2, 2015 07:49 AM
