Photos on engine rebuild (N/A)
Old Dec 20, 2005 | 07:42 PM
  #61
Zexy's Avatar
Zexy
Good luck with this project Richie. Looking good..
Old Dec 20, 2005 | 08:08 PM
  #62
Z350Lover's Avatar
Z350Lover
Charles, you are right there again... If I am going with Ferrea valves, the only valve retainers that I can use are 6mm ones and also they will need different springs too from Ferrea... I have a whole list here if someone need it. just PM me..
Thanks Zexy... I hope things will turn out well...
cheers,
richie
Old Dec 21, 2005 | 05:52 AM
  #63
rednezz's Avatar
rednezz
Z350Lover, I really appreciate you sharing your information. I was about to pull the trigger on the cams but now I know I will need to upgrade my valve train. Good luck with your project!
Old Dec 21, 2005 | 12:47 PM
  #64
mchapman's Avatar
mchapman
That depends on how high you are going to rev your motor, if your going past 7400rpm you'll need a built motor first.
Old Dec 21, 2005 | 02:07 PM
  #65
Z350Lover's Avatar
Z350Lover
Murray:
Check your PM at the other 350z forum! I sent you some very useful info.
rednezz:
No worries... If you are just going for anywhere below 7400rpm, Nismo valve springs or JWT valve springs will be more than enough for ya! And cams will not shift your max power up by much though, probably around 300rpm or so, but if you have an 03 car, it is really necessary to get an 05 lower intake plenum from Jason@Performance because it really helps getting more power higher up!
Also for others:
I have decided to go for Ferrea standard size valvetrain set already and they are looking good though... I ordered them from www.xtremeracecars.com, Carl Jr. is really helpful passing me all the tech knowledges that they have on the VQ35 engine.. they are at NJ, so if any of you is around there, you can go in and talk to him about it... he is really cool and helpful! They have over 3 years building VQ35 engine up to 10,500rpm with 1400hp+ on their drag cars and they have no problem using the exact same parts from Ferrea... also he told me that the stock crank has no problem seeing 10,500rpm either! That's a relief for all of us as I was so afraid that I would snap the crank next, never know what will happen after the valvetrain...
The valvetrain set that Carl sells include:
1. Ferrea IN vavles (Stock size or 1mm oversize)
2. Ferrea EX valves (Stock size or 1mm oversize)
3. Ferrea dual spring Sets
4. Ferrea valve Guides
5. Ferrea titanium valve spring retainers
6. Ferrea seals
7. Ferrea locks
8. Ferrea valve spring seat locators
Hope things will turn well from there onwards next year!
cheers,
richie
Old Dec 21, 2005 | 02:14 PM
  #66
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
not sure if you have seen these yet: http://z1auto.com/prodmore.asp?model...ne&prodid=1718
Max lift the springs will support is 12.8mm
would love to get a set on a Z....unfortunately they were not out when I did my heads, so we used the standard NISMO springs. We have been using the dual springs on some very high rpm Evo's with high lift cams (Tomei and JUN), with awesome results
If you need, they offer valves as well (stock diameter and 1mm oversize, though I'd stick with stock for your NA setup)
Old Dec 21, 2005 | 03:03 PM
  #67
Z350Lover's Avatar
Z350Lover
Adam,
Thanks for the info.... abit too late because I have already paid for the Ferrea valvetrain set... but I am sure Murray can go for this set though! It will be good alternative to Ferrea and looks like they might be cheaper too!
cheers,
richie
Old Dec 21, 2005 | 03:25 PM
  #68
thawk408's Avatar
thawk408
Is there any benefits going with these vs the ferrea springs? Would these last longer becuase they are dual springs?
Old Dec 21, 2005 | 03:40 PM
  #69
Z350Lover's Avatar
Z350Lover
Ferrea vavle springs are dual springs too (at least the one that I ordered is with dual springs)... Dual springs actually make the valvetrain set stronger I believe...
I actually went across supertech website 2 days ago, but didn't see much information on the vavletrain set info on their website and they don't seem to make valves to me, that was why I decided to go for Ferrea since it has been tested by people already on the forum...
cheers,
richie
Old Dec 21, 2005 | 03:45 PM
  #70
thawk408's Avatar
thawk408
cheers,
richie
Ah ok. I did not know that Ferrea was dual spring. How much did you end up paying for the springs?
Old Dec 21, 2005 | 07:28 PM
  #71
mchapman's Avatar
mchapman
Thanks Richie, Carl from www.XtremeRaceCars.com was extremely helpful and knowledgeable and good on them for using the VQ35 as their platform! Carl mentioned they are getting 1800rwhp!
Based on what Carl was saying I will also need the stronger valves and valve guides, so I'll get the whole kit also.
Old Dec 22, 2005 | 01:26 AM
  #72
Z350Lover's Avatar
Z350Lover
That's the way Murray!!! Good on you! I really think it is the best way for us who want to rev the engine up to 8000rpm though! We are now on the same boat!
thawk408:
We paid USD$1595 for the entire kit and that's the cheapest offer that I could find...
cheers,
richie
Old Dec 22, 2005 | 12:30 PM
  #73
mchapman's Avatar
mchapman
8000rpm plus here we come, order placed.
Old Dec 22, 2005 | 12:38 PM
  #74
thawk408's Avatar
thawk408
thawk408:
cheers,
richie
Rev it to 8500rpm and tell us if it makes power!!
Old Dec 22, 2005 | 01:05 PM
  #75
mchapman's Avatar
mchapman
Piston speeds past 8K would be the next concern.
Old Dec 22, 2005 | 01:16 PM
  #76
Z350Lover's Avatar
Z350Lover
Murray: Nice one... probably our parts will get shipped together tomorrow...
yeah.. won't want to rev the engine pass 8K at all though... that is somewhere that i would never want to try... valves gave me enough troubles already!
cheers,
richie
Old Dec 22, 2005 | 01:17 PM
  #77
thawk408's Avatar
thawk408
With his rods and pistons I am sure he could go over 8k.
Old Dec 22, 2005 | 04:34 PM
  #78
JDMFairlady21's Avatar
JDMFairlady21
geez richie, i'm really hoping that youcome out with some really good results. you're keeping me 50/50 on either tt or n/a!
Old Dec 22, 2005 | 07:53 PM
  #79
nuff's Avatar
nuff
There's more to 8k+ then rods and pistons.
Old Dec 22, 2005 | 07:56 PM
  #80
mchapman's Avatar
mchapman
I was refering to the heat generated by the friction of the pistons against the cylinder walls once you go past 8000rpm, not the strength of his forged internals. A forum member caculated the speeds the pistons will be reaching at various rpm with the stock VQ35 stroke. Based on that data it seems that going past 8000rpm isnt the best on our motors. Though you might be able to do it occasionally for a short period providing you have adequate cooling capabilities.
