Photos on engine rebuild (N/A)
Old Feb 1, 2006 | 11:30 PM
  #121
Z350Lover's Avatar
Z350Lover
got some photos from my tuner today... she should be ready tomorrow afternoon if everything goes as planned (both UR and stock crank pulleys are balanced, but somehow my UR pulley isn't back from the engine shop and they are chasing it down, so for now, the engine is using the stock crank pulley)
Engine with front engine cover off, you can see those nismo VTC units, look exactly the same as the stock items besides they have "55°" written on top of them.
Engine with stock crank pulley and 05 lower plenum + MD spacer shown
Fujitsubo headers...
Engine got put back to the car by Ryan @ Nizpro
will post some updates tomorrow after I get her back home...
cheers,
richie
Old Feb 2, 2006 | 01:48 AM
  #122
zillinois's Avatar
zillinois
Nice pics. Ritchie you should look into some delrin motor mounts for the beast!
Old Feb 2, 2006 | 04:15 AM
  #123
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Looking awesome...can't wait for results
Old Feb 2, 2006 | 12:39 PM
  #124
100122923's Avatar
100122923
+ 99
Old Feb 2, 2006 | 01:35 PM
  #125
laswyguy's Avatar
laswyguy
+1 subcribing..
your final hp numbers over your base numbers will tell the whole story of the max potential of this motor. I not sure out of 100,000 z's sold anyone has done more N/A. Congrats and keep us posted..
Old Feb 2, 2006 | 01:54 PM
  #126
thawk408's Avatar
thawk408
z350Lover, you should look into the Crawford throttle body. It doesnt do anything for stock cars, but with cams it seems to help out. Might even help more since you have higher CR.
Old Feb 3, 2006 | 01:58 AM
  #127
Z350Lover's Avatar
Z350Lover
It did take a while for me to take my car back but everything is worth it!
Guess what?! We have run out of injectors (stock ones)... yes... 100%!!! We were sooo surprised that we would actually run out of injectors on a N/A tuned engine though, end result 212.5rwKW... that caused some power loss from around 7200rpm to 8000rpm... if we have more fuel to balance out with the air, the top end will keep it at 212.5rwKW or so all the way to 8000rpm... You can see the A/F ratio and compare it to the dyno curve...
The only baseline that I have got is 220rwHP (headers, cats, nismo cat back, flywheel, intake and unichip).... and right now, I have got 289rwHP with cams and internals... so the total gain of 69rwHP... and my max. power occurs around 7200rpm or so now...
The engine is slightly noiser now due to the Ferrea valve train set (compare to the engine sound before valve float happened)... but it is still a lot quieter and smoother than the stock engine...
We will modify the stock injectors a bit to get some volume out... and I will also look at the larger throttle body as well... it should help a bit at the top end though! Drove it home today and I did several 8000rpm gear changes already... it is awesome and this motor just keeps on pulling and pulling all the way to 8000rpm... I can feel the power all the way through! This should really be the engine for the 350z!
Here is the dyno curve from this afternoon's tuning @ Nizpro...
and here is the link to my Dyno clip... all the way to 8000rpm... it pulls so hard... Save it first before watching it!
http://www.sil-chem.com/rlchen/Dyno_mov.MPG
While I was there, Nizpro tuned Ferrari F355 was there for the service too... for those people who don't know about this beast... it is a TWIN TURBO F355... pulling out 550rwKW (738rwHP) @ 12.5psi... with 11.5:1 compression ratio still!
Here is a video of that Ferrari "idling"... sounds very mean and loud... LOUD for a street car though!
http://www.sil-chem.com/rlchen/Ferrari2.MPG
Enjoy them!
cheers,
richie
Old Feb 3, 2006 | 03:26 AM
  #128
fairladyZ in Japan's Avatar
fairladyZ in Japan
Richie .. Simply an incredible journey and an incredible outcome.
and from Nissan, NISMO, this site, Z owners, and N/A followers - we salute you
Old Feb 3, 2006 | 04:27 AM
  #129
ImportPartsPro
One word
AWESOME!!
Congrats and Enjoy the ride
Old Feb 3, 2006 | 04:39 AM
  #130
Z350Lover's Avatar
Z350Lover
Thanks Kyle and Bill...
So I think what this dyno result gives is that going from 10.3:1 compression ratio to 11.5:1 will yield around 14rwKW (19rwHP), considering Ferrea valve train parts don't gain/lose any rwHP compare to standard valve setup... I was actually expecting the result like what I have got, but many people thought it would have been a lot higher... therefore, people who are going down this route have a clear idea on how much gain they can get out of those CR pistons roughly now.
cheers,
richie
Old Feb 3, 2006 | 05:53 AM
  #131
rednezz's Avatar
rednezz
Thats one bad a** car! That motor just sounds so good at the top of its power band.
Old Feb 3, 2006 | 07:00 AM
  #132
Jun's Avatar
Jun
wow, simply amazing.
How much would it cost us if we decided to reach the same level as you (minus all the trial/error things, just the finished product )?
Old Feb 3, 2006 | 01:19 PM
  #133
Z350Lover's Avatar
Z350Lover
Jun,
I have worked out the cost for a few members on the forum and it would be somewhere around USD 27K all up for the performance parts (including motec, exhaust, cams, machining jobs and labours)... but if you are thinking about big power, you can use that for TT + internals and you can easily go up to 600rwHP I believe!
cheers,
richie
Old Feb 4, 2006 | 10:06 AM
  #134
davidgmil's Avatar
davidgmil
Enjoy them!
cheers,
richie
OMG!
Old Feb 4, 2006 | 10:21 AM
  #135
eat rice z33's Avatar
eat rice z33
Niceeeee!!!
Old Feb 4, 2006 | 12:54 PM
  #136
NiSmO D1X's Avatar
NiSmO D1X
wow, 27k. Thats definitely dedication right there. Congrats on your achievement.
Old Feb 4, 2006 | 04:54 PM
  #137
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Excellent job Richie!!!
Old Feb 4, 2006 | 05:19 PM
  #138
MyV6IsFast3r's Avatar
MyV6IsFast3r
You can say that again. VERY nice work. Nissan should hire you to build the future Z.
Old Feb 4, 2006 | 09:21 PM
  #139
Z350Lover's Avatar
Z350Lover
Thanks Tony!!! You can see the MD spacer on my engine too and it works just fine even with 2005 lower intake plenum!
I wouldn't mind that mate, but I am sure they have a lot more talented/skilled people already to figure that out... otherwise they will never consider 450Z in the future and it might also end up to be a lot cheaper than what I have got in my engine bay! They always want to reduce the cost to gain more margins!
cheers,
richie
Old Feb 4, 2006 | 11:34 PM
  #140
FatBoy1's Avatar
FatBoy1
Congrats! Great job, great story.
