Photos on engine rebuild (N/A)
Old Mar 27, 2007 | 08:03 PM
  #181
Reyes5937's Avatar
Reyes5937
Bump for the best thread.
Old Mar 28, 2007 | 09:30 AM
  #182
davidf's Avatar
davidf
That was a brave guy keeping his head under the hood like that @8000 RPM's.
Old Mar 28, 2007 | 10:18 AM
  #183
Sk8fe's Avatar
Sk8fe
There is an in-car video where Richie buries the needle past 9 grand on his NISMO instrument cluster on a throttle blip! Outstanding!...
Old Apr 2, 2007 | 08:17 AM
  #184
nismology1's Avatar
nismology1
Where's this vid?
Old Apr 2, 2007 | 08:41 AM
  #185
Sk8fe's Avatar
Sk8fe
Actually, my bad, the NISMO cluster goes to 8 grand not 9; my apologies.
Here is one of his dyno pull:
http://www.sil-chem.com/rlchen/Dyno_mov.MPG
And here is one redlining at 8 grand.
http://www.sil-chem.com/rlchen/revup1.MPG
I though he had one where he buried the needle past 8 grand (not 9 grand; again my apologies), but he doesn't seem to have that one posted any longer.
Old Mar 22, 2008 | 09:23 AM
  #186
track1z's Avatar
track1z
Default hmmmmmm
Originally Posted by Hydrazine
Yes, it sure is. And its probably tuned to the specific known frequency(s) of a stock VQ.
And with Richies engine being as modified as it is, who knows what the new frequencies are now. Richie is much better off with the fluid damper because it will damp a broad range of frequencies. It should blanket everything that comes out of the crank.
So after balancing the rotaing assembly wouldn't it change the harmonics signal making the crank pully not dampin the right signals?
Old Jul 18, 2008 | 03:03 AM
  #187
h3av3ndeath's Avatar
h3av3ndeath
nice post! i got a question. do you know where i can find nismo headgaskets and valve springs?
Old Jul 18, 2008 | 06:49 AM
  #188
Kwame's Avatar
Kwame
http://z1auto.com/prodmore.asp?model...ine&prodid=919
http://z1auto.com/prodmore.asp?model...ine&prodid=921
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
