Photos on engine rebuild (N/A)
Old Feb 12, 2006 | 11:20 PM
  #161
ZON's Avatar
ZON
Hmmmm
(takes note of this)
Old Feb 13, 2006 | 07:06 AM
  #162
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by rednezz
Couldn't he just get a light weight pulley and balance with the rest of the engine? Also, I thought fluid dampers were for American engines because they are not balanced internally?
Vibration is underestimated by most people, engineers especially mechanical engineers can relate to this. There are n number of natural frequency modes, that means it vibrates at max amplitude not just at one frequency but a succession of ascending frequencies. So even if you try to damp down the first mode, the next mode will definitely excite the body and the higher modes are not just effect of balancing the crankshaft, but the entire system coupled together, so the stiffness of the engine block, crankshaft and other load carrying members play into effect. For example, the engine block will get excited at different frequency than the crank, so a block designer/analyst will try to get those harmonics out by playing/tuning with stiffness in different parts of the block.
There is a reason why inline 6s, 90 deg V8s are considered very well balanced because of the geometry and how the whole system gets excited at the lower modes when the engine is firing.
People love changing flywheels, pulleys etc and are under the illusion that that is the good for the engine and performance, while opposite might be the case.
Dont underestimate the manufacturers design when it comes to advanced engineering, its just plain ignorant.
BTW, keep it up Richie, you are doing a great mod or mods.
Old Feb 27, 2006 | 05:51 PM
  #163
Z350Lover's Avatar
Z350Lover
the fluidampr pulley just arrived... but unfortunately I am not in the country... but already asked my wife to take a pictures for me... and here they are... according to that company, the weight is only 0.9 pond more than the stock one and this is also balanced internally ready to bolt on.... so it shouldn't affect that much on the HP really... and I will put that one on as soon as I get back to australia in 2.5 weeks time... keep you guys posted on the result!
cheers,
richie
Attached Thumbnails Photos on engine rebuild (N/A)-pully.jpg   Photos on engine rebuild (N/A)-pully-back.jpg   Photos on engine rebuild (N/A)-pully-bottom.jpg   Photos on engine rebuild (N/A)-pully-top.jpg
Old Feb 27, 2006 | 07:58 PM
  #164
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
There you go Richie! That's exactly what your engine needs to keep it reving a long time.
Old Feb 27, 2006 | 08:51 PM
  #165
godmans's Avatar
godmans
time to get some more vids of the cool VQ!!
Old Feb 28, 2006 | 09:45 AM
  #166
ken350z's Avatar
ken350z
Originally Posted by Nismo 350z
I thought the Z didn't come with a harmonic dampener???
When I replaced my crank pulley I noticed that the stock one DEFINITLY had a rubber section to isolate the outer section. I'm assuming that is the dampener.
K
Old Feb 28, 2006 | 11:43 AM
  #167
Hydrazine's Avatar
Hydrazine
K
Yes, it sure is. And its probably tuned to the specific known frequency(s) of a stock VQ.
And with Richies engine being as modified as it is, who knows what the new frequencies are now. Richie is much better off with the fluid damper because it will damp a broad range of frequencies. It should blanket everything that comes out of the crank.
Old Feb 28, 2006 | 05:07 PM
  #168
Z350Lover's Avatar
Z350Lover
Thanks Tony....
I would say... it is better safe than sorry in this case... losing 1 or 2 rwHP to prevent engine blowing up is really worth it and is also for a piece of mind revving up to 8000rpm everyday...
cheers,
richie
Old Mar 31, 2006 | 01:59 AM
  #169
Z350Lover's Avatar
Z350Lover
I posted these videos in another thread, thought I would continue it here as well....
(Right click and save....)
Starting up
http://www.sil-chem.com/rlchen/startup.MPG
Idle Exhaust Sound
http://www.sil-chem.com/rlchen/idle.MPG
Revving up 1 (In the car with tacho meter at the front)
http://www.sil-chem.com/rlchen/revup1.MPG
cheers,
richie
Old Mar 31, 2006 | 02:04 AM
  #170
Rickdogg's Avatar
Rickdogg
Out of hiatus
That sounds nice and clean. Your engine is just so buttery smooth sounding. Talk about blueprinted!
Old Mar 31, 2006 | 02:33 AM
  #171
fairladyZ in Japan's Avatar
fairladyZ in Japan
Sounds great !!
If you ever get a chance, a video of your running up and down a deserted road under acceleration would be great.
Old Mar 31, 2006 | 02:46 AM
  #172
JDMFairlady21's Avatar
JDMFairlady21
yes please let us hear it full throttle man. sweet setup on the engine.
Old Mar 31, 2006 | 03:08 AM
  #173
Sk8fe's Avatar
Sk8fe
Originally Posted by fairladyZ in Japan
Sounds great !!
Sweet!...
+1 for the vid of the NISMO instrument cluster running up through the gears taking each one to 8 grand on a deserted road!
Old Mar 31, 2006 | 03:15 AM
  #174
Z350Lover's Avatar
Z350Lover
Hahaha... I want to do that too... but there is no deserted roads here for me to do that though... heaps of cops around Melbourne nowadays giving out defective notes... and also I don't really know how to film it while I am driving
I will see what I can do and if I have new videos, will surely post them up here!
cheers,
richie
Old Mar 31, 2006 | 06:15 AM
  #175
Sk8fe's Avatar
Sk8fe
Chest-cam! LOL!
"defective notes" -- is that the same as a ticket?! Here in the states, if a cop pulls you over for speeding they give you a "ticket" with a fine and possibly "points" against your license which have additional monetary implications with your insurance. If you are caught going 30mph or more over the posted speed limit, expect a ride in the back of his car and maybe your license being cut in two on the spot. A tow truck will come for you car later at your expense. Well, that is what I am told, I hope to never find out!
Old Mar 31, 2006 | 03:00 PM
  #176
Z350Lover's Avatar
Z350Lover
we have the point system as well... and each state has different laws... we have 12 points each and you can only recover the points that you lose exactly 3 years later.... that means within 3 years, you only get to play with 12 points in Victoria States... and each speeding ticket will get you 3 points!
The defective notes are for the "modification cars" that are not complied to ADR (Australia Design Rules) or going againsts EPA (Enviornment Protection Association) rules... so we will need to take notes of everything.... even with my recaro seat swapped out, I gotta have an engineer certificate to go with those, you don't want to be pulled over and got a defective note here man! It is not likely for my car to get a defective note since I never lower my car too low (100mm clearance) and also the exhaust isn't as LOUD (90dB)... but some cops never know about those mods and they don't have proper testing tools when you get pull over...
cheers,
richie
Old Mar 31, 2006 | 03:19 PM
  #177
Sk8fe's Avatar
Sk8fe
Well in that case, we get the infamous "Fix-it" ticket. You usually have one week to get the violation fixed and you have to go to the Police station to prove you got it fixed. Or at least that is what my friends had to do as they push/test the "limit" more than I.
Old Mar 31, 2006 | 09:40 PM
  #178
fairladyZ in Japan
You guys in the US don't know how lucky you have it getting tickets.
Look at Richies's experience above in OZ.
In Japan .. I just got #%#%#$ caught going a blistering 53 mph in a 32 mph on a 4-lane highway. Perception of speed here is just unf"ing believable. As you can see .. I am pi$$ed at my own stupidy for having missed this speed trap and the "%#$% stupid laws here.
Result of this violation:
1/ about a $700 fine
2/ 1 day in traffic school .. ZZZZZzzzzz on a weekday .. 1 vacation day gone !!
3/ about 6 points off the total of 10 .. I have to drive grandma style in risky areas for 1 year. If I go over the 10 point limit -- license is removed for 1 year .. then driving re-test .. then new license. El K ***#$% blows.
GRRRRRRRRRRRRRrrrrrrrrrrrrrrrrrrrrrrrr
Old Apr 1, 2006 | 05:44 AM
  #179
Hydrazine's Avatar
Hydrazine
Whoa! That is bad....
LOL! Doing 53 in a 32 is exactly the kind of thing I would naturally do.
Even then. I still don't feel lucky when I get a ticket.
Old Apr 3, 2006 | 03:56 AM
  #180
mchapman's Avatar
mchapman
Ouch!
