NA Build Inside....Soup to Nuts :)
Old May 20, 2008 | 07:49 PM
  #521
1cockyZ's Avatar
1cockyZ
In the factory service manual it is required that you add sealer to the front of the valve cover. I had that leak, it was slow and actually would run to the back of the block. Good luck with the fix.
Old May 20, 2008 | 09:21 PM
  #522
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by Z1 Performance
it started off with just giving me the VTC solenoid code - driver side, then passenger (passenger only once in a while). Then the cam sensor codes started. I don't think there is a code for the crank sensor itself though, but I'm not an expert in OBD2 codes anyway lol. I replaced both cam sensors and the crank sensor today and at least it started. But the codes are still stored and TCS/Slip lights are on. Tomorrow I will remember to bring the laptop so I can at least clear them and see how it goes from there
I find the Service Manual to be the best source of information on OBD-2 codes, what Nissan calls Diagnostic Trouble Codes (DTC). There is one DTC for the Crankshaft Position Sensor, P0335.
I scanned this page from my G35 Service Manual, but I have found most of the 350Z DTC's to be the same. The Service Manual lists the DTC's in numerical order and also by name. P0335 is the only CKP type of DTC listed. There is more information than what I scanned... I always like to see a picture.
To find these codes and other DTC information, look in the EC, Engine Control System section of the Engine manual.
Hope this helps...
Old May 21, 2008 | 03:56 AM
  #523
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
thanks - the valvecover isn't leaking at all though, it's dry up there, actually dry all around the heads on both sides.
Thanks for the post -jb - I've got the factory service manual, problem is with all of these sensors, there really is no diagnosis. It's basically "if you get the code, replace the sensor". If the sensor is plugged in, there really is no reason for it not to read properly. So, since its easy to do, and they have been somewhat of a known issue, we just changed it yesterday. Now I have to clear the codes tonight and go from there
Old May 21, 2008 | 04:09 AM
  #524
blasian's Avatar
blasian
+1
I pulled the code... took the sensor off and cleaned it. It worked for about an hour and bam, I got the code again
Old May 21, 2008 | 07:24 PM
  #525
Z1 Performance
Former Sponsor
Just a quick update and a favor to ask
We tried to clear the codes, to no avail. So on to the next thing
When monitering the car with the Cipher, I am getting 2 different VTC positions when looking at Bank 1 and Bank 2. They aren't significantly different at idle, but different none the less. When I step on the gas, say to around 1500 rpm, I get one VTC side giving a quick cycling that goes positive then back to negative..this corresponds immediately to the rpms bouncing up and down too. I don't see either solenoid moving at all though, even when I step on the gas. However, I don't know what it should look like. We pulled the connectors off both VTC solenoids while the car was running, and there was no change at all.
Can someone with a Cipher plug it in at idle and moniter the following real quick:
Intake cam solenoid #1 and 2 and Intake Cam Position for bank 1 and 2 This way I know what is different, if anything, between what my car is doing vs what it should do.
Thanks
Old May 22, 2008 | 02:16 PM
  #526
__jb's Avatar
__jb
Z + Rear Seat
I'll try it tonight when I get home.
Old May 22, 2008 | 02:19 PM
  #527
Z1 Performance
Former Sponsor
thanks!
Old May 23, 2008 | 10:26 AM
  #528
Oleg's Avatar
Oleg
Adam, I do apologize for OT'ing, but would you mind sharing a bit about your suspension setup, in terms of hardware/settings in the suspension forum, or here?
Thank you.
Old May 23, 2008 | 01:45 PM
  #529
Z1 Performance
Former Sponsor
HKS RS Coilovers
Cusco A Arms
Cusco Rear Camber/Toe Kit
Cusco Swaybars front/rear
Powergrid/Z1 Endlinks front/rear
Full NISMO bushing kit
Front/Rear urethane swaybar bushings
0 toe all around, -1.5 camber front/rear for
Old May 23, 2008 | 01:50 PM
  #530
Oleg's Avatar
Oleg
Thank you very much....
Old May 23, 2008 | 06:05 PM
  #531
Z1 Performance
Former Sponsor
thanks again John - I am going to look at your email tomorrow and try to figure things out this weekend
Old May 23, 2008 | 07:57 PM
  #532
__jb's Avatar
__jb
Z + Rear Seat
Not a problem, Adam.
Hope it helps...
Old May 25, 2008 | 03:33 PM
  #533
dTor's Avatar
dTor
Adam,
It was great to meet you at Zdayz. Had I known who you were when we were talking outside the Louisiana guys' cabin, I would have known this thread is your N/A build you were talking to me about. I was following it pretty closely when you first started it. I thought about this thread when we were talking, but forgot to mention it.
Anyway, good luck on finding your oil leak. Like I said before, when you told me you've been driving your car with this build for about a year before you had any problems (oil leak) and the money you spent doing it (as compared to an F/I build), there aren't many F/I guys I've seen that can say they've been problem free for a year.
BTW, I was looking through my old Cipher logs, but I never logged any of the info you need. Sorry.
Old May 25, 2008 | 05:50 PM
  #534
Z1 Performance
Former Sponsor
thanks dTor - yeah all told the build has treated me more than well. The relatively small issues we have here, have happened to guys with nearly stock cars as well, so it's nothing I'm too worried about. I just need the time to properly diagnose it lol
Old May 26, 2008 | 06:15 PM
  #535
Z1 Performance
Former Sponsor
thanks again for the log file John - was helpful to see what a properly working setup should be doing. Here is a log of mine
Time INTK INTK Sol Sol MAF TPS
B1 B2 B1 B2 Volt Volt
40 -17.5 -17 0 0 1.31 0.65
80 -18 -17 0 0 1.3 0.65
130 -18.5 -16 0 0 1.3 0.65
180 -17.5 -16.5 0 0 1.32 0.65
230 -18.5 -17 0 0 1.3 0.65
290 -18.5 -16 0 0 1.31 0.65
340 -17.5 -17 0 0 1.3 0.65
390 -18 -16 0 0 1.31 0.65
440 -18.5 -16.5 0 0 1.31 0.65
500 -17.5 -17.5 0 0 1.31 0.65
550 -18 -16.5 0 0 1.31 0.65
600 -17.5 -17 0 0 1.3 0.65
650 -18 -17 0 0 1.45 0.73
710 -18.5 -16.5 0 0 2.13 1.06
761 -18 -17.5 0 0 2.16 1.17
821 -19 -16.5 0 0 2.01 1.19
871 -19 -18 0 0 1.96 1.19
941 -17.5 -18 0 0 2.04 1.18
981 -17.5 -14.5 0 0 2.12 1.16
1051 -19.5 -14 0 0 2.17 1.16
1111 -18.5 -13.5 0 0 2.17 1.16
1161 -19 -16 0 0 2.14 1.17
1221 -19 -15.5 0 0 2.21 1.17
1261 -16 -17.5 0 0 2.2 1.19
1321 -19.5 -17.5 0 0 2.2 1.17
1371 -18.5 -15.5 0 0 2.23 1.17
1442 63.5 -15 0 0 2.28 1.17
1482 -19.5 -17.5 0 0 2.24 1.17
1552 -19.5 -14.5 0 0 2.25 1.17
1602 -17 -17.5 0 0 2.33 1.18
1662 -17 -18 0 0 2.38 1.19
1712 63.5 -16.5 0 0 2.46 1.2
1762 -18 -18 0 0 2.51 1.21
1822 -19 -16 0 0 2.54 1.22
1872 63.5 -17.5 0 0 2.52 1.22
1942 63.5 -16.5 0 0 2.51 1.21
1982 -19.5 -17.5 0 0 2.49 1.19
2052 63.5 -16.5 0 0 2.37 1.09
2112 63.5 -16.5 0 0 2.08 0.92
2163 63.5 -17.5 0 0 1.85 0.8
2233 63.5 -16.5 0 0 1.68 0.68
2273 -19.5 -17.5 0 0 1.62 0.73
2343 -18 -16.5 0 0 1.6 0.74
2393 -19 -17.5 0 0 1.58 0.71
2453 -20 -16.5 0 0 1.57 0.7
2503 -17.5 -16.5 0 0 1.52 0.69
2563 -19 -17.5 0 0 1.51 0.69
2613 -19 -17.5 0 0 1.5 0.68
2683 -19 -15 0 0 1.49 0.68
2733 -19.5 -14.5 0 0 1.47 0.68
2773 -19 -17 0 0 1.49 0.68
2824 -19 -17 0 0 1.5 0.69
2894 -19 -17 0 0 1.46 0.7
2944 -16 -17 0 0 1.51 0.7
3004 -16.5 -16 0 0 1.52 0.7
3054 -16 -16.5 0 0 1.51 0.7
3114 -19 -14.5 0 0 1.5 0.69
3164 -18.5 -14 0 0 1.55 0.73
3234 -18.5 -16 0 0 1.64 0.76
3314 -18 -15.5 0 0 1.66 0.76
3364 -15 -14.5 0 0 1.63 0.74
3424 -19.5 -15.5 0 0 1.56 0.7
3484 -19 -17.5 0 0 1.49 0.68
3535 -19 -16.5 0 0 1.46 0.68
3595 -18.5 -16.5 0 0 1.43 0.68
3655 -18.5 -17 0 0 1.41 0.67
3695 -19 -16.5 0 0 1.39 0.66
3765 -18 -17.5 0 0 1.37 0.65
3815 -19 -16.5 0 0 1.35 0.65
3865 -18 -17.5 0 0 1.36 0.65
3925 -19 -16.5 0 0 1.4 0.69
3975 -18.5 -17 0 0 1.98 0.98
4035 -19.5 -17 0 0 2.37 1.18
4085 -19.5 -18 0 0 2.3 1.3
4145 -19.5 -13.5 0 0 2.21 1.35
4195 -19 -14 0 0 2.19 1.35
4266 -16.5 -15 0 0 2.14 1.35
4316 -15 -13.5 0 0 2.1 1.34
4376 -16.5 -13.5 0 0 2 1.32
4426 -15.5 -14 0 0 1.96 1.32
4486 -18.5 -15.5 0 0 1.93 1.32
4536 -16 -15.5 0 0 2.05 1.33
4606 -15 -13.5 0 0 2.14 1.33
4646 -18 -13.5 0 0 2.17 1.34
4716 -17.5 -15 0 0 2.14 1.34
4766 -17.5 -13 0 0 2.11 1.34
4816 -19.5 -14.5 0 0 2.13 1.34
4876 -16 -15 0 0 2.09 1.34
4927 -16 -13 0 0 2.04 1.34
4987 -16.5 -15.5 0 0 1.97 1.34
5037 -19.5 -17.5 0 0 1.88 1.34
5107 -19.5 -18 0 0 1.82 1.34
5157 -18.5 -16.5 0 0 1.66 1.34
5217 -17.5 -16.5 0 0 1.61 1.34
5267 -18.5 -17 0 0 1.54 1.34
5327 -18.5 -17 0 0 1.72 1.34
5377 -19.5 -18 0 0 1.9 1.34
5427 -19.5 -17.5 0 0 2.03 1.34
5497 -18.5 -15 0 0 2.2 1.34
5537 -16.5 -17 0 0 2.34 1.34
5608 -16.5 -17 0 0 2.43 1.34
5658 -19 -16 0 0 2.56 1.38
5718 63.5 -16.5 0 0 2.61 1.37
5768 -19 -16.5 0 0 2.62 1.35
5828 -20 -17 0 0 2.64 1.37
5878 -19.5 -16 0 0 2.63 1.37
5948 63.5 -16.5 0 0 2.65 1.37
5988 -19 -17.5 0 0 2.62 1.37
6058 63.5 -16 0 0 2.64 1.35
6108 -19.5 -17.5 0 0 2.63 1.38
6168 -20 -17.5 0 0 2.63 1.38
6218 -19.5 -18 0 0 2.64 1.38
6268 63.5 -17 0 0 2.64 1.38
6329 63.5 -17.5 0 0 2.62 1.37
6379 63.5 -16 0 0 2.64 1.38
6449 63.5 -16 0 0 2.63 1.37
6489 -19 -16 0 0 2.63 1.37
6559 63.5 -17 0 0 2.64 1.37
6609 -19.5 -16.5 0 0 2.65 1.37
6669 63.5 -16.5 0 0 2.66 1.38
6719 63.5 -16.5 0 0 2.65 1.38
6779 -18 -17 0 0 2.65 1.38
6829 -19 -16 0 0 2.63 1.37
6899 -20 -17 0 0 2.62 1.37
6949 -19.5 -16 0 0 2.63 1.36
7010 63.5 -17 0 0 2.64 1.36
7060 -19 -17.5 0 0 2.63 1.37
7110 63.5 -17 0 0 2.66 1.41
7170 -18 -17.5 0 0 2.67 1.38
7220 63.5 -16.5 0 0 2.68 1.43
7280 -19.5 -16.5 0 0 2.67 1.38
7330 -20 -16.5 0 0 2.66 1.37
7400 -19 -17.5 0 0 2.65 1.38
7450 -18 -16.5 0 0 2.63 1.38
7510 -19.5 -18 0 0 2.65 1.38
7560 63.5 -17.5 0 0 2.68 1.4
7620 -20 -16.5 0 0 2.71 1.38
7670 -19.5 -16.5 0 0 2.75 1.38
7741 -19.5 -17.5 0 0 2.72 1.38
7781 -19.5 -16.5 0 0 2.71 1.38
7851 -19 -16 0 0 2.69 1.38
7901 63.5 -16.5 0 0 2.66 1.4
7961 -19.5 -18 0 0 2.64 1.38
8011 -20 -16 0 0 2.64 1.36
8071 -19.5 -18 0 0 2.65 1.36
8121 63.5 -16.5 0 0 2.65 1.38
8191 -19.5 -17.5 0 0 2.63 1.36
8251 63.5 -16.5 0 0 2.67 1.36
8301 -19 -16.5 0 0 2.67 1.38
8361 63.5 -16.5 0 0 2.69 1.38
8412 63.5 -17 0 0 2.74 1.38
8472 -19.5 -17.5 0 0 2.78 1.38
8532 -19.5 -17.5 0 0 2.76 1.39
8572 -20 -16.5 0 0 2.68 1.31
8622 -18.5 -17.5 0 0 2 0.82
8692 -19 -16 0 0 1.71 0.72
8742 -19.5 -17.5 0 0 1.6 0.73
8792 63.5 -17 0 0 1.6 0.73
8852 -18 -17.5 0 0 1.63 0.74
8902 63.5 -16.5 0 0 1.63 0.73
8962 -17.5 -17.5 0 0 1.6 0.72
9012 -19.5 -15.5 0 0 1.57 0.7
9072 -20 -17 0 0 1.54 0.7
9123 -17 -17.5 0 0 1.53 0.7
9193 -19 -17.5 0 0 1.51 0.69
9243 -19 -15.5 0 0 1.5 0.67
9303 -19 -15 0 0 1.48 0.69
9363 -19 -17 0 0 1.48 0.68
9413 -19.5 -14.5 0 0 1.42 0.65
Old May 26, 2008 | 06:22 PM
  #536
Z1 Performance
Former Sponsor
The above was us just revving the car while it sat (not driving). Basically what the above shows is that the VTC solenoids are not working at all - what causes that, I have no idea. We've already removed them, and inspected them and they were clean (no buildup inside at all). Even tried swapping one with a spare we had, and still no luck.
On the log John emailed me, you can see his solenoids working at certain rpm points, when just revving the car stationary
We unplugged the UTEC so are just running the factory ecu for now.
Old May 27, 2008 | 04:01 AM
  #537
rx7/350z's Avatar
rx7/350z
sounds like the same problem i had
Old May 27, 2008 | 04:41 AM
  #538
Z1 Performance
Former Sponsor
^that doesn't really help me lolol - details?
Old May 27, 2008 | 09:20 AM
  #539
chris'smax's Avatar
chris'smax
adam, are the solenoids working w/ the utec unplugged? Sorry if i missed it in a previous post.
Old May 27, 2008 | 09:23 AM
  #540
Z1 Performance
Former Sponsor
nope....unplugging the utec had no effect
