NA Build Inside....Soup to Nuts :)
Old Aug 19, 2010 | 10:13 AM
  #1081
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
got my hands on a revup airbox just to do some back to back testing while the weather is still hot - hopefully I'll be able to put it in next week and do some logging to see how it affects AIT in both cruising and traffic situations
also got my hands on some SPL front compression arm bushings, and plan on doing those, and the rest of the rear subframe bushings in the near future, followed by another alignment, as mine is overdue (about 2 years on the current spec and its starting to drift left now)
Old Aug 23, 2010 | 07:30 PM
  #1082
Z1 Performance
Former Sponsor
Did a quick down and dirty install of the 06 box tonight. Wasn't too warm
out but was humid. On my way to work this am with the open
filter I saw peak IATs of 118F. Tonight it didn't even hit 94F. That's a huge
difference considering
I'll do some more driving and logging this week
when the weather clears then I guess make a new
intake pipe and run the airbox going forward
Old Aug 23, 2010 | 07:45 PM
  #1083
MREDDLE's Avatar
MREDDLE
I am glad to hear your new box works for you. Do you know what the ambient temps were?
Old Aug 24, 2010 | 02:19 AM
  #1084
Z1 Performance
Former Sponsor
around 72f and humid
also my temp sensor is in the intake manifold
Old Aug 24, 2010 | 02:59 AM
  #1085
0jiggy0's Avatar
0jiggy0
So your telling me to sell my short rams and go back to stock? Fine, but it doesnt sound as good!
Old Aug 24, 2010 | 03:48 AM
  #1086
Z1 Performance
Former Sponsor
I'd be curious to see what an hr looks like
do some logging on the Cobb
Old Aug 24, 2010 | 09:15 AM
  #1087
0jiggy0's Avatar
0jiggy0
Good idea I was gonna stop by sat anyway. Ill make it my morning project.
Old Aug 26, 2010 | 06:19 AM
  #1088
tuko316's Avatar
tuko316
Adam I'm sorry if its posted in the thread already but how many cfms do your heads flow?
Ever flow the stock manifold and then your ported manifold for a comparison?
Old Aug 26, 2010 | 06:53 AM
  #1089
Z1 Performance
Former Sponsor
I don't have that info on hand, sorry, my machinist has all of those specs
Old Aug 26, 2010 | 07:01 AM
  #1090
Highway Riding's Avatar
Highway Riding
? for the Z1 guys
Do you guys carry the 06 Intake airbox?
Old Aug 26, 2010 | 07:12 AM
  #1091
Z1 Performance
Former Sponsor
yes, just give us a call
Old Aug 26, 2010 | 07:53 AM
  #1092
Highway Riding
awesome thx ^^
Old Aug 27, 2010 | 06:06 AM
  #1093
kacz07's Avatar
kacz07
Adam, I'm assuming you modified the v-stack in the 06 box, but aside from portmatching the surounding plastic of v-stack on the back flange panel that hooks up to your intake pipe, did you modify or cut any other pieces? Did you just cut that whole panel out?
Also, do you think the baffles on the inside of the airbox around the v-stack can be modified or smoothed out to enhance flow? My feeling is that they help with the laminar flow for the MAF sensor equipped cars, which may not be necessary in your case, since you do not use it. By the time it gets to the engine from the >2ft intake pipe, the airflow is probably pretty smooth and consistent.
For reference:
03-05 airbox vs. 06 airbox
Old Aug 27, 2010 | 06:26 AM
  #1094
gt20ir's Avatar
gt20ir
cool to see the inside of those both side by side... assume the one on the right is a rev-up?
Also, all the ribs on the inside of the air box are for support ( so the air box lasts a long time and does not fall apart) but in some other cars they also help cancel sound waves and reduce intake resonance and noise. Many cars make more power by cutting/grinding those out.
Old Aug 27, 2010 | 08:22 AM
  #1095
Z1 Performance
Former Sponsor
I did not touch the inside of the airbox, and I didn't port match anything either -it's just on my car as it comes stock. Didn't really see the point in playing with it, I can't see it netting anything significant
Old Aug 27, 2010 | 08:25 AM
  #1096
2004Black350z's Avatar
2004Black350z
Exhaust Whore
so do u feel the only advantage to running 06 box better IAT?
Old Aug 27, 2010 | 08:30 AM
  #1097
Z1 Performance
Former Sponsor
I have no idea if there is an advantage to it over the pre 06 box or not to be honest. People assume there is because of the more pronounced velocity stack. Your guess is as good as mine. I don't have my stock 04 airbox here anymore to do a back to back with (wish I did). I just happened to grab this thing to test with, and since the IAT's dropped so much vs my open filter, I might as well stay with it. The other option was building a box for the HKS filter I was running, and maybe down the road I will do that, but for now, this was quick and easy to work with, and functional
Old Aug 27, 2010 | 08:42 AM
  #1098
2004Black350z
Exhaust Whore
understand. I was also thinking about building me one or CIN Motorsports build one for my popcharger. I would like to compare IATs and hp diff n popcharger and 06box with a K&N. I know the margin for hp for a intake is slim but if i could make the same power and achieve lower IAT i would buy a 06
Old Sep 10, 2010 | 05:40 PM
  #1099
MIKERNM1990's Avatar
MIKERNM1990
Old Sep 11, 2010 | 06:46 AM
  #1100
Z1 Performance
Former Sponsor
nothing else planned at this time
