AAM fuel return
Old Aug 16, 2008 | 03:16 PM
_350Lee_'s Avatar
_350Lee_
Default AAM fuel return
About to send my ecu off to AAM to get it reflashed for the new 440cc injectors. While i'm waiting for it to come back, i'll be installing the AAM fuel return system. Just cuious if anyone else is using this fuel return system on a n/a Z?
Old Aug 16, 2008 | 06:11 PM
h2kSPiG's Avatar
h2kSPiG
This is for an NA car?
Old Aug 16, 2008 | 07:13 PM
Kwame's Avatar
Kwame
Why in the world would you need a fuel return system on an NA Z?
Old Aug 16, 2008 | 07:16 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Old Aug 16, 2008 | 08:04 PM
_350Lee_'s Avatar
_350Lee_
i'm building it up for forced induction. Just curious if it would hurt anything in the meantime with a reflash. I completly understand that it is unnecessary for a n/a car. i'm just tired of the parts i ordered still sitting in the box.
Old Aug 17, 2008 | 06:31 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no reason it will cause any issues for na use
Old Aug 17, 2008 | 07:51 AM
_350Lee_'s Avatar
_350Lee_
thanks, when the money comes around, i will be adding forced induction to the car. Until then, i'm just building it up as much as i can. Next upgrade will be the engine management but just dont have the time or place to get it tuned yet. i should have been clearer in my first post with my full intentions. I understand that a fuel return in complete overkill with a n/a Z. I just wanted to know if with the reflash it wouldn't hurt anything until a good tune or the turbo addition. thanks again.
Old Aug 17, 2008 | 12:28 PM
bbs350z's Avatar
bbs350z
the only benefit i can see a reflash doing, is bumping up the idle/removing the speed limiter/raising the rev limiter. (the idle, and rev limit raise should be used in conjunction with cams/headwork)
other than that, save the $500 it'll run you, and get a little closer to some boost
Old Aug 17, 2008 | 01:01 PM
_350Lee_'s Avatar
_350Lee_
i was doing for all those reasons but also they will trim the fuel map for the larger injectors.
Old Oct 7, 2008 | 05:04 AM
irax's Avatar
irax
I am setting up a fuel return system because I'm doing a vq swap into my 240sx, eventually I will go supercharged but for now I just wanted to take advantage of what was already on the car and not have to install a 350z pump and parts off a gas tank. I only need a few pieces but unfortunately you 350z owners needs a lot of stuff to do it right. It will require a lot less fuel pressure from the pump so a stock pump should be good for higher horse power in fuel return mode, than returnless mode, or so I understand.
Old Oct 7, 2008 | 05:07 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
honestly just wait and install everything at one time, the reflash will help NA but if you're planning to FI you're wasting money right now. Get your engine management, fuel system, FI, etc and get all installed/tuned don't do stages
