DIY total N/A backyard build
Old Nov 20, 2008 | 07:55 PM
1cockyZ's Avatar
1cockyZ
Default DIY total N/A backyard build
This is my N/A build project all prices listed
All machine work done by M2 race systems in Farmingdale, NJ
Short block:
Wiseco 11:1 .020" pistons $575 shipped on ebay new
Eagle rods $400 shipped from a forum member new
ACL race bearings, Calico CT-1 coated $256.85 shipped from calico
Machine work was $604.55 including nj 7% sales tax
bore and hone block $240
balanced rotating assembly $160
polish crank $45
Machine down the water jackets for the HR head gaskets $80
Measure all journals and housings $40
Revup oil pump $$185.50 new
OEM gasket set $287.41 new
Heads:
M2 Serdi valve job $335(4 angle with radius cut on intake and 1 angle with radius cut on exhaust) tips ground $55 and mill decks $125 and clean inspect assemble heads $150. Total for the heads was $711.55
Brian crower 264 cams with BC springs and Ti retainers $815 shipped forum member new
HR head gaskets and head bolts $116.80 including 7% sales tax
The intake and plenum setup: From filter to heads
JWT popcharger $109 from avalon racing new
samco intake duct $60 shipped on ebay new
proflow ported throttle body(not used on 2-19-09 dyno tune)
APS tall boy plenum $190 shipped from a forum member used
Nonrevup lower with all the casting imperfections removed
Z1 Big maf housing
Exhaust:
DC sports stainless headers $300 shipped ebay new
aps test pipes $85 shipped my350z member used
nismo y pipe and exhaust $575 ebay used
Misc:
JWT oil pan spacer $65 shipped from my350z member used
koyo r core $275 my350z member new
Fluidampr $335 from titan motorsports
aasco flywheel $220 shipped ebay new
crawford strut tower brace $50 shipped
Right now the goal is to assemble it and not have it blow up. If I forgot something let me know. I am trying to give people an idea of cost for an N/A build if you are a bottom feeder like me and buy used parts and have the patience to wait for bargains. Anyone have any questions or would like to see a picture of something just ask away.
Old Nov 20, 2008 | 08:22 PM
Z_Nick_Z's Avatar
Z_Nick_Z
wow, you are for sure a bargain hunter. some of those prices on there are really cheap!
good luck with the rest of the project. from what i can tell, your going to have a really nice setup
Old Nov 20, 2008 | 08:28 PM
scmtkings4's Avatar
scmtkings4
wowee
good luck with the project man. Hopefully you get some good numbers
Old Nov 21, 2008 | 05:40 AM
rednezz's Avatar
rednezz
Make sure you clean the block and parts well...looks little dirty.
Good Luck on your build and keep us posted.
Old Nov 21, 2008 | 06:16 AM
1cockyZ's Avatar
1cockyZ
The one pic is fresh home from the machine shop. I have since cleaned it twice. Before installing the bearings shown for measuring for clearance I wiped down the block housings with acetone just to remove any residues of any kind. The other pic is just oil from the main bolts as you have to put oil on the threads and seats of the bolts. I have to say there is a lot of not so glamorous parts of this; for example cleaning the crank, block, and measuring everything three maybe four times.
Old Nov 21, 2008 | 09:50 AM
pmohr13's Avatar
pmohr13
nice list! i'm very interested in seeing how this build works out for you. i was hoping to do a build next year, but with the economy it might get pushed of for some time.
Old Nov 21, 2008 | 04:30 PM
Control 350z's Avatar
Control 350z
great list i cant wait to see it when its done
Old Nov 21, 2008 | 08:46 PM
1cockyZ's Avatar
1cockyZ
Cleaned the decks with a green scrubby pad(the one you can barely get stuff off your dishes with) and simple clean. It required a lot of elbow grease but I didn't want to disturb the sealing surfaces of the decks. Also note the machine work for using the HR gaskets.
Old Nov 21, 2008 | 09:35 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Great stuff! keep us updated.oh and post more pix!! .
Old Nov 21, 2008 | 10:59 PM
Lawy'dU's Avatar
Lawy'dU
bookmarked. Can't wait to see this done my friend.
Old Nov 21, 2008 | 11:34 PM
bbs350z's Avatar
bbs350z
subscribed! hope all goes well. love n/a builds
Old Nov 21, 2008 | 11:49 PM
OldDirty Z33's Avatar
OldDirty Z33
Good luck!
Old Nov 22, 2008 | 06:27 AM
1cockyZ's Avatar
1cockyZ
This is not going to be a one week and done deal. I am just a normal guy in my garage, using whatever available free time to do this. But I am taking requests for pics and or explanations of stuff.
Old Nov 22, 2008 | 08:21 PM
leozim's Avatar
leozim
sweet build....... bery nayce!!!
Old Nov 22, 2008 | 08:27 PM
Sean's Avatar
Sean
6K to stay N/A and perhaps pick up 60 hp doesn't seem worth the money and time....you will be unhappy with the results shortly and go FI. You may as well plan for it during your build.
Old Nov 22, 2008 | 08:43 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Sounds fun project. But can i ask you why you went with 264 cams?
Old Nov 23, 2008 | 05:45 AM
350zna's Avatar
350zna
looks great! tons of respect to guys going the fully built NA route
Old Nov 23, 2008 | 05:46 AM
mw9's Avatar
mw9
+1, waiting on results
Old Nov 23, 2008 | 05:55 AM
Monsta's Avatar
Monsta
Old Nov 23, 2008 | 06:19 AM
1cockyZ's Avatar
1cockyZ
I can go fi and drive a grenade without a built engine. I am building the car for track days and to be reliable. This car is already faster than me on a road course and na power is easier for a road course. I chose 264 cams because the car will still idle decent, not loose mid range, and I wanted to be different where is the bc 264 N/A build. Also they were cheap, just like me.
