My NASA Racecar NA Build
Old May 16, 2009 | 07:05 PM
  #61
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Here are some pics during the break in
She is ready to fly, she is still on pump gas so we have the timing pulled way back and running her real rich. Starting the tune on E85 end of next week after we get some more miles on her, anxious to see the numbers!
Old May 16, 2009 | 07:09 PM
  #62
ThreeFiveZero Z
Here was the final build sheet, im sure Im forgetting a few things
CP Custom Pistons 12:1 Compression
Carillo Super A-Beam Rods
ACL Main Bearings
ARP Main/Head Studs
Machine Work by TEC
Heads
JWT S7R Cams
JWT Spring/Shim Kit
Ferrea Valves
3 Angle Radius Job
HKS Head Gaskets
Head Work by TEC
Supporting Mods
KOYO Thick Radiator
Custom HUGE Setrab Core
Nismo Power Steering Cooler
Nismo Thermostat
ATI Super Crank Dampener
APS Oil Pan
Intake/Exhaust
Custom K&N Cold Air (Brought my air temps down from 160 to 100!!!)
Cosworth Intake Manifold
Cosworth High Volume Fuel Rails
RC 440CC Injectors
Custom Dual 2.5" HKS Hi-Power Exhaust
Crawford Ceramic Coated Tuned Headers
Engine Management
Haltech Pnp Standalone
Haltech RacePak Display
Other Track Related Stuff
Sparco Ring Steering Wheel
Works Bell Short Hub
Smart Racing Products Quick Release
Next few weeks
Custom 4pt Roll Bar
6 Pt Harnesses
Recaro Seats
Girodisc 2 Piece Rotors
Old May 16, 2009 | 07:21 PM
  #63
kacz07's Avatar
kacz07
Did you consider the JWT C8R cams? If so, why'd you choose the S7R?
Old May 16, 2009 | 08:23 PM
  #64
mthreat's Avatar
mthreat
Nice! Did you happen to do a before/after dyno with the Cosworth plenum? I'm been considering it (for my N/A setup), but I'd like to know what gains it can give me over the Crawford plenum. I know it will be the usual "small" N/A gains (maybe 5-12 hp or so).
Old May 16, 2009 | 10:01 PM
  #65
ThreeFiveZero Z
Havent tuned the car for full power so I couldnt really tell you. We chose the S7R cams over the C8 cams after a 2 hours phone conversation with Jim Wolf himself lol. We told him our goals and what the car was used for. Great guy if you ever get the chance to talk to him.
Old May 17, 2009 | 01:53 PM
  #66
mthreat's Avatar
mthreat
I can't wait to see your results. If you ever come to a track in Texas, especially TWS, I want to check out your setup, as well as give you a run for your money
Old May 17, 2009 | 04:20 PM
  #67
tuko316's Avatar
tuko316
sweet build and congrats. just curios what modifications were needed to the fuel system to run e85.
Old May 17, 2009 | 04:28 PM
  #68
Peak350's Avatar
Peak350
The larger fuel rails and injectors, along with (guessing) larger fuel lines (filter?) and maybe pump.
E85 primarily takes more fuel, many newer fuel systems are alcohol resistant, just not designed to flow 50% more than the OE tune.
Old May 17, 2009 | 06:22 PM
  #69
ThreeFiveZero Z
Just the fuel rails, injectors, and pump. The stock lines should be sufficient.
Old May 17, 2009 | 06:27 PM
  #70
Peak350's Avatar
Peak350
Are you still running a returnless system?
Thats the reason I was thinking the lines would get replaced (mainly).
Old May 17, 2009 | 07:09 PM
  #71
ThreeFiveZero Z
Its still returnless, didnt see a benefit to running one.
Old May 17, 2009 | 07:17 PM
  #72
Peak350's Avatar
Peak350
Gotcha, it isn't really necessary, just a way to ensure you've got enough fuel at the rail, its more important if you're running high boost (with turbo) or nitrous. Those both have a "shock" draw where the fuel suddenly gets drawn off, and you can get a lean spike.
I'm excited to see what kind of power you make though, this is definitely going to be a pretty awesome set of results.
Old May 17, 2009 | 09:23 PM
  #73
copec's Avatar
copec
I'm excited to see the results as well! Was there any work done on the lowest part of the intake manifold?
Old May 18, 2009 | 02:19 AM
  #74
ThreeFiveZero Z
I have a MREV2 lower collector still in there from when I had the motordyne setup.
Old May 22, 2009 | 04:38 PM
  #75
tuko316's Avatar
tuko316
thanks for the info guys. its something interesting that i will look into some more.
Old May 22, 2009 | 06:33 PM
  #76
ThreeFiveZero Z
Well put about 500 miles on her and took her back up to get tuned today. Got a few other things to do to get her ready the track event next weekend but she should be ready. Should have some official numbers on Tuesday.
Joseph
Old May 22, 2009 | 06:48 PM
  #77
03threefiftyz's Avatar
03threefiftyz
How are the preliminary results looking?
Old May 22, 2009 | 08:25 PM
  #78
ThreeFiveZero Z
The breakin driving was fine, no problems. She definately wanted to pull hard in the top end but I didnt take it past 6k since it wasnt tuned. Real test will be next weekend.
Old May 27, 2009 | 03:24 PM
  #79
ThreeFiveZero Z
Update!
We swapped in another tranny for the mean time while we tear my old one apart to further study it. Car is just about ready for this weekend. As far as the final tune went, she put down 292whp, 246tq on the E85. We are having the power fall off around 6800, which in our opinion is a little early especially with the cams/head work we have gone with. Once we get through this weekend, we are going to throw her back on the dyno after the motor loosens up a bit. We dont see why we cant break into the 300-310 area on a mustang dyno, which would be about 330-340whp on a dynojet for those concerned with higher numbers. The tune is pretty conservative since the motor is built to last for at least 2 years of road racing and time trials. For their first NA build, with a haltech, on E85, I give mad props to the guys at Japtrix. We still have alot of tweaking and work to do so its only up from here! I will make a new post with her performance this weekend at Homestead Speedway!
Joseph
Old May 28, 2009 | 02:23 PM
  #80
warmmilk's Avatar
warmmilk
do you have a dyno chart by any chance?
