Compression: Heads vs. Pistons
Old Jan 28, 2009 | 08:16 AM
DaytonaBlue55's Avatar
DaytonaBlue55
Default Compression: Heads vs. Pistons
Does anyone know if there is a benifit or a difference in creating a higher compression ratio through a smaller combustion chamber or a taller piston. The reason why i came across this dilema is because the NISMO stage 2 heads run a smaller combustion chamber increasing compression to almost 12.0.
Old Mar 25, 2009 | 06:45 PM
nismology1's Avatar
nismology1
Smaller combustion chamber >>>>>>> taller piston dome. If the design is efficient (like the nismo heads) the tendency to knock will be decreased. VQ35DE's don't have a compact/efficient combustion chamber like the VQ30's or VQ35HR. The nismo heads are modeled after VQ30 combustion chambers.
Old Mar 26, 2009 | 09:39 PM
OCG35's Avatar
OCG35
Intriguing thread… in for knowledge…
Old Mar 26, 2009 | 10:39 PM
Ivory's Avatar
Ivory
I looked into the Nismo setup while researching my NA build. Ultimately the price over hp gain isn't likely to be good enough to other "cheaper" alternatives. But I'd love for someone to give it a try and prove me wrong.
Old Mar 27, 2009 | 09:59 PM
leozim's Avatar
leozim
this is a great info.......
Pleask
Dec 21, 2021 03:17 PM
_koubie_
Sep 20, 2015 06:34 PM
