All N/A Build up's, number, mods...Post 'em up
Old Jan 19, 2010 | 04:50 PM
  #101
03threefiftyz's Avatar
03threefiftyz
Originally Posted by jmccarty
03threefiftyz - Lester, the lead tuner at the HKS Technical Factory here in Singapore, says >12:1 though I can not verify that today. I'll see what I can do when I bring it in for servicing before end of week to verify it.
What dyno would you suggest I use to test against the dynapack? I'll ask around and try again.
The dyno type doesn't matter.......did you ever get a baseline (with no or little mods) done on the same dyno?
Old Jan 19, 2010 | 05:02 PM
  #102
gabe3d's Avatar
gabe3d
Why not test it on the same dyno again since it will be easy to compare it to your previous results.
03threefiftyz, his base line numbers are actually reasonable on that dyno (see his dyno in the gallery gallery). Concerning the cam profile, you can't make a blanket statement that 264 is too small for his power. Adam's car only has 268 for that matter and he is making pretty good numbers.
Old Jan 19, 2010 | 05:04 PM
  #103
jmccarty's Avatar
jmccarty
No baseline on my original engine. The baseline on my dyno test is from a slightly modified Z33 previously tested on that dyno.
Since there was no plan to keep anything original in mine, seemed a bit pointless to test the original set-up.
Old Jan 19, 2010 | 05:12 PM
  #104
Crom's Avatar
Crom
Insane build.... any pics or vids ?
Old Jan 19, 2010 | 05:13 PM
  #105
gabe3d's Avatar
gabe3d
Jmccarty, do you know what was done to that lighlty modified Z33?
Any reason why you went with the HKS cam instead of the Cosworth ones? It would have appeared to make more sense to go to the cosworth one as it has been developped with their engine components in mind and you happen to have all of them. Are you tied or sponsored by HKS?
Really curious to hear this run, let us know when you do post them!
Old Jan 19, 2010 | 05:16 PM
  #106
03threefiftyz
He also runs more compression than Adam (I believe).........Perhaps I spoke too generally about the 264's. That being said....I haven't seen anyone make over 300whp on them.....granted NA builds on them don't really exist. I think its a very cool build....I was just trying to pry some extra details out.
Edit.....never seen an HKS BBK on a Z before. Interesting.
Old Jan 19, 2010 | 05:20 PM
  #107
jmccarty's Avatar
jmccarty
Gabe - I don't know the baseline car, the dyno shop guys said it was "lightly" modified.
When I started ordering parts in late 2008, the Cosworth cams were not available yet. I'm not tied to HKS but the HKS Technical Factory did all of the work for me and they have a lot of experience tuning engines with their cams. The electronic variable valve timing control on these cams seemed a good idea at the time.
a friend of mine has offered to video a run if we can get another in his passenger seat to hold the camera. I'll work on it for the weekend.
Old Jan 19, 2010 | 06:39 PM
  #108
Zazz93's Avatar
Zazz93
Gabe, Have you got your car together yet? It should be a monster as well.
Old Jan 19, 2010 | 07:01 PM
  #109
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Actually I think jmmcarty would have a bit less CR than my car. The Cossie short block is 11:1, but then he has the Cossie heads, which actually drops the static CR just a touch because of the larger combustion chamber (I don't think it's by any measurable amount), But, static compression doesn't really change the #'s all that much unless you make big jumps. Engine response goes up a bit as you raise static CR, but it's nothing dramatic. I bet this car feels really strong. I can only imagine it on a nice, cool night!
Gabes car too I think is going to be really impressive
Would be great to get all the NA build cars together for a day at the track or something. Problem is there are too few of us, and we're scattered all over the world lol. Maybe we can at least setup some sort of video archive that shows some stuff on the various setups out there. Would be a cool thing to refer back to.
For the cams, gabe is right. These advertised duration #'s (and lift) really tell you nothing. Cams are pretty funky things (very simple yet complex...a pretty neat invention all things considered!). The #'s that are published are the #'s the manufacturer wants you to see. A few have done over 300 whp on the BC 264's, but there really is no way to compare a 264 from one brand to a 264 of another. Then you get into the whole interaction of the cam, the intake manifold, and the exhaust manifold, and the stuff gets pretty involved. Things with boost in that regard can be much easier to understand and predict, because you can refer back to the efficiency map for the turbo. With a stock set of cams, you have a pretty good idea what to expect with a given turbo or pair of turbos. With the NA stuff, its so much more interdependant, and at so much lower of a power threshhold. The FI stuff gets equally, if not more complex, but it's at a much higher power threshhold, that few every really have to worry about it. But, that's to me what makes it just a different type of challenge.
FWIW I remember talking to Doug from Crawford back in 2008 about cams he had in his car. I forget the exact specs, but he had some custom setup in his car that had a staggered in/ex duration (not sure about lift) and on paper, they were pretty radical for the time. I think he played around with them, tuning, maybe even manifold mods, but just never found their sweet spot. He ended up taking them out, getting a set of the exact same cams I run, and telling me how much better they were overall. They may still be in the car today (if he still has it?).
Old Jan 19, 2010 | 07:14 PM
  #110
03threefiftyz
I think I speak for everyone when I say............................GABE GET YOUR CAR RUNNING ..........I keed, but seriously lol.
Old Jan 19, 2010 | 07:29 PM
  #111
gabe3d's Avatar
gabe3d
Cool, can't wait to see and hear this thing in action. OK-la, post it up when you get a chance this weekend. BTW, is this a race or street car?
The only monster thing about my build is the monster amount of delay I've had...as well as the cost. Hopefully things will wrap up this month...I think...well I hope.
I promise that the car will be running this year for sure without fail. I can't believe that initially I thought this thing was gonna take only two months. Take the time and the price and times it by 2-3... Now that's much more accurate. When is your turn or are you still debating? How are the new brakes?
Good idea on the archive thing (maybe a sticky), would be great to see everyone post up some specs, video, audio, picture, and dyno in a single thread. I can't imagine it being more than 20 guys sadly. Why don't you start one since your build is by far the most elaborate and well known on here.
Old Jan 19, 2010 | 07:44 PM
  #112
03threefiftyz
I haven't put them on yet too be honest. Hopefully this weekend if the weather holds out. Unheated garage is fail here in the winter. I'm going to do more suspension/brakes/etc before I concern myself with power again.
Old Jan 19, 2010 | 08:23 PM
  #113
jmccarty's Avatar
jmccarty
Gabe - I drive it daily to say the least. Here it is outside of my office window today. I track it accross the border in Malaysia at Pasir Gudang F2 track or Sepang F1 track but not often enough. The drive to Pasir Gudang is about 2 hours from my house, Sepang is 3 1/2 hours. The pump gas in Malaysia sucks so I can get a good run around Pasir Gudang and make it home but if to Sepang, I would need to be sure I can get higher octane with the maps I have for fuel mixture.
Attached Thumbnails All N/A Build up's, number, mods...Post 'em up-20-jan-10.jpg
Old Jan 26, 2010 | 03:44 PM
  #114
jmccarty's Avatar
jmccarty
Default Video Clips
Here's a couple of clips:
http://www.youtube.com/watch?v=KB6IoE5FmSE
http://www.youtube.com/watch?v=h2xL1ufTHfw
I have purchased a camcorder after this attempt to get better sound quality. This was with a digital camera with no stereo sound.
I'll do a few more videos over this coming weekend with the proper video camera and post them.
Old Jan 27, 2010 | 06:17 PM
  #115
arsine's Avatar
arsine
City, State which Dyno occured : Coconut Creek, FL
Approx weather condidtions : overcast, about 75, somewhat humid
Baseline Dyno : first time on dyno
1/4 mile time/trap speed : n/a
Tires used in the 1/4 : n/a
Size of wheels/tires used during dyno : 245/40-19
Dyno after your mods : 234
Type of Dyno : mustang
Year : '06
Model : g
Motor : Rev-Up
Engine Oil : nissan oem
Plugs : ngk iridium stock temp
Transmission : 6spd
Clutch : Stock
Flywheel : Stock
Short Shifter : Stock
Final Drive Gear Set : Stock
Rear Diff : Stock
Engine Ground Kit : n/a
Engine Internals : stock
Heads : Stock
Intake Manifold : Stock
Lower Intake Manifold : Motodyne mrev2
Intake Manifold Spacer : motordyne 5/16"
Throttle Body : Stock
Intake : stillen w/z-tube
Headers : Stock
Cats : strup Test Pipes
Exhaust : hks hi power
Fuel System : Stock
ECU : osiris reflash
Fuel used on Dyno : 93
note: i have a cel regarding the o2 sensor on one of my cylinder banks (i believe it to be an issue with my non foulers). guy running the dyno said it was costing me upwards 12hp
Old Jan 27, 2010 | 07:28 PM
  #116
GT-ER's Avatar
GT-ER
Year : '06
Model : g
Motor : Rev-Up
Transmission : 6spd
Clutch : Stock
Flywheel : Stock
Rear Diff : Stock
Heads : Stock
Headers : Stock
Fuel System : Stock
The guy running the dyno really doesn't know what he's talking about.
Old Jan 27, 2010 | 08:15 PM
  #117
Zazz93's Avatar
Zazz93
Old Feb 12, 2010 | 08:10 AM
  #118
rich2342's Avatar
rich2342
Originally Posted by 3_FILTHY_Z
N/A Builds, please post up all info needed seen below
I searched and searched to find a thread like this for N/A's, if there is one, I apologize for overlooking it, but I think it would be cool to see what people are putting down with their set-ups as well as their tastes in certains mods...etc. Copy and paste this original format below and add your parts to the right. If they are stock, type stock, if you have mods for any of these, please list brand, specs etc.
Here's what Info we need in every post in this format so it's easier to read through and it stays uniformed. If this is the first thread uniformed like this, could we make this a sticky mods?
City, State which Dyno occured : Dallas, TX...etc.
Approx weather condidtions : Sunny, about 75, very humid...etc.
Baseline Dyno : List your starting number
1/4 mile time/trap speed : If your ran the 1/4 stock, list it
Tires used in the 1/4 : If your ran the 1/4 stock, list it
Size of wheels/tires used during dyno : List your sizes used on baseline
Dyno after your mods : List your finished number
1/4 mile time/trap speed : If your ran the 1/4 modded, list it
Tires used in the 1/4 : If your ran the 1/4 with anything other than stock tires, list 'em
Size of wheels/tires used during dyno : List your sizes at your latest dyno
Type of Dyno : ex. DynoJet, Mustang...etc.
Year : 03-up
Model : List your model Z or G
Motor : Non-Rev or Rev-Up
Engine Oil : Brand and weight
Plugs : Stock or Colder
Transmission : 6spd or AT, (if AT, Valve Body installed and/or higher stall)
Clutch : Stock or List your Aftermarket
Flywheel : Stock or List your Aftermarket
Short Shifter : Stock or B&M...etc.
Final Drive Gear Set : Stock or 3.9, 4.08...etc.
Rear Diff : Stock or Brand LSD, 2.5 way, 2 way...etc.
Engine Ground Kit : Stock or Aftermarket
Engine Internals : List all parts & specs
Heads : Stock, built, ported & polished...etc.
Intake Manifold : Stock or APS, Kinetix...etc.
Lower Intake Manifold : Stock or Motodyne...etc.
Intake Manifold Spacer : Yes or No, if Yes, which one
Throttle Body : Stock or Aftermarket, Port & Polished...etc.
Intake : Stock or JWT...etc.
Headers : Stock or Borla...etc.
Cats : Stock or HFC, Test Pipes...etc.
Exhaust : Stock or Borla...etc.
Fuel System : Stock or Aftermarket
ECU : Stock or Flashed, S-EMS, Piggyback...etc.
Fuel used on Dyno : 91, 93, C16...etc.
If there is something I missed, please let me know. Thanks. This hopefully will keep threads from starting like the one I wrote earlier yesterday....
Thanks and happy posting
Can I also suggest cost per build? Not trying to pry but it can prove useful to others in their decision making process.
Thanks
Old Jun 22, 2010 | 09:21 AM
  #119
350z-bra's Avatar
350z-bra
what does this monster run in the 1/4 mile?
Old Jun 22, 2010 | 10:19 AM
  #120
0jiggy0's Avatar
0jiggy0
What monster?
