Tomei Header and Cam install
Old Jun 23, 2009 | 04:54 PM
  #41
gabe3d's Avatar
gabe3d
Gabe: Do you have cipher?
Yeah, I have Cipher as well as the Greddy Infotouch that allows me to log certain things without the need of a computer. It's a nice small utility to have to see real time info. I'm going to use it with the sensor adapter to watch boost and such when i do go SCed. I like it a lot better then gauges.
Old Jun 23, 2009 | 04:58 PM
  #42
03threefiftyz's Avatar
03threefiftyz
Ohhh boost. I have been seriously considering of late just turboing the car, but I don't know......I am having fun with it NA.
Old Jun 23, 2009 | 05:00 PM
  #43
gabe3d's Avatar
gabe3d
Here is a pic of my old headers for reference, notice how they practically look identical to the very popular Strup (the way the tubes wrap and meet at the collector)
Old Jun 23, 2009 | 05:02 PM
  #44
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Yeah, it's really up to you with what you can tolerate. I don't especially like too loud and don't need good topend power so I went with the 264.
I def like loud lol. Anyways im just waiting now until u post a VID!!!!!!!!!!!! 03 u should stay NA and have nitrous fun like me lol
Old Jun 23, 2009 | 05:04 PM
  #45
gabe3d's Avatar
gabe3d
The Greddy Infotouch is still very good for NA car. I was thinking of going Turbo as well but the NA upgrades I have transfers a lot better over to SC then it does to Turbo. Also smog is always a concern here in california.
Old Jun 23, 2009 | 05:05 PM
  #46
03threefiftyz
Boooo giggle juice. All the cars I have ever owned ended up getting a bigger turbo or turbo'd. This car has easily made it the longest without getting boost.
Old Jun 23, 2009 | 05:09 PM
  #47
03threefiftyz
Function Tuned has a 1 year warranty on turbo installed by Dave and tuned by him.........on stock block that is. I am SERIOUSLY tempted. Only stipulation is that you can't go over 400whp on his DD (about ~430whp on a dynojet). Still, its the only place I have ever seen to put that much behind their work. I figure after the year I will be tired of 430whp (lol) and have a built block ready to go in. Sorry to jack your thread.
Cali=Fail in terms of their car hating policies.
Old Jun 23, 2009 | 11:27 PM
  #48
gabe3d's Avatar
gabe3d
Here are some awesomely bad video of inside of the car.
Here is an old video that is just as bad in quality but prior to the cams and headers for comparison.
This is the best I can do since it is so late and I had to drive two hours. I promise to take some better vids tomorrow.
Old Jun 24, 2009 | 04:59 AM
  #49
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
280 would be pretty pointless on an otherwise stock short block. 264 is a good grind......I would say anything about 268 is a total waste on a stock short block.
280's don't work with stock pistons
Old Jun 24, 2009 | 06:38 AM
  #50
gabe3d's Avatar
gabe3d
Here are some much better videos.
Old Jun 24, 2009 | 07:46 AM
  #51
03threefiftyz
All the more reason not to use them . Sounds good gabe.
Old Jun 24, 2009 | 01:31 PM
  #52
2004Black350z
Exhaust Whore
1st vid sucks. U should put the camera close so we could hear the cam. Res of vids sound awesome. U were right sounds like a mini V8. Next vid should be on a closed road and WOT and a take off and up close on the exhaust to hear cam. Thanks for thses vids
Old Jun 24, 2009 | 09:07 PM
  #53
Chef-J's Avatar
Chef-J
Booooosstt!!
I'm not a big fan of wrap headers. Check out jet-hot coating next time.
https://my350z.com/forum/intake-exha...coating-2.html
Edit: nice dyno sheet, it's always good to compare before and after. Good gains.
Old Jun 24, 2009 | 09:20 PM
  #54
gabe3d's Avatar
gabe3d
I was looking at Jet-hot as well but then I wanted the heat wrap more for it's sound/vibration insulation properties. It eliminated all of the remaining rasp and almost most of my drone. Drone used to be from 2300-2800 rpm range, but now it's way down to only between 2400-2500 rpm with a more mild droning.
Btw, did you sell your SC?
Old Jun 24, 2009 | 09:25 PM
  #55
gabe3d's Avatar
gabe3d
Yeah, I had to take these for you before i left to work. Hopefully i get some time this weekend before i leave for asia, else it'll be 5 weeks from now. I really wonder how this will sound like with the shockwave tips. I'll try to swap them out since I have them.
Old Jun 24, 2009 | 10:02 PM
  #56
Chef-J's Avatar
Chef-J
Booooosstt!!
shops doing compression/leak down test to see which way i should go with.
Old Jun 24, 2009 | 10:19 PM
  #57
gabe3d's Avatar
gabe3d
I see good luck on that, I just got mine done last week since i have lots of miles on my car (93k) to see if i should rebuild my engine for NA or FI it.
Old Jun 25, 2009 | 05:27 AM
  #58
Chef-J's Avatar
Chef-J
Booooosstt!!
Wow 93k? Coo. How was it? I did test couple weeks ago by cobb tunning, but they didn't give me any paper work they just told me it's good. lol
Why you doing install cams and etc? if you have a high milies car, isn't it better and easier to start build on the side? I'm pretty sure install cams wasn't easy.
Old Jun 25, 2009 | 01:52 PM
  #59
aggietsi's Avatar
aggietsi
The car sounds amazing. Nice job.
Old Jun 25, 2009 | 02:07 PM
  #60
gabe3d's Avatar
gabe3d
Yeah lots of miles, i've had my car for 6.5 years and it's not even my main car, hehe. The check came out to be very good on all cylinders, so he told me not to rebuild my engine unless if i'm going for lots of power. You are getting another test done? Is there some issues with your car?
My heads are fine and those are easy to work on since it just sits on top of the block. So really not too much work. My block and heads got checked and are very healthy so really no need to build a new engine on the side and drop it in. I don't mind the car being out of commission since I have spare ones to drive and also don't feel like spending $6000 or so to replace something that is healthy. I'm not aiming for anything with high power so my last upgrade to my car I will do is a SC, if i do it (btw, your build thread is very informative and thanks for putting it up) Later on if something does go wrong with the block then I'll probably do a small engine rebuild.
Thanks!
