Ah, ok, i didnt know that about the HR cams. Either way, you can get the same performance out of aftermarket cams, correct?
I was talkign about the revup cams, not the HR cams.
I think I read soemwhere that the HR cams are basically the same lobes as the revup cams though. I believe lift is the same, not sure about duration, centerline, etc.
one other tidbit of info, the HR heads use smaller diameter valve heads than the DE motors. Just a little FWIW.
