NA Build: Kacz07's 2006 SS 350z RevUP
Old Jun 14, 2011 | 12:08 PM
  #401
Erik@R/Ttuning's Avatar
Erik@R/Ttuning
Keep on keepin' on with this killer Z Jon.
Old Jun 14, 2011 | 04:54 PM
  #402
Voboy's Avatar
Voboy
Originally Posted by SGSash
I LOVE the comparison of our headers to the Megan headers at high rpm. It's nice to see them make another 10lb-ft of torque as well. I think that proves the advantages of a stepped header and true merge collectors, as well as proper equal length action.
275lb-ft with the cosworth manifold is really good, and I would imagine with a stock non-revup lower your torque would be close to 290 (although I'd imagine the power would be roughly the same).
Great work man! Now bigger cams are needed for even more jam!
those headers are pretty nice... now if only they were still in production...
Old Jun 14, 2011 | 07:15 PM
  #403
the_coupe's Avatar
the_coupe
....and if they were cheaper lol. so i'll be happy with my megans for the time being
but im diggin the 370z nismos
Old Jun 16, 2011 | 03:04 PM
  #404
kacz07's Avatar
kacz07
Thanks for offering them! I really enjoy them. IMO, the sound is cleaner than the Megan's and the performance benefits are clear. I can't help but tinker and wonder how to take better advantage of them.
I'd love to go with bigger cams, but I feel like the stock TB and Cosworth will restrict the flow a little. I have sent out a few messages to vendors to see if they could possibly flowbench and port and polish the Cosworth for better flow, but no one seems interested. I love the Cosworth in the engine bay, so I'd do the P n P and likely chop off the neck and mate it to the GM TB w/ a custom cold air intake or stock box integration.
I'm guessing that would be around a grand for everything intake-wise (flowbench, port/polish, welding, intake pipe, etc.) and then another few hundred for the install of the C9R camshafts, the most aggressive JWT cams available for Rev-ups.
Fortunately/unfortunately, I haven't sold all my old parts for the available cash right now, so no tinkering till I iron my intake plan out (Vince has probably been breathing easier with the absence of calls and emails since the last setup and tune was completed). Not sure if there's anything more I can do exhaust-wise, so I'll leave that alone.
Other than intake and cams, I'm still looking for that optimal catch can setup. I'd like to get that installed ASAP.
Finally, some aural crack:
http://www.youtube.com/watch?v=y9fv-JgtLko
Old Jun 16, 2011 | 04:50 PM
  #405
mgrotel's Avatar
mgrotel
you could do a cutout after the y in the xyz pipe, if tuned for, you might get a little power from that
Old Jun 16, 2011 | 06:45 PM
  #406
the_coupe's Avatar
the_coupe
sounds like secks!!! what exhaust do you have? i woulda thought it woulda been louder with long tubes tho
Old Jun 16, 2011 | 06:56 PM
  #407
SGSash's Avatar
SGSash
Vendor - Former Vendor
Nice! Need more RPM!
Old Jun 16, 2011 | 08:27 PM
  #408
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1 on more rpm and it def sounds so sexy. Whats the sound diff from the SGs and MR?
Old Jun 17, 2011 | 08:34 AM
  #409
Zazz93's Avatar
Zazz93
Sounds higher picthed, a little more crisp than my Megans (but could have something to do with the exhaust though).
Old Jun 17, 2011 | 10:32 AM
  #410
mgrotel's Avatar
mgrotel
love the high pitch sound
Old Jun 17, 2011 | 11:27 AM
  #411
kacz07's Avatar
kacz07
My exhaust is SG Long tubes> MD shockwave V1 w/ the Harakiri canisters. I had straight pipes on before, but they were too loud for me and the sound wasn't commensurate with the performance. The Harakiris sound just right. Idle has calmed down, but it still retains that scream during WOT.
I'm going to make another video on a longer straight. I'll spin it out then. I'm actually curious to see how the powerband looks beyond 8k. I would believe I'm safe to rev a little higher without any problems, considering the beefed up block. 8.5k, 9k? We'll see.
Old Jun 17, 2011 | 12:04 PM
  #412
mgrotel's Avatar
mgrotel
single or dual valve springs?
Old Jun 17, 2011 | 01:46 PM
  #413
kacz07's Avatar
kacz07
^To the best of my knowledge, they are single heavy duty springs. I included them in my build list to IPP.
IPP's website info:
http://www.importpartspro.com/fevqfuvatrki.html
Old Jun 17, 2011 | 02:22 PM
  #414
mgrotel's Avatar
mgrotel
i wouldnt get too crazy with single springs, dont want to ruin your motor
Old Jun 20, 2011 | 06:07 AM
  #415
SGSash's Avatar
SGSash
With C9's, JWT springs are good for ~8000-8200rpm. C10's will rev a bit higher since there's more duration.
Not sure about the springs you have, but needless to say valve springs are one of the most important parts you put inside of your engine.
Old Jun 20, 2011 | 06:14 AM
  #416
e30cabrio's Avatar
e30cabrio
How about JWT S7 cams & JWT springs? What would you say the safe rpm limit with a BC 88mm crank, BC rods & 11.0.1 JE pistons would be?
Old Jun 20, 2011 | 07:13 AM
  #417
Zazz93's Avatar
Zazz93
Safe...Stock. I'm actually thinking you're gonna be limited by the power being made rather than the mechanical stress limits. I'd say shoot for 7200-7500.
The BC kit requires removal of the oil squirters right? I don't like the idea of that mod but maybe they've done their homework.
Old Jun 20, 2011 | 07:16 AM
  #418
kacz07's Avatar
kacz07
I run the Ferrea valvetrain that IPP offers in their engine packages. I spoke to JWT and Ferrea before i built the engine and JWT recommended I used their valve springs because they optimized their springs with their cams. Ferrea said their springs were stronger, so they should hold up fine, but I will definitely revisit this inquiry.
I'm going to call IPP and Ferrea and ask them about safe rpm limits for the valvetrain/motor. Cams are still a ways off in the future, but it will pay dividends to have this info out there before I make my next move.
Old Jun 20, 2011 | 07:19 AM
  #419
e30cabrio's Avatar
e30cabrio
Squirters are gone because the pistons come down into that area. I have added a bigger oil pan, oil cooler the rear coolant mod, three row aluminum radiator and Forged shroud. Cooling/lubrication shouldn't be a problem.
I am shooting for 7500 so should be fine.
Old Jun 20, 2011 | 07:33 AM
  #420
kacz07's Avatar
kacz07
+1 On the higher pitch and crisper sound. To be honest, it was a little bit higher with the straight pipes on, but also lower in the rev range, which was not to my liking. I wanted something that would scream up top and be civil eveywhere else. I probably could've accomplished a similar setup with the V2 with the axleback Helmholtz resonators.
