3.7 in a 350?
Old Jan 31, 2010 | 09:26 PM
NissanJunkie's Avatar
NissanJunkie
Default 3.7 in a 350?
Has any one transplanted the 370 motor into a 350 yet?
Old Jan 31, 2010 | 09:28 PM
SatchScream's Avatar
SatchScream
No, and it's not going to happen, way too impractical.
Old Jan 31, 2010 | 09:36 PM
Nexx's Avatar
Nexx
+1, no newb, but you can stroke your 3.5 to a 4.2 if you can afford it.
Old Feb 1, 2010 | 06:27 AM
drivessidewayz's Avatar
drivessidewayz
Been asked before. If you'd like to be the first to do it, give us a DIY and let us know how much it cost
Old Feb 1, 2010 | 06:54 AM
raycs7's Avatar
raycs7
How much different is the 370 to the 2008 HR?
Old Feb 1, 2010 | 07:04 AM
AzuLzed06's Avatar
AzuLzed06
/\ to much to list. if youre talkin about engines, 3.7 is 24hp over 3.5 HR.
Old Feb 1, 2010 | 07:15 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
completely
Old Feb 1, 2010 | 07:29 AM
ImWeeZzel's Avatar
ImWeeZzel
ive could've sworn there was another thread like this last week... something about a guy having access to a 370 parts really cheap and trying to swap them into a 350
Old Feb 1, 2010 | 07:30 AM
Zazz93's Avatar
Zazz93
It would definitely be easier to use a stroker kit, but if I'm not mistaken you have a DE and will be giving up the updated variable valvetrain. All and all, I don't think its worth the hassels you'll be dealing with for a few months after the motor is in (if you're lucky). I'd spend my resources differently.
Old Feb 1, 2010 | 08:13 AM
raycs7's Avatar
raycs7
I know the 2008 powertrain is completely different from the earlier models.
I am referring to physical differences on the engine and transmission.
For instance the 2008 transmission is a different shape..starter is moved to the other side and the crank angle sensor is relocated. The slave is also internal.
Would the 370 motor bolt to this 2008 tranny?
Old Feb 1, 2010 | 01:42 PM
SexyRob's Avatar
SexyRob
yeah good luck with the swap
first you would need access to the parts at a decent price
you would need the entire engine and hope it mounts to our tranny (don't think this has been confirmed yet)
then you would need the ecu/wiring harness because the stock ecu isn't going to know wtf do to with VVEL.
after you have the ecu/wiring harness you need to figure out how to get it to work with your stock gauges and other 350z components.
mounting is probably the same but you might need a custom bracket if it isn't.
If I were to attempt this I would have to have found a killer deal on a pristine 370 motor.
Old Feb 1, 2010 | 02:36 PM
NissanJunkie
Thank you for your response's, i asked if any one has done this yet, not that i was going to do it. I have 3 03' Z motors (2 shells) and found a $800 salvage 370Z with the Engine, harness, ecu and Tranny still in working condition and was wondering if worth buying.
You make me laugh. I was one of the OG members on this site. Look at my join date, i dont post much people jackass's like you have little of credible info if any at all, and unlike 90% of the members of this site, i do all my own work. Plus the 4.2 is weak sauce if your going F/I with a single T78.
Old Feb 1, 2010 | 02:40 PM
Z1 Performance
Former Sponsor
how about we up the level of discourse just a bit - we have enough 'mine is bigger than yours' threads already
Old Feb 1, 2010 | 02:47 PM
NissanJunkie
Sorry. I was on here oogling before the Z even came out and bought one of the first imported, to be called a n00b just gets under my skin.
Old Feb 1, 2010 | 02:55 PM
SexyRob's Avatar
SexyRob
$800 might be low enough to make me wanna do the swap if it includes all that.
just noticed you were in plano... if you don't want that 370 let me know. hook it up!
Jambo016
Sep 16, 2016 01:08 PM
TrackFiddy
Sep 27, 2015 05:51 PM
