Tease. (Cams)
Old Apr 11, 2010 | 06:44 PM
0jiggy0's Avatar
0jiggy0
Nathan didn't hit the nail on the head. He pounded it with a 40 lb mallet.
Old Apr 11, 2010 | 06:58 PM
rich2342's Avatar
rich2342
Interested as well.
What's up with the intake mod? How is that progessing?
Old Apr 11, 2010 | 08:09 PM
Russ@Z1's Avatar
Russ@Z1
*in for results when released*
Old Apr 12, 2010 | 05:36 AM
SGSash's Avatar
SGSash
Vendor - Former Vendor
Hey Guys,
We are doing TWO seperate cam tests.
One with bolt-in cams that don't require upgraded valve springs, and then once the high compression engine is finished, one with upgraded valve springs designed for guys who are on the hunt for the most power possible.
We are planning to use some of the cams you've already mentioned!
Nathan, maybe you could have the guys from Down Under send us some cams from Kelford? I have never used their cams but have heard good things!
Old Apr 12, 2010 | 06:04 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
So test with Cams on a high compression engine with every bolt on known to man with a crazy modified plenum? I don't care. Didn't know there were so many members with this set up
<-----walks out.
Old Apr 12, 2010 | 06:08 AM
Kwame's Avatar
Kwame
<-----walks out.
... because there are SOOOOO many people who are installing cams on completely stock motors... SMH
Old Apr 12, 2010 | 06:26 AM
tuko316's Avatar
tuko316
When will the magazine print? Will we get the results before hand?
Old Apr 12, 2010 | 06:36 AM
2004Black350z
Exhaust Whore
So according to ur logic only built motor guys or high comp engines have cams? SFT. Hmm guess I need to go back to CIN Motorsports and have my cams uninstalled.
Old Apr 12, 2010 | 08:33 AM
biggersNISMO's Avatar
biggersNISMO
What's the max lift that can be achieved with stock pistons on the DE/HR?
Old Apr 12, 2010 | 08:38 AM
Zazz93's Avatar
Zazz93
If I'm not mistaken I think the problem becomes coil bind, and then head clearencing with stock pistons. I think coil bind is an issue around 11 mm but don't quote me on that one.
Old Apr 12, 2010 | 08:43 AM
biggersNISMO
You mean valve spring clearance?
Old Apr 12, 2010 | 08:54 AM
Kwame's Avatar
Kwame
I'm not sure how you would have surmised that from my previous post but... umm ok.
Edit: Regardless of what motor these tests are conducted on I wish SG the best of luck and I look forward to how this will benefit the community.
Old Apr 12, 2010 | 09:05 AM
Zazz93's Avatar
Zazz93
I was under the impression the head clearencing refered to the lobes. On many engines with really radical cams the stock head just doesn't clear the lobes as they rotate. With stock pistons, the piston to valve clearence should only be a problem if there is an error made. But just the same its always a good idea to "clay" the setup.
Edit: I believe there is a threshold where valve float and bounce becames an issue for the stock springs as well. Its all related.
Old Apr 12, 2010 | 09:20 AM
kacz07's Avatar
kacz07
<-----walks out.
I am one of these members and appreciate the work that SG is putting into this project.
Old Apr 12, 2010 | 01:59 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
11mm is max lift IIRC on the DE, with a stock piston, not sure about an HR though (though I will know in the coming weeks as we're doing a little HR project)
Old Apr 12, 2010 | 06:34 PM
GT-2 350Z's Avatar
GT-2 350Z
I just finished putting together a revup for my car with Arias 11:1 pistons and the JWT C9 cams which are .516 lift (13mm). I am using stock heads with a port match and had to clearance the head around the buckets to clear. I am probably a couple of weeks away from getting it tuned and running so I will let you know how it does.
Old Apr 12, 2010 | 06:58 PM
biggersNISMO
keep us updated
Old Apr 13, 2010 | 12:17 PM
  #38
screener's Avatar
screener
This is going to be a good comparison. Thanks guys!
Old Apr 13, 2010 | 09:01 PM
  #39
ZYouL8R's Avatar
ZYouL8R
So when are results going to be released? I'm eager to see what makes the most power and how much
Old Apr 14, 2010 | 09:04 AM
  #40
SexyRob's Avatar
SexyRob
good to see this happening before I purchase cams for my build. Thanks, look forward to updates.
