Tease. (Cams)
Old Jul 13, 2010 | 09:44 AM
  #81
SexyRob's Avatar
SexyRob
^ Exactly.
Old Jul 14, 2010 | 07:27 PM
  #82
504Z07's Avatar
504Z07
I was told mid last year from someone at BC that they had cams for the HR but now Dustin from BC just emailed me saying they don't make them for it yet, i guess they mistook it for the DE. . .it's been 3 years already. . .somebody make something for the 07-08. . .geez. . .
Old Jul 15, 2010 | 04:53 AM
  #83
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
plenty of companies make cams for the HR
Old Jul 15, 2010 | 05:39 AM
  #84
504Z07's Avatar
504Z07
you're probably right. . .i'm just being a drama queen. . .that's the only ones i was looking forward to so i haven't looked elsewhere. . .
Old Jul 25, 2010 | 11:01 AM
  #85
johnwigs's Avatar
johnwigs
BC dosen't have the cams cause they haven't had a chance to copy JWT cams... JWT has had HR cams for a long time... problem is that the stock cams are real good... minimal gains from cams
Old Jul 25, 2010 | 12:37 PM
  #86
Zazz93's Avatar
Zazz93
Anyone know what the stock VHR grinds are? They seem to have their powerbands so high in the rev range (especially the VHR Nismo) that I can't imagine putting more cam on them without building the bottom-end and valvetrain to take more revs.
Old Jul 26, 2010 | 12:31 PM
  #87
C-unit's Avatar
C-unit
anyone know how well the Tomei 280 cams work with their valve springs??
Old Jul 26, 2010 | 03:24 PM
  #88
Zazz93's Avatar
Zazz93
I'm sure they work fine with their own springs but I imagine you're more interested in how well they work (power) in general. What I thought was odd is on Tomei's website they have the 272's with a higher output. I can only assume this is due to other tuning factors such as lower than needed rev limit.
Old Jul 26, 2010 | 04:01 PM
  #89
Z1 Performance
Former Sponsor
Yes the Tomei springs will work perfectly with the 280 cams.
For the VHR, there are lots of reasons why power peaks so high. It's the same on a DE too...just extrapolated a bit. These engines in general are not low rpm power makers by any means. The cams are a component, but not the only one. There are surely gains to be had, as I will be able to show you soon (on a 3.5HR)
Old Jul 28, 2010 | 02:44 PM
  #90
biggersNISMO's Avatar
biggersNISMO
Nice Adam. Crossing fingers !
Old Aug 10, 2010 | 04:45 PM
  #91
04silvrz's Avatar
04silvrz
bump for results?
Old Sep 28, 2010 | 07:49 AM
  #92
SGSash's Avatar
SGSash
Vendor - Former Vendor
Hey Guys,
The cam test article has gone to print with Modified, so it will be released soon! I'll post the article up here once it's done already.
I do have some bad news for all of you however, that I discovered during the cam test.
The series we raced in - required the Nismo Street Cams. It appears however, as though the cams that were ACTUALLY being used were not - at all - Nismo street cams. So you'll find the results from the test do not match the power numbers we were making by about 15whp. The cams actually being used were closer to something like a JWT C8. They had much larger duration, but tiny lift as they had to work with the stock valve springs.
Sorry to get you all excited and to advertise that we were using the Nismo R-Tune cams - we really believed we were!!!
Old Sep 28, 2010 | 07:56 AM
  #93
Bestswat's Avatar
Bestswat
whattt an update I cant believe it! Im running to the magazine racks as we speak.
Old Sep 28, 2010 | 07:58 AM
  #94
Z_HighSpeed's Avatar
Z_HighSpeed
in for results
Old Oct 1, 2010 | 09:52 AM
  #95
kacz07's Avatar
kacz07
Originally Posted by SGSash
Hey Guys,
The cam test article...
The cams actually being used were closer to something like a JWT C8. They had much larger duration...
Well, I happen to have C8Rs in my car
Can't wait for your new products!
Old Oct 1, 2010 | 02:57 PM
  #96
SexyRob's Avatar
SexyRob
NOOOOO, I wanted to see the nismo cams sooo bad! I already bought them and I'm almost ready to put them in, guess I'll just have to dyno and get the results.
Old Oct 2, 2010 | 10:28 AM
  #97
Bestswat's Avatar
Bestswat
Must be similar to the tomei 272 cams, longer duration but a lift of 10.5
Old Oct 7, 2010 | 01:32 PM
  #98
WetDreamZZZ's Avatar
WetDreamZZZ
So what were the results? I'm having trouble locating a modified magazine at all my local news stands and I checked thier website but didn't find anything there either...
Old Oct 8, 2010 | 05:22 AM
  #99
SGSash's Avatar
SGSash
It hasn't been published yet, it should be coming out shortly, I will post the scans of the article once it's available!
Old Oct 8, 2010 | 07:57 AM
  #100
Zazz93's Avatar
Zazz93
Hey Guys,
... The series we raced in - required the Nismo Street Cams. It appears however, as though the cams that were ACTUALLY being used were not - at all - Nismo street cams. So you'll find the results from the test do not match the power numbers we were making by about 15whp. The cams actually being used were closer to something like a JWT C8. They had much larger duration, but tiny lift as they had to work with the stock valve springs.
Were they custom grinds from the Nismo blanks, or an actual Nismo grind?
