Tease. (Cams)
Old Nov 8, 2010 | 12:41 PM
  #121
SGSash's Avatar
SGSash
Vendor - Former Vendor
Don't be afraid to scan it, the guys from Modified gave me the ok!
Old Nov 8, 2010 | 05:43 PM
  #122
kacz07's Avatar
kacz07
Went to B&N and they didn't have it. Scan?
Old Nov 8, 2010 | 06:09 PM
  #123
Bestswat's Avatar
Bestswat
SCAN IT alreadyy!
Old Nov 8, 2010 | 08:51 PM
  #124
kacz07's Avatar
kacz07
Old Nov 8, 2010 | 10:07 PM
  #125
Classy's Avatar
Classy
Man I have been wanting some S1's for some time now... This makes me want to put off my suspension to put some cams in!
Old Nov 8, 2010 | 10:13 PM
  #126
Flo-ridaZ33's Avatar
Flo-ridaZ33
Interesting...
Old Nov 8, 2010 | 10:41 PM
  #127
kacz07's Avatar
kacz07
I think you're going to need the long tubes or Crawfords for similar results. The test was performed with SGs long tube headers and they are of limited production.
Old Nov 8, 2010 | 11:42 PM
  #128
Flo-ridaZ33
^I inquired and SG pm'd me saying they'll be available shortly at a high(good IMO) price.
Old Nov 9, 2010 | 06:58 AM
  #129
Bestswat's Avatar
Bestswat
Nice test and results. Need to get my hand on those SG long tubes first
Old Nov 9, 2010 | 07:17 AM
  #130
kacz07's Avatar
kacz07
I'd love to see how these rev out ever further.
Old Nov 9, 2010 | 10:23 AM
  #131
SexyRob's Avatar
SexyRob
hmm makes me a little disappointed that I just put nismo cams in, oh well... I'm just happy I have cams
Old Nov 9, 2010 | 11:44 AM
  #132
KA24DE's Avatar
KA24DE
No point with these cams, or the stock manifold. All this shows me is what I have suspected for a while, JWT are one of the best cam makers out there.
Old Nov 9, 2010 | 12:03 PM
  #133
KA24DE's Avatar
KA24DE
Crawford is the new (old) Cosworth manifold. I have yet to see any proof that they produce ANY power. And they are not longtubes.
Old Nov 9, 2010 | 12:07 PM
  #134
Classy's Avatar
Classy
I have Long tubes OBX headers, I dyno'd at 269 hp, I am right there with the test car
Old Nov 9, 2010 | 12:20 PM
  #135
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
but without that intake manifold, throttle body and headers, you are not going to yield nearly the same results as the subject car. The OBX's/Megan's, etc are smaller, and IIRC, not as long as the SG or Crawfords. I'd estimate a 10-15 whp difference and probably an equal amount of torque assuming pump gas and a similar state of tune
Old Nov 9, 2010 | 12:41 PM
  #136
KA24DE's Avatar
KA24DE
If I remember correctly, Crawfords are not true long tubes, and their collector is further upstream compared to a long tube header like Megans and SG, and are SHORTER, bolting up to HFC or Test pipes, while the SG's and OBX/Megan bypass that as part of the design. Furthermore, there have been ZERO dynos showing gains for Crawfords. Snake oil.
Old Nov 9, 2010 | 01:53 PM
  #137
Z1 Performance
Former Sponsor
The primary length on the Crawford is actually longer (slightly) the SG's IIRC (I remember comparing them earlier this year when deciding my next steps for my car) , though yes, it is designed in a shorty configuration, so it needs a test pipe/cat. Yes, collectors are totally different for sure. Outlet diameters differ between them (SG are bigger), which would help with a car that is built and can really rev (and has the cam to suit such a power band). SG Primary diameters differ too in that they are stepped, I don't 'think' the Crawfords are. Again, this will play nicely with some cams and may not be ideal for others, it really all depends. Collectors will def be different due to the packing requirements of a shorty configuration vs a long configuration. SG has alot more room to work with by making it a true long tube, so it stands to reason their collector placement is better, and also longer, which is a nice touch (and probably necessary with the stepped piping in order to prevent reversion). It's a very nicely spec'd and designed header, but like anything else in the NA world, it will only reward the right complimentary setup. Long tube as a product title does not make it necessarily better than short tube...it just makes it different. Just like equal length is not necessarily better than unequal length. What sets the net results apart is how all the subject parts interact.
This is a great article since it's nice to see some in depth testing on the platform. That being said, the only conclusion you can draw is that on a car with this exact setup, you know what to expect from each of the cams chosen. It's cool to see, because it's the first, and likely only time, you would ever see such a test done because it's costly and time consuming. But it will not automatically translate to another car with mods that differ (particularly in the throttle body/intake manifold arena), and in fact, may not be indicative at all of what one can/should expect should they get the same cams. So in that regard, the article doesn't reveal anything staggering (but if you know what you're looking at, you shouldn't expect it to). Change the manifold for the more common spacer, eliminate the 90mm throttle body for the more common stock one in the stock location, put back in a MAF like 90% of people run, and you'll see the results change alot IMHO. Tune it with an ecu that doesn't allow cam timing changes (old school, but a UTEC for example), or even do it on a non-revup, and depending on the cam, you may see the results change even more (I am assuming they manipulated cam timing on a per cam basis to show each in their most positive light, which is the way it should be done IMHO).
A header on a non revup DE without cams is never going to set the world on fire power wise. It never has, and it never will. Makes no difference who makes it. The right headers reward those with the right cams - they significantly affect one another, so they really need to be picked together. Arbitrarily tossing one part in and expecting the world on this platform is unfortunately common
Def look forward to seeing some of the other cams out there tested that we've never seen results of before. Great work Sasha, and thanks for putting it all together
Old Nov 10, 2010 | 08:59 AM
  #138
kacz07's Avatar
kacz07
Point taken, but I am nowhere near stock. Regardless, I am sure that there would be greater variations in power if you bumped the redline up, but you are playing with fire without a built motor.
Old Nov 10, 2010 | 09:01 AM
  #139
kacz07's Avatar
kacz07
I was talking about the Crawford headers (which is why I listed them separately from long tubes), which are proven to make power past 6k, based on JB's and Z1's build. No manifold mentioned in my posts.
You need a hug?
Old Nov 10, 2010 | 11:41 AM
  #140
Classy's Avatar
Classy
I guess we can all be nit picky about brand name, but in the end, there will be a VERY minimal difference between off brand and name brand, seriously, $330 shipped for OBX/Megan headers, or $2k+ for SG's and maybe gain a few HP, I will keep my money. Everything I have read on this site says that unless you are FI or running an EXTREMELY aggressive NA setup, a good old spacer and some porting will do the job right (which I have). Yes the test car has a 90mm TB, but I would seriously doubt that my car would make less than 15 RWHP from that cam with my current setup. I am only 3 hp behind that test car after all!
