New camshaft buckets...
Old Sep 13, 2010 | 02:21 AM
10-E-C-350Z's Avatar
10-E-C-350Z
Default New camshaft buckets...
I got some new ones in today and the tops of the are coated in a dull grey material...is this harmless parkerizing that will go away on it's own after initial startup, or does this need to be removed prior to installation? Thanks!
Old Sep 16, 2010 | 10:08 AM
DaveJackson's Avatar
DaveJackson
Master
It's probably assembly oil... But, the grey part is throwing me off. Assembly oil is usually ultra viscous, like half way between oil and grease. I'm familiar with an ATF (bright red) colour to it so it would still be transparent. Grey doesn't sound quite right.
Old Sep 16, 2010 | 09:20 PM
10-E-C-350Z
I ended up taking a brake clean soaked rag to them and with some elbow grease it all came off. This was definately not lube of any sort. If I had to compare it to anything, it was kind of like a harder version of what they use on the scratch off lottery tickets. I'm guessing it was a corrosion protection measure or some sort.
Old Oct 27, 2010 | 06:42 PM
Zazz93's Avatar
Zazz93
Man, I think that Nissan started using the HR's DLC coated buckets for replacement parts on all Z's. The DLC coating stands up to the higher revs and lift better than without it.
Old Oct 28, 2010 | 04:46 AM
tuko316's Avatar
tuko316
+1. I don't think it was a good idea to take the coating off.
Old Nov 1, 2010 | 10:39 AM
SexyRob's Avatar
SexyRob
wow that would suck if you took off something that was supposed to be on there.
Dr.Paulyy
Jul 29, 2019 07:45 AM
bluefish
Drag
19
Aug 8, 2004 05:39 PM
Lipps
Jun 16, 2003 08:46 PM
Traffic
Apr 2, 2003 07:25 AM
