PCV system mods
Old Aug 18, 2011 | 10:06 AM
  #61
johndoesdamage's Avatar
johndoesdamage
So to my understanding just put a breather filter on the ds Pcv and cap the intake off or catch can from ds Pcv with a breather on the end and capping intake off? Which way would the airflow on the catch be going towards the Pcv or away from Pcv?
Old Aug 19, 2011 | 07:06 PM
  #62
the_coupe's Avatar
the_coupe
airflow would be out the pcv valve (to the intake via vacuum)
Old Aug 20, 2011 | 11:11 AM
  #63
johndoesdamage
I know that for passengers side...is it same for drivers? And capping off intake plug?
Old Aug 20, 2011 | 02:33 PM
  #64
Classy's Avatar
Classy
capping the inlet on the intake and adding a breather filter on the back of the driver's side valve cover makes it so instead of pulling vacuum from the back of the driver's side valve cover, it is actually going to end up sucking and the pcv valve will be doing all of the work pulling out all of the stuff out of both valve covers
Old Aug 21, 2011 | 09:48 AM
  #65
johndoesdamage
Yea went ahead and did it car sounds deeper now it rumbled a little rpms would drop close to the first notch on the rpms gauge so I disconnected battery pumped brakes and then reconnected and no more idle problem the car just sounds deeper
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
