the_coupe's NA build cp manley bc
Old Jun 19, 2011 | 07:58 PM
  #41
e30cabrio's Avatar
e30cabrio
I was referring to the motor being in, not the smoking.
Hope it clears up.
Old Jun 19, 2011 | 08:50 PM
  #42
gabe3d's Avatar
gabe3d
My car smoked real bad during breakin but it was a blow head gasket the first time and a dropped sleeve the second time. Hopefully you don't have either of those problems. I also used conventional valvoline oil during my break-in but it was 10w30.
The car sounds really good! It's great to see that you did everything in house, I wish I could have done that as well. Keep up the good work.
Old Jun 19, 2011 | 09:24 PM
  #43
mgrotel's Avatar
mgrotel
You drilled out the pcv valve? Check compression, leak down test, open your oil filler cap while idling to see if air comes out
Old Jun 20, 2011 | 06:57 PM
  #44
the_coupe's Avatar
the_coupe
turns out this motor doesnt like no pcv valve lol the vacuum was pretty much sucking the oil through the valve cover and filling up the catch can. emptied it out, put a new pcv valve in and problem solved. no smoking. maybe just a tiny light puff here and there but im guessing it has to clear out what was sucked into the plenum now
either way, i put nonfoulers on the rear o2 sensors and that helped with my rich problem.....alphas are within spec now. stayin in the 90% range. and i put in the new clutch master and slave cylinder so NOW my pedal feels normal again! and i changed the oil and filter, no nothing so yayyy!
got an appt set up with CIN in charlotte for the osiris tune saturday morning tho
couple vids....sound still sucks since its from my Fascinate phone
http://www.youtube.com/watch?v=WsrF9...eature=related
http://www.youtube.com/watch?v=gdaNAWr9jko
Old Jun 20, 2011 | 07:16 PM
  #45
e30cabrio's Avatar
e30cabrio
Glad to hear the smoke was just the pvc.
Old Jun 20, 2011 | 08:28 PM
  #46
mgrotel's Avatar
mgrotel
i was wondering why you drilled it out, good to hear. im jealous, as always until i can get going on mine
Old Jun 21, 2011 | 12:41 PM
  #47
mgrotel's Avatar
mgrotel
dyno tune time!
Old Jun 21, 2011 | 06:50 PM
  #48
2004Black350z's Avatar
2004Black350z
Exhaust Whore
wish u had vids from the outside
Old Jun 21, 2011 | 07:13 PM
  #49
the_coupe's Avatar
the_coupe
will def have vids of it while getting dyno tuned and some on the street too!
and i drilled the pcv valve out cuz i was originally planning on running a vented catch can and plugging off the vacuum source........and didnt think to change it out since i stuck with my original setup for now lol
Old Jun 21, 2011 | 07:17 PM
  #50
2004Black350z
Exhaust Whore
ill have Ben send me the vid. Cant wait to hear his impressions of the headers. Me and him/bobby just talked about these headers the other day. Ben's kinda bias bc the original ones he had cracked. How many miles do u have on the headers?
Old Jun 21, 2011 | 07:23 PM
  #51
the_coupe's Avatar
the_coupe
i bought them used from a member here, so no telling how many miles....nothing crazy high im guessing since he blew his motor lol. but the welds looked solid all around on these so im sure they will be ok....if not, ill get them welded over if they start to crack....
but ill be there saturday at 9 so anyone that wants to chill wit me.....feel free to do so
Old Jun 21, 2011 | 07:27 PM
  #52
2004Black350z
Exhaust Whore
whats ur mods again? i know u list them with piks i just wanted to see a list. Thx
Also i would come up there if i was 140 miles out. I try and stop in once a month and we go to lunch. Just got my car retuned the other day. Sucked though it was 104 in the shop
Old Jun 21, 2011 | 07:39 PM
  #53
the_coupe's Avatar
the_coupe
well im 130 miles away lol
cp 11:1 pistons (96mm bore)
manley rods
acl bearings
bottom end balanced
bc stage2 264 cams
bc valve springs and ti retainers
stock valves
port matched/resurfaced heads
port matched intake manifold and plenum
MD 5/16 isothermal spacer
afe stage2 intake
polished inside the upper plenum
stillen oem sized crank pulley
comp clutch stage4 clutch/flywheel kit
hr headgasket mod and headbolts
qx4 rear coolant pipe mod
MR long tube headers
MR ypipe with custom 3" single apexi n1
Old Jun 21, 2011 | 07:41 PM
  #54
2004Black350z
Exhaust Whore
what are you shooting for? i see your AT
Old Jun 21, 2011 | 07:47 PM
  #55
the_coupe's Avatar
the_coupe
Im 6mt. ATs are for girls. lol
Old Jun 21, 2011 | 07:57 PM
  #56
2004Black350z
Exhaust Whore
haha i fail. SOrry late and jager. So im gonna put u around 295-310 if the motor is strong of course. Hopefully u have a weds motor like mymyself lol
Old Jun 21, 2011 | 08:06 PM
  #57
mgrotel's Avatar
mgrotel
lol at autos are for girls, we will see. a simple torque converter drops drivetrain loss from 14-18% to 4-6%
Old Jun 21, 2011 | 08:09 PM
  #58
the_coupe's Avatar
the_coupe
yeah, your post just proves you have consumed excess amounts of jager. lol
im hoping for atleast 300rwhp tho...the more the better go have fun and post back when sober buddy
lol mgrotel,, thats not the first time someone has said "you're AT" when i say i got a clutch kit and never mentioned AT in any post. dont get me wrong, you can make an AT go fast, but if it dont have 3 pedals....i dont want it
  #59
2004Black350z
Exhaust Whore
thats pretty good. Didnt know that
Old Jun 21, 2011 | 08:13 PM
  #60
mgrotel's Avatar
mgrotel
not only go fast, but shift fast too, but im also at 4500ft, so now i have an excuse when my numbers are grossly lower than yours, lol. we have very similar builds though so should be interesting, hopefully i can get some elevation corrected numbers. although, im not big on dyno numbers anyway, but i do want to see where we are both at all said and done.
