rev up heads on de?
Old Jul 1, 2011 | 08:00 AM
sonoriansZ's Avatar
sonoriansZ
Default rev up heads on de?
Well I want to build my heads but I was wondering if it is possible to put the heads of a Rev up on a de. Any1 suggest it or know how or wat to do?
Old Jul 1, 2011 | 10:30 AM
Max-G's Avatar
Max-G
search button?
Old Jul 1, 2011 | 10:48 AM
Cali-Darkness's Avatar
Cali-Darkness
Moved but I think Mods will close. Good luck with your search.
Old Jul 1, 2011 | 01:18 PM
SE5spd's Avatar
SE5spd
Curious to see your reasoning?
Don't stock heads have enough flow for a decent amount of power?
Old Jul 2, 2011 | 06:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Revups are DE's. There are non revup DE and revup DE. The heads are the same, the cams are different. The revup cams have VTC on the intake and exhaust sides, the non revups only have it on the intake side. So, to do a full revup head on a non revup engine would require extra wiring, a new ecu (from a revup).
Old Jul 2, 2011 | 06:11 AM
graffkid732's Avatar
graffkid732
Or the block off covers that I believe Hal sells If not Hal it is some other Vendor on the forum I know does it for sure.
From what I have been told, that is all you need because it takes away the extra sensor and for the DE harness, it wouldn't matter simply because there is no plug to plug into it.
I do not have the PMs any more or else I would have shared.
Old Jul 2, 2011 | 08:37 AM
sonoriansZ's Avatar
sonoriansZ
Just doing a little investigation b4 I get into something impossible. Its my DD so I can't be out of a car for more than a couple days.
Old Jul 3, 2011 | 08:27 AM
graffkid732
I understand, pm Hal at Dynosty, I am almost 100% sure he was the guy I talked to about it.
Old Jul 3, 2011 | 09:22 AM
gabe3d's Avatar
gabe3d
If you want to take benefit of the exhaust VTC you have to do what Z1 said, otherwise you can still bolt up the revup head and cap off the sensor location with these.
http://www.injectedperformance.com/i...for350zg35.htm
Old Jul 5, 2011 | 06:12 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The answer is yes. Revup heads can be used one of two ways on a nonrevup engine:
1. As nonrevup heads, using nonrevup cams. This requires our blockoff plugs. Contact me to purchase. You will use nonrevup front covers for this.
2. As revup heads, using revup cams. This requires some wiring and a Haltech, or swapping stock computer and having the dealer flash. You will also need revup front covers.
Pleask
Dec 21, 2021 03:17 PM
