N/A build advice for lower plenum
Old May 1, 2012 | 07:24 AM
rcdash's Avatar
rcdash
If you are putting in BC cams, put in their springs at the same time! Agree with others, do not change your intake manifold set up. Spacer and non-revup is the best bang for the buck and very close to best overall performer.
Old May 17, 2012 | 10:12 AM
silvertouringz's Avatar
silvertouringz
thank for the replies guys, my build started yesterday. parts installed are:
-BC stage 2 cams
-53mm radiator
-NGK IX iridium spark plugs
-R&D factory valve cover spark plug gaskets
-Hayden tranny cooler
-OEM New valve cover Gaskets
-Radiator Silicone hoses
-Ebay headers
-Uprev etunes directly from uprev
Flushing the radiator LOL
Tranni cooler
Got the radi used for a nice deal
Uprev
Stripped header bolt. It took immense beating to take it out, luckily the stud came out with it in one piece LOL
Headers installed
Camshafts installed
R&D factory spark plug gaskets installed
Nasty leaking old ones out
sry for the mobile photos
Old May 17, 2012 | 10:17 AM
silvertouringz
Originally Posted by 350Zdj
+1.
Rafael, it's me Dex
Install Revup oilpump or Nismo (better but costly) if you want to push beyond 7k rpm.
Sexy build you got there, me likey.
sup dude
Old May 17, 2012 | 01:13 PM
350Zdj's Avatar
350Zdj
yes my mechanic had a painful time taking out the bolts off the oem exhaust manifolds. They actually had to take my engine out.
Originally Posted by silvertouringz
sup dude
Another Time Attack tomorrow at Yas.
Your build is looking good so far!
subscribed!
Old Jun 14, 2012 | 08:47 AM
Zchris350's Avatar
Zchris350
Originally Posted by Rubidium
I highly suggest you keep the stock crank pulley, as I have had an un-orthadox racing pulley on for 30k miles and now it wont come off unless I go to extreme's or possibly break it's connection with the crank. GTM has video's somewhere explaining this issue.
You can get other light weight pulleys for the other components but save the life of your engine and stick with the stock (or ATI pulley)
Are you going to do any port and polishing with the upper plenum or heads?
Hey Rubidium, I too have included UR stock sized pulley set in my NA build. I understand what u mean in regards to the pulley not comming off, but why would you want to take them off? unless they went bad. I know the gain isnt very noticeable, but ive done some reasearch and ive read that when combined with a light weight flywheel and perhaps other breather mods, they really help out through out the powerband.
Old Aug 6, 2012 | 10:44 PM
alex350z06's Avatar
alex350z06
-BC stage 2 cams
-53mm radiator
-Ebay headers
Tranni cooler
Uprev
Headers installed
Camshafts installed
So what were the end results???
