SG Longtubes are back.
Old Jan 25, 2013 | 02:37 PM
XChacalX's Avatar
XChacalX
Originally Posted by 0jiggy0
3 years ago there was so much interest for these and when he came out with them, maybe 2 people bought them. Why would now be any different?
from what I saw , way more than 2 bought his headers ! He ran a few batch of 5 sets everytime and all of them got sold.
andre12031948's Avatar
andre12031948
Originally Posted by XChacalX
gain has been proven on non-rev and rev-up engine..
there is no reason why an HR wouldnt gain from these.
HR headers arent much better than the previous DE headers.
so right there, those SGM are a BIG improvement over what you might have (oem header or stillen crap shorty header....)
the basic of airflow is the same in any engine.
I understand you have a hard time to be willing to drop the $$ on those..
the HR heads has been much improved from the DE.
twin Throttle body in the mix .
all you need is a proper headers setup then ofcourse a good flowing exhaust.
anyway im not here to push you at buying those headers.
it is just because people tend to forget the basic of how NA power is gained.
I wasn't going to say this(so not to hurt anyone) but since you contacted me I will.
While the DE has lousy headers, the HR has completaly different & very good headers.
When you dyno test a DE with stock headers vs a DE with long tube headers the H.P. increase is significant. That is because of 2 reasons. You're replacing a lousy set of headers & you're eliminating the biggest H.P. robber, THE CATS.
As nice as long tube look, & they look like they should increase the h.p.. I won't bother doing them until I see legit dyno results.
An HR with test pipes vs Longtube headers. A good performing HR with long tube at the track would also be helpful.
So, a few guys here are installing them. I can wait & see.
Makes sense?
That test can be made without ANY exhaust past the headers & test pipes.
Old Jan 25, 2013 | 02:45 PM
XChacalX's Avatar
XChacalX
Makes sense?
That test can be made without ANY exhaust past the headers or test pipes.
I wouldnt say the HR has a very good header setup . better than the DE.
Yes, but again, they still suck quite hard for what they are.
have you ever look into their collector, how badly welded the primary are ?
Old Jan 25, 2013 | 02:46 PM
Old Rice's Avatar
Old Rice
11.4whp on non-rev DE with stock cam
http://www.tune2win.com/index.php/pe..._power_adders/
We were anxious to see the results as the SG headers on the same U2NDyno have produced over 30whp on the Revup version of the VQ35 however on our non revup engine we only saw 11.4whp. Some research revealed that the Revups feature a more aggressive cam profile which seems to be able to better use the increased flow that the headers provide. If installing the headers on a non-revup something like a Nismo performance camshaft set would go a long way to realize their true potential. On the road we found the longtubes add a raspyness to the exhaust note at around 3500RPM but when approaching redline sound truly fantastic.
SG Motorsport Longtube Prototype headers +11.4whp
Old Jan 25, 2013 | 02:54 PM
XChacalX's Avatar
XChacalX
I cant see how someone who is willing to pay 2200$-2500$ for the SGM header but wont go with a more agressive cam than what the non-rev cam are.
the more agressive the cam will be , the better those headers will prove a higher gain as they have been tuned for the JWT C8 or around it. (I cant remember)
even the rev-up showed a bigger gain than non-rev..
so yeah the gain has been proved many times.
Old Jan 25, 2013 | 02:58 PM
jwttz's Avatar
jwttz
http://www.fastintentions.com/produc...E%20copy_2.pdf
Here is a link to the fast intentions Lth with Hi flow cats on a 370z. I know it's not apples to apples but it gives you an idea that if the exhaust manifold design on the vq37hr can be with holding power, the ones on a hr can be improved as well.
andre12031948
I don't see any HR's having a header leak. You saying that they still suck hard means O to me. They are excellent. I don't know any after market headers that are better. When Nissan spends a million dollars to develope them, I'm sure they can do as good of a job/better than any joe blow...
I've worked for nissan for 20+ years. I know all the improvements that Nissan made to the H.R. From the design & beefynest of the bottom end, the thicker rods, better heads, cams, throttal bodies, & THE BEST fresh air intakes on the market.
Old Jan 25, 2013 | 03:14 PM
XChacalX's Avatar
XChacalX
ok im gonna stop here and start
you really think their HR oem header as the best on the market..
wow ,, ok
stay in your world then, since it seem like nothing can make you see the true.
again working for Nissan for 20 years does not mean anything if you cant understand the flow dynamic into those headers.
also go tell every Nissan race team to go back to the HR headers since they are perfect.
Old Jan 25, 2013 | 03:18 PM
andre12031948
NO! You're chart proves my point. First if you take 3 dyno runs there's always a best run, a worst run & a run in between. Let's put that aside for now.
The stock headers were tested with CATS. I don't care what kind of cats, they are NOT test pipes. I'm also sure that there's a chance that a good run with headers & not such a good run with stock headers might have been used. Anyway, CATS VS TEST PIPES is a no contest. Any reason why no T.P comparison was done? I can give you one
Old Jan 25, 2013 | 03:22 PM
XChacalX's Avatar
XChacalX
dont worry andre,
im with you when I would love to see a proper test with different combo
since Im swaping the HR engine in my 370z.
I would love to do the test
OEM HR header + testpipe
PPE step long tube header
Momentum + test pipe.
if 2TH PWR will sell me his momentun once he gets his SGM header.
I will surely do the test
im glad I never sold my TP afterall
anyway I always go on the dyno after every mods in the past,
I will continu doing so and share the result.
andre12031948
wow ,, ok
Let's not mix oranges & apples. We are talking about street/stock car with bolt ons.
You still provide no proof what so ever. Can you even show me ONE HR car that is quick with after market headers, long tube perhaps. THat's what I'm looking & waiting for. Show me ONE car....
Old Jan 25, 2013 | 03:26 PM
andre12031948
dont worry andre,
Sounds good. Can't wait.
HR 370z? 3.5 or 3.7 ?
Old Jan 25, 2013 | 03:34 PM
XChacalX's Avatar
XChacalX
to answer your previous post.
all I know for a fact is that Ive seen people gain power from going to an aftermarket header with stock cats on the HR
so yeah their oem headers does suck when you compare them to a true well made shorty headers , such as those Momentum header that I have seen in the pass. and even proven a great deal of gain on the 370z platform over OUR SAME HEADER (HR & VHR) use the same one.
I had a spare HR engine that I had from my 350z old days.
I swaped the VHR crank/connecting rod and modified the HR piston to clear the oil jet and crank,
VQ37HR
Old Jan 25, 2013 | 03:35 PM
jwttz's Avatar
jwttz
Well, modern emissions and hi performance emission systems don't really rob that much hp in the first place. I don't really get the point you are arguing. We all know long tubes don't have cats. Just like we all understand that from a mass production and performance stand point, Nissan did a great job with the stock exhaust manifolds for the price, performance, and emissions that they have to meet. However you are not understanding that chacal is simply stating that the design is not optimised for performance and that it can be improved oppon in a track or race application where emissions and price are not an issue. I think there is that saying in F1 where a 1/10 of a second costs $1,000,000. Or something to that effect.
Old Jan 25, 2013 | 03:41 PM
XChacalX's Avatar
XChacalX
Well, modern emissions and hi performance emission systems don't really rob that much hp in the first place. I don't really get the point you are arguing. We all know long tubes don't have cats. Just like we all understand that from a mass production and performance stand point, Nissan did a grea job with the stock exhaust manifolds for the price, performance ,and emissions that they have to meet. However you are not understanding that chacal is simply stating that the design is not optimised for performance and that it can be improved oppon in a track or race application where emissions and price are not an issue. I think there's that saying in F1 where a 1/10 of a second costs $1,000,000. Or something to that effect.
+1
explained better than what I tried to. ! hehe
Old Jan 25, 2013 | 03:42 PM
andre12031948
VQ37HR
Did both headers have cats???
I don't have a comment about your spare engine thing
Old Jan 25, 2013 | 03:47 PM
andre12031948
First emission robs more H.P from a car then everything else combined.
Second I'm not interested in race cars with engines that cost more than 100K. Neither is anybody else in this forum.
Old Jan 25, 2013 | 03:48 PM
  #38
XChacalX's Avatar
XChacalX
already answered your question that you didnt read I guess.
as far as getting dynosheet for what I said I knew for a fact .
then no because that was a long time ago and im kind of tired trying to make you see the light than doing more research for YOU.
Old Jan 25, 2013 | 03:52 PM
  #39
XChacalX's Avatar
XChacalX
so you do agree that afterall the oem headers arent optimised for the track/race.
ok I see now what you are saying.
  #40
andre12031948
Well then, good luck with your car.... Oh, and keep dreaming about the good old days
