Upper plenum project 75mm Maxima TB
Old Apr 6, 2015 | 08:12 AM
  #81
denchan350gt's Avatar
denchan350gt
Side pic
Old Apr 6, 2015 | 08:19 AM
  #82
denchan350gt
My 3.5 intake setup with 3.5 velocity stack and R2C filter.
Both lowers are ported with a 1/2 spacer.
Sorry for the sideways pic.
Old Apr 6, 2015 | 10:46 AM
  #83
1cockyZ's Avatar
1cockyZ
After replacing the elbow on that upper it will be less Nissan oem part than modified. Kind of like Darth Vader. Also I am purchasing some upper plenums so in the future I can offer a core charge service as well as quicker turnaround.
Old Apr 6, 2015 | 05:03 PM
  #84
DarkZ03's Avatar
DarkZ03
Cocky, my upper plenum is powdercoated can you work with something like that or am I better of getting a spare?
Old Apr 6, 2015 | 05:48 PM
  #85
1cockyZ's Avatar
1cockyZ
I can but it's not going to look good around the weld area. Also the new part will be raw AL.
Old Apr 6, 2015 | 07:14 PM
  #86
denchan350gt
Don't worry about mine it's PC also. I'll just get it redone when I get it back.
Old Apr 7, 2015 | 07:05 PM
  #87
1cockyZ's Avatar
1cockyZ
I just wanted to post this to show how lean the car was from 4500 to redline. Still made power and this car is so consistent. These runs are 12 min apart. I have purchased 2 upper plenums for cores for anyone that needs a zero down time solution. For anyone new to thread this modification is only for use with a 09' Maxima throttle body, you will have to supply the throttle body and adapter harness.
Old Apr 8, 2015 | 08:58 PM
  #88
dylpick21's Avatar
dylpick21
I can't wait to get mine back. I'll have dynos for anyone interested.
Old Apr 17, 2015 | 09:22 AM
  #89
str8dum1's Avatar
str8dum1
which of those lean dynos shows the completely stock car?
Old Apr 17, 2015 | 09:41 AM
  #90
1cockyZ's Avatar
1cockyZ
None. Test car not stock details are in the thread.
Old Apr 20, 2015 | 03:42 PM
  #91
str8dum1's Avatar
str8dum1
so how do you know the car wasnt lean 4500 to redline before you put on the TB?
Old Apr 21, 2015 | 04:57 AM
  #92
1cockyZ's Avatar
1cockyZ
Page 4 the second dyno. Kinetix running at 13.5 and then this plenum running between 14-14.5 afr
Old Apr 28, 2015 | 12:40 PM
  #93
1cockyZ's Avatar
1cockyZ
Progress. The hardest part of this is making flanges. Going cnc after this batch. Not cutting as far as the prototype as it's the initial 90 turn that is awful.
Old May 19, 2015 | 10:52 PM
  #94
90nissanS13's Avatar
90nissanS13
Default How Ironic!
I'm literally working on something very similar to your project. It's nearly finished up...
Would anyone like to see it so far? I won't have test results until the end of summer. The race shop I use is newly relocated and still setting up the dyno.
Here is a shot of my fixture showing milled clearence in the plenum and oem neck in it's original location.
The start of the T/B flange.
T/B flange in progress.
Old May 27, 2015 | 11:08 AM
  #95
denchan350gt
Any new updates/ pics?
Old Jun 28, 2015 | 08:30 PM
  #96
dylpick21's Avatar
dylpick21
Any updates? I've pm'd you. I hope my stock plenum isn't missing or anything.
Old Jul 23, 2015 | 08:32 AM
  #97
jdm-v35's Avatar
jdm-v35
Im guessing nothing ever came of this then? Did anyone get a completed plenum back?
Old Jul 23, 2015 | 09:41 AM
  #98
90nissanS13
It's seems the attention span of this discussion has been exceeded.
Old Jul 29, 2015 | 02:24 AM
  #99
dylpick21's Avatar
dylpick21
Nope I've asked him to send mine back and have had no luck. Thank god it was just an OEM plenum.
Old Jul 29, 2015 | 06:31 AM
  #100
jdm-v35's Avatar
jdm-v35
Still, a plenum is still worth something and can be modded usefully. Sucks more for the person with the modded OEM plenum in the pic. Hope he ends up finishing it, as they have already been cut up in that pic..
