Difference between JWT and Tomei Cams
Old Dec 19, 2018 | 11:00 AM
Chinky4U's Avatar
Chinky4U
Default Difference between JWT and Tomei Cams
Besides the price point and options, can someone explain to me the major differences in regards to the engineering aspect of the cams between the two companies?
Old Dec 20, 2018 | 01:44 PM
onevq35de's Avatar
onevq35de
Nissan VQ Street Cam Shootout - Tech
Testing The Hottest VQ Cams On The Market.
Sasha Anis – Nov 19, 2010
google search "350z cam shootout"
http://www.superstreetonline.com/how...vq-street-cam/
COLOR LEGEND
STOCK GREEN (HP)BLUE (TORQUE)
NISMO PURPLE
TOMEI RED
JWT YELLOW
JWT rules, now
Old Dec 20, 2018 | 01:57 PM
BluestreamDE's Avatar
BluestreamDE
Read this a while back, Sasha truly has done wonders for the VQ community in his quest for more power. Great Article!
BTW the link doesn't work, 404 code, OneVQ
Old Dec 20, 2018 | 03:30 PM
onevq35de's Avatar
onevq35de
Huh...corrected.
Old Dec 20, 2018 | 05:08 PM
dnash's Avatar
dnash
COLOR LEGEND
NISMO PURPLE
TOMEI RED
JWT YELLOW
JWT rules, now
i always thought that dip at 3000 for the Nismo and Tomei cams was quite suspicious. I am using those same Tomei cams and my curve is much more like the JWT curve.
Old Dec 24, 2018 | 05:02 AM
ZMoneyPIT's Avatar
ZMoneyPIT
JWT has great customer support from what I hear from my mechanic. They are very quick to help in decision making and offering advice and still do R&D rather than just throwing a product out on the market and calling it a day. Not knocking Tomei but the language barrier is there.
Old Dec 24, 2018 | 07:27 AM
Chinky4U's Avatar
Chinky4U
Most likely all in the tune? The dip of those cam runs did catch my attention though, so interesting.
Old Dec 24, 2018 | 07:28 AM
LexD's Avatar
LexD
Since he makes no mention of it in the article Id be interested to know if bucket lifters were needed to be replaced with each cam swap. Measuring 32 buckets and rechecking with each cam is a critically important part of all this.
One could potentially need cams + 32 bucket lifters (@ $20/each) for a proper install. Not sure how this left out of the article.
Old Dec 24, 2018 | 07:33 AM
Chinky4U's Avatar
Chinky4U
COLOR LEGEND
NISMO PURPLE
TOMEI RED
JWT YELLOW
JWT rules, now
I mean, you're not wrong lol. The proof is in the pudding here. JWT just basically works.
LONG LIVE NA GLORY, and I do agree about Sasha. He is definitely the NA Maestro. Dude is friggin pioneer, for sure.
I have also heard that JWT has great customer service. A couple of local guys in my city use JWT parts and hadn't complain when they had any problems that needed to be dealt with by JWT. You're also right about language barrier. I remember reading some thread on here about how JWT goes into detail with harmonics and etc.
Old Dec 24, 2018 | 07:34 AM
onevq35de's Avatar
onevq35de
The cam profile is the reason for the dip. Funny how stock out performs tomei and nismo until 3400 rpm. I like Tomei. Got their headers but JWT for the cam shaft win.
Also, read something about aftermarket cam shafts snapping. Not sure wtf that's all about. Think the info was a bit old.
Old Dec 24, 2018 | 09:51 AM
Chinky4U's Avatar
Chinky4U
SNAPPING?! errr....wtf...that's sketchy/
Currently have ppe headers lol so waiting to pull the trigger on some cams. Stuck on the debate for the selection. C8s or tomei procams 272 with a 10.5 mm lift. Mid - high power range because LONG LIVE NA GLORY.
Old Dec 24, 2018 | 10:32 AM
dnash's Avatar
dnash
I disagree.
These are Tomei 262 cams..where is my dip? You can make an argument that the numbers are inflated due to Dynapak but that shouldnt change the curve itself.
From what I have seen, JWT makes a touch more midrange and a touch less topend than the equivalent Tomei cam.
Old Dec 24, 2018 | 10:40 AM
dnash's Avatar
dnash
Here is a pic from Tomei's website:
I don't see a dip anywhere. The first thing I thought when seeing the comparison dyno above was artificially poor tuning to make the JWT cams appear better than the rest.
Old Dec 24, 2018 | 01:24 PM
onevq35de's Avatar
onevq35de
Originally Posted by dnash
I disagree.
"By using my personal 350Z race car for the test, we were able to remove almost all of the typical restrictions from the engine to highlight the changes that come about from a camshaft."
A quote above from the link above. To be more specific, I'd consider the modifications done to Sasha's as compared to another to determine how the cam's profile reacts per any given rpm. I suppose it's not the profile per se, but it's relation to all other modifications done to the engine.
Old Dec 24, 2018 | 02:03 PM
dnash's Avatar
dnash
I'm not debating that one setup should have the exact same results as another but I do feel that the test was biased towards the JWT cams.
Old Dec 24, 2018 | 04:45 PM
onevq35de's Avatar
onevq35de
It could be. I don't know of a reason to suspect Sasha was lying and getting a paycheck from JWT but anythings possible I suppose. If I were to fudge something like this, I think I'd make sure the stock cams looked as bad as the other 2 though cause it's tough to believe the stockers perform better than 2 out of 3 performance joints down low.
Old Dec 24, 2018 | 04:49 PM
onevq35de's Avatar
onevq35de
Neither do I but these dyno charts look like someone drew it up and just connected the dots.
Old Jan 7, 2019 | 02:53 AM
RobPhoboS's Avatar
RobPhoboS
I went with C8 cams, half way through now. Just waiting for a couple of bits (oil pan seals and 1 more valve lifter).
Old Jan 7, 2019 | 07:06 AM
LexD's Avatar
LexD
Out of curiosity-- after torquing cam caps, how many lifters were out of spec in total?
Old Jan 7, 2019 | 07:23 AM
RobPhoboS's Avatar
RobPhoboS
About 6 from memory.
All of them needed to be shorter, I presume due to the valve wearing away some material ?
