07 Base Cp 6MT Tranny Question / Help
Old May 29, 2007 | 05:18 PM
hurd.28's Avatar
hurd.28
Question 07 Base Cp 6MT Tranny Question / Help
Hi All,
Just got my 07 Cpe (Base, Silver, 6MT). Love it so far but I have a question about the transmission. Car has about 650mi on it after 2 months and I have noticed that there is a spinning noise in the transmission (neutral and clutch out).
Also, the car does not always go into gear as you have to wrestle a little with it. Best described as 'notchy'. I had the dealer check it out and they said this is normal. For a 30k car I would expect it to have a smoother shift mechanism (My 77 280Z had a more solid feel than mine).
Is this normal break-in period kind of stuff or should I be concerned about something more sinister lurking around? Has anyone else experienced this?
Feedback appreciated.
Old May 29, 2007 | 06:21 PM
wldkatz03's Avatar
wldkatz03
it's notchy...you'll get use to it though...have fun with it!
Old May 29, 2007 | 10:59 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Welcome to the forum. Do you still have the 280? Haven't driven an 07 yet, so don't know what's normal for an 07. Each year has it's own quirks.
Old May 30, 2007 | 07:33 AM
rockinbboy's Avatar
rockinbboy
1st gear to 2nd gear is notchy for me..but the other gears are fine for me. Just push the clutch all the way in and shift slowly but surely...thats the best I can suggest.
Old May 30, 2007 | 07:54 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
The transmissions do make noise, that's normal. However, my shifter doesn't feel notchy at all, even when "cold" (it's AZ, so it really doesn't get that cold).
As soon as it's time for the first oil change, I'm also going to switch the tranny and diff fluid out too. Going to try MT90 first as I've had great results with it in other Nissan transmissions.
Old May 30, 2007 | 08:04 AM
Mansmind's Avatar
Mansmind
my 1-2 felt a little notchy at first, but it's smoothed up quite a bit after 8800 miles of driving.
The driveline noise is normal.
John
Old Jun 1, 2007 | 10:13 PM
illjim69's Avatar
illjim69
i noticed a little noise in neutral with the clutch out, but nothing abnormal. mine shifts fine, no "notchyness". then again, i've got about 130 miles on it, time will tell i guess.
jim
Old Jun 3, 2007 | 03:24 PM
I1DER's Avatar
I1DER
Congrats and welcome to the forum. I think your problem with the transmission is that you don't drive your car enough.
Old Jun 4, 2007 | 06:16 PM
OmGIsHSaK's Avatar
OmGIsHSaK
I just got my PPW 07 too. The clutch is notchy becuz its directly to the transmission????? Same thing to the G35 too. That's what I though and the noise is normal i hear mine all the time. sound like a charger......
Old Jun 4, 2007 | 06:22 PM
Zulu-6's Avatar
Zulu-6
You want notchy, drive a srt-4 with a short throw shifter. Going from that to the Z is a night and day difference.
Old Jun 4, 2007 | 06:47 PM
D_K's Avatar
D_K
yeah , I went from a 2nd gen Eclipse to a Z and it definetly felt a lot tougher to move the shifter , like it was heavier to move around but thats just the way its supposed to be, after a while you just get used to it.
Stevo Z
Oct 3, 2015 09:14 PM
350z82
Oct 1, 2015 06:25 PM
