Throttle issue
Old May 21, 2022 | 07:24 PM
BrendenZ1's Avatar
BrendenZ1
Default Throttle issue
Hey I just purchased a 2005 Nissan 350z as a project car and I have no throttle response. And the car is in limp mode I got it to my house and now I have absolutely 0 throttle response. I have checked the MAF, the throdle body is new and is in properly. And the ECU was replaced recently as well. If anyone can help or has any ideas. Let me know. If you have any questions please ask. Thank you.
Old May 23, 2022 | 01:21 PM
Ponyryd's Avatar
Ponyryd
Need to check docs, as well as the wiring and connectors to the throttle body from the accelerator pedal…sounds like someone tried to fix it and gave up.
Old May 24, 2022 | 02:47 AM
BrendenZ1's Avatar
BrendenZ1
The throttle body does open when I hit the gas. And the connection seemed strong. With that but I just have no power or response from it. Anything else I could try?
Old May 24, 2022 | 04:42 AM
travlee's Avatar
travlee
Master
you have a buddy that has a 350z? if so, try swapping TB's to eliminate that
Old May 24, 2022 | 04:46 AM
BrendenZ1's Avatar
BrendenZ1
Unfortunately I do not but that is a good idea I'll have to maybe find some sort of way to troubleshoot it tho. I was maybe thinking a vacuum leak as I heard a ight hissing noise every time I hit the gas
Old May 24, 2022 | 04:48 AM
travlee's Avatar
travlee
Master
you could always get one from rockauto, autozone etc.... test it, if it works then you have it, if not return it
Old May 24, 2022 | 04:50 AM
travlee's Avatar
travlee
Master
get some brake cleaner, with engine started spray around all vacuum lines you see, if the engine stumbles in an area.... more than likely a leak there
siyabiZ
Nov 28, 2019 03:25 AM
WestCoastRiot
Feb 2, 2011 06:44 PM
JAM3Z
Dec 17, 2009 06:00 AM
Vas@Extended
Nov 11, 2009 08:32 AM
runnun
Jun 22, 2008 01:01 PM
