Throttle Body Stuck Open!
Old May 3, 2008 | 12:28 PM
runnun's Avatar
runnun
Default Throttle Body Stuck Open!
ok so here's what happened...I replaced my stock NGK plugs for some pulstar plugs..realized my throttle body was dirty so I took some throttle body cleaner and sprayed it in there and wiped the top and bottom down..after a test drive..my idle was high -around 1300..I thought it would go down after the car was driven..so I scanned the car and got a misfire fault which later cleared..I now have a p0805 I think it is idle too high..I took the throttle body out and cleaned it and realized I could not adjust it..what can I do?
I made an apointment with nissan but I know their gunna dick me over...
the car is running like s*** rev it to 4 grand it will pause at 2 then back to a high idle at 1300 rpms..messing up my shifts too..gas milage is horrible 10-15 mpg...
PLEASE HELP
Old May 3, 2008 | 03:45 PM
Tac-M's Avatar
Tac-M
you need to do this
Idle Air Volume Learning (Throttle Position Learning)
http://www.technosquareinc.com/350reset.htm
Old May 3, 2008 | 05:20 PM
runnun's Avatar
runnun
thanks I'm gunna go try that now
Old May 3, 2008 | 07:20 PM
Hoooper's Avatar
Hoooper
youre probly f'ed if you moved the throttle plate. sometimes the relearn will work, sometimes an ECU reset works, but sometimes its a new throttle body that makes it work
Old May 3, 2008 | 07:31 PM
Tac-M's Avatar
Tac-M
^ oh, so smart... how alse would anyone clean the TB if not by moving the plate?
dud
Old May 3, 2008 | 07:57 PM
baspence's Avatar
baspence
dud
lol
Old May 4, 2008 | 10:14 AM
runnun's Avatar
runnun
yea I did all those steps for recalabration, but the MIL light stays on..I did it 5-6 times too..I'll try again today -maybe disconnect the battery and go through the steps then
Old May 4, 2008 | 11:43 AM
Hoooper's Avatar
Hoooper
dud
you obviously havent been a part of any of the high idle after cleaning the throttle body threads
Old May 4, 2008 | 11:44 AM
Hoooper's Avatar
Hoooper
try resetting the ecu, then if that doesnt work you may need to visit the dealer
Old May 4, 2008 | 01:42 PM
350ZTheStandard's Avatar
350ZTheStandard
Have you thought about driving really really fast all of the time???
Q45tech's Avatar
Q45tech
What happens when you move Throttle plate while battery is connected.
Old May 4, 2008 | 02:07 PM
Hoooper's Avatar
Hoooper
not really sure, but it usually ends in high idle. havent seen any threads about it on hr's, but the de some people get more lucky than others. the best is a simple idle air volume relearn, the worst is a new throttle body. it must have something to do with the drive by wire system getting messed up when manually moving the plate. also, some people have moved it without seeing any problems at all so it seems to be luck of the draw
Old May 4, 2008 | 02:54 PM
Tac-M's Avatar
Tac-M
after owning 2003 maxima ( vq35) , a 2005 z , a 2005 gc, and finlay 07 HR, i sure no nothing about nissans ( hitachi ) TB's...
edit : if there is no physical damage , read my 1st post.
Old May 4, 2008 | 03:13 PM
Tac-M's Avatar
Tac-M
it is not easy to get this right the first time... it is actualy quite difficult if you have to, use a stop watch...
Old May 4, 2008 | 03:20 PM
runnun's Avatar
runnun
yea I'm gunna go try again now ...see what happens
Old May 4, 2008 | 03:37 PM
Hoooper's Avatar
Hoooper
if you owned a 2003 maxima you should REALLY know this. i read this thread all the time on the maxima boards. here, read up http://forums.maxima.org/showthread....+idle+throttle
Edit: i just confirmed that the maxima throttle body and 03-08 350z throttle body are the same unit so ^^^^
Old May 4, 2008 | 03:46 PM
Tac-M's Avatar
Tac-M
^ if OP cannot fix the problem by doing the learning pros. , i will say that i am sorry to slam you.
i have removed and cleaned my tb's and had 0 problems. so make that 10 times ? on 5 different ( same tb ) cars. ( including my wife's FX )
don't forget, that 02 max was the firs DBW nissan... so just like a bunch of MAF problems ( i had some ) there could be a few tb problems.
edit : to your edit the 07-08 z can not be the same unit - go look at one
1 more edit: let the op reset the dang thing, before telling him that his tb is dead...
Old May 4, 2008 | 04:09 PM
Hoooper's Avatar
Hoooper
must be bad info from parts site, i figured as much. i told him to idle air relearn, reset ecu and then if nothing works the dealer has your answer.
PS: check what the CEL is for, may be the answer to your question
edit: tac-m, you should go buy a lottery ticket because if you really did clean it and move the throttle plate without running into problems then you are the luckiest person i know, and im being 100% serious
Old May 4, 2008 | 04:14 PM
Tac-M's Avatar
Tac-M
^ no i am not... i have been exactly where OP is right now , freaking out that my TB is f'd...
Old May 4, 2008 | 04:28 PM
Hoooper's Avatar
Hoooper
oh, lol. i was under the impression that you never had any strange result
