Rebuild and upgrade questions
Old Jul 14, 2023 | 10:55 AM
themeta47's Avatar
themeta47
Does anyone know the torque specs for these studs, cannot find anything online about them?
Old Jul 14, 2023 | 05:50 PM
i8acobra's Avatar
i8acobra
They don't have a spec as they're part of the assembly. Just bottom them out, the nut tightened to spec keeps them from backing out.
Old Jul 14, 2023 | 09:07 PM
bealljk's Avatar
bealljk
Just hand tight … you will torque the nut that goes on them.
Old Oct 18, 2023 | 01:32 PM
themeta47's Avatar
themeta47
Hey guys, quick question about crankcase ventilation and the hoses connecting to it. Nissan doesn't have any clamps listed on the circles hose and I was wondering if this was right? It doesn't seem so given that every other hose and pipe has a clamp of some sort holding it in place. Thanks
Old Nov 22, 2023 | 03:09 PM
themeta47's Avatar
themeta47
I got a question about my throw out bearing: how would y'all separate it from the sleeve that sits in it and what grease should I use in putting the new one on?
Thanks,
Meta
Old Nov 22, 2023 | 03:34 PM
Vitamin_B12's Avatar
Vitamin_B12
my '03 does not have clamps on that crossover hose
Old Nov 25, 2023 | 01:46 PM
themeta47's Avatar
themeta47
I was watching videos on how to replace this and saw them putting some sort of grease on the sleeve (just a thin coat). I was wondering if this stuff is what I should use and if adding that thin coat to the sleeve was ok?
Old Nov 25, 2023 | 08:39 PM
bealljk's Avatar
bealljk
Thats the style of grease I use - I dont overthink it…
Old Dec 20, 2023 | 12:14 PM
themeta47's Avatar
themeta47
Does anyone know of any reputable machine shops in the Colorado Springs area that would be willing to surface and clean parts? Mine unfortunately closed down within the last year.
Old Jan 14, 2024 | 03:35 PM
joelle king's Avatar
joelle king
Where can I find this product?
Old Jun 11, 2024 | 01:17 PM
themeta47's Avatar
themeta47
Default Gas smell coming from new lines
Hey guys, I recently redid my fuel lines and replaced them with -8an ones as well as a return kit and for some reason my lines smell like gas. I’ve checked for leaks and can’t find any nor do I see any gas residue anywhere on the lines/ where they connect after I prime the pump. The gas in the tank has been sitting for quite a while and I’m wondering if that’s the reason for the strong odor or if something is actually leaking?
Old Jun 11, 2024 | 08:54 PM
OldManZ350's Avatar
OldManZ350
YES YES YES it Matter........
In the service manual it shows you where each one goes.
Hey guys, I’m test fitting my cam caps with what the service manual says and had one question, does it matter where the different numbers are facing? And if so what is the order?
Old Jun 12, 2024 | 09:22 AM
themeta47's Avatar
themeta47
Don’t worry, I got this figured out a while ago lol, would you happen to know about the gas smell I previously posted about?
Old Jun 18, 2024 | 07:49 AM
bmccann101's Avatar
bmccann101
if you have played around w the fuel tank pump hat, the large o ring on the hat needs to be replaced , they soak, swell, and die quickly.. theyre supposed to be 1x use but age is really the biggest culprit.
has happened to every car i currently own.
Old Jun 18, 2024 | 01:41 PM
themeta47's Avatar
themeta47
Oh good to know, I did not think of that. I did replace it when I pulled my pump but it got soaked in gas when going back in. I’ll pull that and replace it asap
KleosTheGuy
Jan 10, 2019 10:30 PM
Draxx
May 31, 2015 11:47 PM
wbama387
Oct 14, 2011 07:15 AM
350Zwanabe
May 1, 2006 12:57 PM
Nowell
Nitrous Oxide
Jan 27, 2006 12:05 PM
