NISMO 350Z alignment specs?
Old Oct 31, 2007 | 07:55 AM
whitt1's Avatar
whitt1
Default NISMO 350Z alignment specs?
Are the alignment specs different on a NISMO Z? Mine looks lower than a normal Z and to have more negitive camber,are there any published specs?
Old Oct 31, 2007 | 08:32 AM
jmark's Avatar
jmark
It is lowered for sure. I would think a dealer or a factory service manual would have the proper specs. MC see if your contacts have them.
Old Oct 31, 2007 | 08:33 AM
cp79shark's Avatar
cp79shark
I hope so, need to get mined aligned sometime. Pulls a little to the left.
Old Oct 31, 2007 | 03:30 PM
Nizmo0395's Avatar
Nizmo0395
direct from manual vol#2. camber min neg 1.33 degrees max pos .17 degrees
l/r difference .75 degrees. caster min pos 7.42 max pos 8.92 degrees l/r difference .75 degrees. kingpin inclination min pos 4.33 degrees max pos 5.83
total toe in min 0 in. max .08 in.whitt1 drive my car back to jim keras nissan talk to larry in parts and order these manuals for about $350 you will get 4 vol.they are the same books the nissan mechanics use.i'm here in memphis if you want to talk send me a message.they got my black nizmo from jackson ms.look forward to talking to you,my go to memphis motor sports park for test and tune tomorrow.
Old Nov 3, 2007 | 08:11 AM
Nizmo0395's Avatar
Nizmo0395
my first spec. were for front wheel alignment here is the rear wheel alignment camber min neg. 2.08 deg. max neg 1.08 deg.total toe in min .043 in. max .106 in. all spec. are unladen which mean fuel,coolant and lubricants are full.spare jack hand tools floor mats are in designated places.
Old May 3, 2008 | 04:37 AM
NISMOFO's Avatar
NISMOFO
So it's definitely lowered, but no one knows how much it's lowered? What about the shock/spring rates vs. a Nismo S-Tune suspension...how does it differ? I'm getting an alignment soon myself, but I might want to put on a used Nismo Z suspension before spending the money on the alignment.
Old May 3, 2008 | 05:24 AM
whitt1's Avatar
whitt1
My original alignment settings were left front camber -.9 degrees,right front camber -1.7 degrees,front toe .27 degrees,rear left camber -1.9 degrees,rear right camber -1.7 degrees,rear toe -.3 degrees.The ride height is within 1/2" of stock,so it seems to have S tune springs,but they could be different.
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
hardkicks
Sep 20, 2015 12:28 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
