Service Engine Soon @ 860 miles???
Old Dec 22, 2008 | 02:52 PM
kennylin888's Avatar
kennylin888
Question Service Engine Soon @ 860 miles???
My "SERVICE ENGINE SOON" lighted up when I had only 860miles on my ODOMETER, is this NORMAL???
I thought that this light will normally come up when is near to 3750miles for the first SERVICE & MAINTENANCE. Can anyone help me out here?
Thanks in advance!!!
Old Dec 22, 2008 | 07:38 PM
NISMO133's Avatar
NISMO133
get the code checked to see what it is
Old Dec 22, 2008 | 07:52 PM
kennylin888
Nismo133, thanks for your reply. Main problem now is that NISSAN Paraguay won't take care of any vehicles that are not imported by them.... this really SUCKSSSS!!! Is there any other way to check the code or anything I can do about it?
Well, the truth is that this light came up after I started the engine without connecting both of the AIR SENSOR on the pipes. I also noticed the TSC/SLIP light came up as well, so I STOP the engine immediately. After this, I found out the driver's sensor was not connected so I did connect it immediately. Following this, the SERVICE ENGINE SOON light come up...
Could it possible be that when I started the engine without connecting the AIR SENSOR correctly and caused some malfunction there or anything like that? Maybe some dirt got into and causing this problem now???
Attached Thumbnails Service Engine Soon @ 860 miles???-air-intake-sensor.jpg   Service Engine Soon @ 860 miles???-service-engine-soon.jpg
Old Dec 22, 2008 | 09:06 PM
Kupalo's Avatar
Kupalo
Ya how do you check the code to see what problem it is?
Old Dec 22, 2008 | 10:06 PM
pacfwu's Avatar
pacfwu
Most likely caused by starting the car without the sensors plugged in correctly. Use the Technosquare ECU reset procedure and don't worry about it unless the light comes on again. If it comes on again, get an OBDII scan tool to find out what code it's thrown and then post up again.
Old Dec 23, 2008 | 02:24 PM
JML2007Nismo's Avatar
JML2007Nismo
You might consider disconnecting the battery for a few minutes. I hope that helps.
John
Old Dec 23, 2008 | 05:43 PM
kennylin888
Thanks PACFWU, I followed the TECHNOSQUARE ECU reset procedure today but maybe not within the specify time, therefore without any luck!!! I will try to disconnect the battery tonight and see what happens tomorrow.
kennylin888
John
Thanks John, I will try to do it now!!!
Old Dec 23, 2008 | 05:56 PM
AroundMyHorn's Avatar
AroundMyHorn
It's a Nissan corporate message. Since you've taken the car over 150 mph your car will now lose it's warranty.
Old Dec 23, 2008 | 06:08 PM
cdoxp800's Avatar
cdoxp800
Best of luck
Old Dec 23, 2008 | 08:01 PM
jerseystyle's Avatar
jerseystyle
Old Dec 24, 2008 | 04:10 AM
kennylin888
Just for your reference kiddo, unfortunately my NISMO don't have any warranty since the day it left FLORIDA...therefore your reply doesn't have anything to do with this THREAD. And FYI the light came up before I went over 150mph you FAILLLL~~~
Old Dec 24, 2008 | 04:11 AM
kennylin888
John
You are the MANNNNNN!!!!!! Problem solved~~~ Thank you so much my friend. Wish you and all your family a MERRY X-mas and Happy New Year!!!
Old Dec 24, 2008 | 04:12 AM
kennylin888
Originally Posted by cdoxp800
Best of luck
Thanks CDOXP800, problem solved!!! Best wishes for you and your family.
Old Dec 24, 2008 | 11:06 AM
JML2007Nismo
I am so glad that worked for you, because that was my first, last and only guess! Merry Christmas back at you.
John
Old Dec 24, 2008 | 12:19 PM
Tac-M's Avatar
Tac-M
learn this , print this, post this on the wall, have it in the car, dream about this !!!
http://www.technosquareinc.com/350reset.htm
Old Dec 24, 2008 | 12:35 PM
kennylin888
YES SIR!!! WILL DO!!!
By the way, in the previous posts PACFWU already suggested me doing this.
"Most likely caused by starting the car without the sensors plugged in correctly. Use the Technosquare ECU reset procedure and don't worry about it unless the light comes on again. If it comes on again, get an OBDII scan tool to find out what code it's thrown and then post up again.
__________________
"FACTORY" //Silver Alloy Nismo #549"
But still, really appreciate for your time dropping by and giving me some constructive reply to my inquiry. Now, problem solved by disconnecting and connecting back the battery after few mins.
Thanks TAC-M, wish you & ur family a very MERRY X-mas & GREAT NEW YEAR!!!
Tac-M's Avatar
Tac-M
oh, and you just lost power, thanks to that HOT AIR INTAKE !!!
and MERRY X-mass to you as well ! and a SUPER FUN and HAPPY NEW YEAR !!!!
don't get mad at my comment's, i only speak the truth....
STOCK or new INJEN – the one that sits in the bumper are good. The rest - NOT GOOD !
Old Dec 24, 2008 | 12:43 PM
bbs350z's Avatar
bbs350z
what about my family?
Old Dec 24, 2008 | 12:48 PM
kennylin888
Nice Ride u got BBS350Z.
Best wishes to you, ur nice gal and all ur family members. Merry X-mas pal!!!
Fixxxercask
Nov 9, 2015 11:10 AM
