KingBaby's Nissan Nismo #0191 'Lin'da'
Old Jan 10, 2013 | 03:30 PM
  #661
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by tkuntz
Congrats on the kiddie!
Extent of bolt ons meaning intake and exhaust? or the coolers you just picked up?
By capping off the vacume lines does that hinder the idle? what other lines did you move/cap?
Are you putting your engine cover back on to?
Thanks man...
Yes full intake/exhaust, but more specifically LTH because it's more free flowing...I'm not that tech savvy, but I'm guessing the stock injectors can't keep up
A/G. Separated the (+) terminal wire and move one to a metal bracket closet to it and removed the plastic clamps on it. G part of it was moving the wire to rear of the engine bay to circle around rather than pass over.
B. Moved these ground wires to the passenger side of the block, and underneath the fuel rails.
C. Deleted this connecting breather hose, and capped both ends.
D. Deleted this cylinder breather hose and capped both ends
E. Moved this cable to route on the inside of the block through the valley, and out below the front coolant hose.
Engine cover isn't going back on...
I said I was done but that's for now...once I get into my garage...I'm going in on a bigger level. It idles fine, but it does dip to a stall state often. I'm sure a retune will fix that
Old Jan 10, 2013 | 06:33 PM
  #662
Sickboy101's Avatar
Sickboy101
A big congrats on the birth of your baby girl!
Old Jan 10, 2013 | 08:46 PM
  #663
tkuntz's Avatar
tkuntz
hmm very intersting, yea im not "tech savvy" either but im sure it might help out but thats coming from someone who know's dick all about that kind of stuff.
how come your leaving the cover off? plans of a custom made one?
Old Jan 11, 2013 | 08:19 AM
  #664
KingBaby's Avatar
KingBaby
Hardest Setting
Leaving it off for weight reduction
I like the naked look...
Old Jan 11, 2013 | 09:35 AM
  #665
tkuntz's Avatar
tkuntz
haha interesting perspective, maybe you should fab up a nice burt titanium cover :P just an idea haha.
Old Jan 11, 2013 | 12:06 PM
  #666
Nismo350z#0310's Avatar
Nismo350z#0310
Meh. I say shinny look for only 1 lb!
Old Jan 19, 2013 | 01:14 AM
  #667
KingBaby's Avatar
KingBaby
Hardest Setting
I called a couple shops and got quotes on cutting the titanium!
Been a busy week!
Moving 2 Uhaul 17' trucks full of home by myself has left me sleeping for the pass 2 days!
Tomorrow though my "startover" process begins!
No more "ifs"
Old Jan 22, 2013 | 12:59 AM
  #668
KingBaby's Avatar
KingBaby
Hardest Setting
Seems I'm always posting broke ****...
Old Jan 22, 2013 | 01:32 AM
  #669
freddys 350z's Avatar
freddys 350z
what broke?
Old Jan 22, 2013 | 04:50 AM
  #670
Nismo350z#0310
How's that Stillen front brace fit? Looks sweet, I'd like to get it to brighten up the engine bay.
Old Jan 22, 2013 | 10:08 PM
  #671
KingBaby's Avatar
KingBaby
Hardest Setting
Default Stillen front tension radiator brace
Originally Posted by freddys 350z
what broke?
Well....looks broke all the time...lol
It fits like a$$...it's a circus act to get it to fit! I been meaning to write Stillen on it's horrible craftsmenship!
Got a lot done today...
Old Jan 23, 2013 | 03:37 AM
  #672
e30cabrio's Avatar
e30cabrio
Congrats on the house!
Old Jan 23, 2013 | 04:15 AM
  #673
Nismo350z#0310
lol!
Old Jan 23, 2013 | 02:38 PM
  #674
e30cabrio's Avatar
e30cabrio
Don't hold back. Tell us how you feel.
lol
Old Jan 24, 2013 | 12:04 AM
  #675
KingBaby's Avatar
KingBaby
Hardest Setting
Default Stillen 18 row Oil Cooler (Setrab)
It's Navy housing...3br 2.5ba full size garage ... Temporary bling one day I'll be a home owner.
lol!
lol I'm finding out the hard way as usual that their products are not what most would think!
lol
Now on to the Stillen oil cooler! As noted it doesn't fit a 350z with a long tube intake. Ok...nor does it fit a Nismo model 350Z. Ok ....I'm fine with all that, with a little outside the box thinking it would easily fit if the bracket was tilted forward a few degrees to form a 120 degree angle instead of a 90 degree. So the cooler would be leaning forward a little to clear the Nismo damper.
Yet the bracket Stillen made/mocked up is heavy than the cooler itself? Why Stillen? Why?
The bracket is so flipping heavy I ditched it and made templates for aluminum bracket I plan to make!
Installed stop tech rear rotors/pads/lines
Tried to remove the under brace for the spl compression bushing = failed
Prepped everything for relocating the battery
Then cut up a sticker and rearranged it in memory of a friend passed...
Old Jan 24, 2013 | 02:46 AM
  #676
KushZEN's Avatar
KushZEN
hahaha and a year ago we found out how to make it work . I don't think it was made for HR's though, maybe that's why?
Old Jan 25, 2013 | 09:17 PM
  #677
KingBaby's Avatar
KingBaby
Hardest Setting
Yea, but they advertise it as it would fit, which it does just tight!
Removed all the body panels and bumpers for basic cleaning of nooks and crannies. Must say for those who live in wet areas check those side skirts!
Still can't get the under brace to break loose...since I broke that intake runne bolt I'm horrified I break something else
deleted the throttle body coolant lines...plan on removing the evap lines as well...just wanna read more on it!
Old Jan 26, 2013 | 11:07 AM
  #678
ttknf's Avatar
ttknf
Thanks again guys!
The ricer in me...will run this all the time just to get pulled over and asked "what it mean"...lol
Me: Well...officer back in Japan I'm known for my fancy moves on the mountain
While I get a fancy ticket ...lmao
Picking up my stillen oil cooler tomorrow...
The plate is funny. It says "Nagano" at the top, but then "gunma" in English. Two totally different parts of Japan.
Old Jan 26, 2013 | 11:31 AM
  #679
KingBaby's Avatar
KingBaby
Hardest Setting
ah...my wife says it say "Long" "Wild" in Chinese....
I figure it would be completely off, just like folks who put Chinese/Japanese on their body only to say simple words in English!
You wouldn't believe the plate my wife has on her car...
Old Jan 26, 2013 | 06:21 PM
  #680
mdd's Avatar
mdd
not a huge fan of stillen. their customer service is a hit or miss.
