KingBaby's Nissan Nismo #0191 'Lin'da'
Old Oct 5, 2013 | 07:01 PM
  #841
e30cabrio's Avatar
e30cabrio
Cool!
Old Oct 5, 2013 | 09:46 PM
  #842
SR71's Avatar
SR71
Lead Super Moderator
Correct me if Im wrong but aren't the vent flaps supposed to be cut the the other way so air can escape out? they wont work and a scoop since that's a low pressure area. Cut back like this \\\ not intake style like you posted, or are you still cutting?
Old Oct 5, 2013 | 11:04 PM
  #843
KingBaby's Avatar
KingBaby
Hardest Setting
Correct...
I'm no aero expert regardless of what type air going in high/low pressure. Air will be going in? My train of thought behind this is that is should keep the heat soak down by keeping hot air moving and not soaking in the engine bay? I'm still cutting and want to do a large vent towards the rear right before the firewall similar to the BMW's
No point to this beside me wanting to see it done on an HR hood...
Old Oct 5, 2013 | 11:22 PM
  #844
SR71's Avatar
SR71
Yeah see how the front vents are cut on that BMW hood, that way it pulls air out of the bay through the hood, air that comes in from the front area of the car exits up and out with the draft of the car. Im no aero expert either lol, just trying to put it all together and wondering if there is an advantage to your style. We need some of the road racers up in hurrr, 03threefiftyz, terrasmak, scotts300, care to chime in put your knowledge to work?
Old Oct 10, 2013 | 01:36 PM
  #845
boliviandaddy23's Avatar
boliviandaddy23
side view = BOSS...front view = bacon strips....maybe try to flatten em out and weld a metal bar along each cut to have support and not look like bacon strips? but regardless looks like it will turn out great...you sir have ***** lol
Originally Posted by KingBaby
....may just be painting the car all satin/flat black because of the constant modding lol
Old Oct 10, 2013 | 02:11 PM
  #846
KingBaby's Avatar
KingBaby
Hardest Setting
Yea another reason I didn't cut the vent out completely was the strip in between got really weak hence the bacon strips will be massaging them to curve one way
Thanks...if anything we'll replace it
Old Oct 10, 2013 | 06:47 PM
  #847
saywat?'s Avatar
saywat?
lol damn man. I guess this is wat happens when u run out of things to do to the car?
Old Oct 10, 2013 | 08:01 PM
  #848
KingBaby's Avatar
KingBaby
Hardest Setting
Sadly and car fund fails to family/kids/home/wife
Old Oct 10, 2013 | 08:05 PM
  #849
saywat?'s Avatar
saywat?
Maybe better to jus leave car alone rather than devaluing it imo. Jus leave her alone man lol.. she's good already
Old Oct 12, 2013 | 09:05 PM
  #850
KingBaby's Avatar
KingBaby
Hardest Setting
Paint required
Old Oct 20, 2013 | 01:43 AM
  #851
KingBaby's Avatar
KingBaby
Hardest Setting
So this weekend out sucked with the car...randomly went into limp mode several times...a friends 08 had horrible hesitation no matter what gear...
Read/heard there was a TSB for the ECUs?
Inputs ?
Anyways finished up the hood
lessons learned from this is (1) I should have moved it to the edge of the hump...I slighty cut into it. Aesthetically it would of look ten times better. (2) bending the flaps would be easier if I cuted/trimmed guide on the backside of the hood with a dremel. Would of helped bend the flap easier than using force. Other than that having the proper tools made it really easy to do this.
Next is similair style on the fenders like the GTR racecars..because I'm a ricer
Old Oct 20, 2013 | 12:19 PM
  #852
zswickliffe's Avatar
zswickliffe
That's okay, I recently found this out about myself when I went against everything inside me and went with the momentum single. I then realized I've been a closet ricer all along. Loud exhaust, backfires and flames - what more could you ask for?
Old Dec 3, 2013 | 05:57 PM
  #853
fataLblitz's Avatar
fataLblitz
Kingbaby, do you think the real flares would go up against the v3 rear bumper with no issues? Since I know the amuse rear bumper extends out quite a bit
Old Dec 4, 2013 | 09:16 AM
  #854
KingBaby's Avatar
KingBaby
Hardest Setting
Yes the real flares will mount no issue! Where are you getting just the real flares from?
Old Dec 5, 2013 | 11:03 AM
  #855
fataLblitz's Avatar
fataLblitz
Oh I was just wondering, since I have been observing how the v3 rear and amuse rear add on are pretty much identical, aside from the extension.
Old Dec 5, 2013 | 11:09 PM
  #856
KingBaby's Avatar
KingBaby
Hardest Setting
long time no update...to this wild ride I'm on with this car
So lately the car is back on the floor....no boost no supercharger no nothing...just me continuing to **** with my car...
finished painting the fenders
finished the wire tuck of the body harnesses
Now car doesn't start...rotates but doesn't turn over. Codes P2127 P2138 pop up...OK I read several threads and didn't want to end up running around in circles. Tested alot of other things to confirm they work before ordering a TPS. Hopefully it works...cause I will light this car on fire!
Couldn't let these slide pass me...snug fit for a 6'4" 220lbs but with the rails it's lower than my previous sparco so it's a better seat position.
So yea...still at it...
Old Dec 6, 2013 | 05:17 AM
  #857
Nismo350z#0310's Avatar
Nismo350z#0310
Looks bad ***!!!!
Old Dec 18, 2013 | 07:12 PM
  #858
KingBaby's Avatar
KingBaby
Hardest Setting
I am the biggest noob...
That's out the way...so if you keep up today with my troubles with this car you know that I've had electrical issues. Random stalls/lost of interior lights/trunk randomly popping/gas gauge randomly not working....
I blamed the BCM/IPDM from jump...car still worked so really didn't change them out...my fault....
Ordered bunch of shiet to fix it only to stall for the last time in traffic at a intersection.
Wanted to burn the car where it sat...
I'm over it....
just ripped the whole interior out, and ordered new body harness
also considering going all out with the car..as in removing some glass/ac/etc....
Old Dec 19, 2013 | 05:21 AM
  #859
Nismo350z#0310
racecar!! roll cage!
Old Dec 19, 2013 | 09:29 AM
  #860
saywat?'s Avatar
saywat?
damn man...
