TrustR888's Nismo # 1508 Build thread
Old Oct 7, 2014 | 11:36 PM
  #101
trustr888's Avatar
trustr888
Old Oct 8, 2014 | 01:03 AM
  #102
trustr888's Avatar
trustr888
Old Oct 8, 2014 | 07:17 PM
  #103
trustr888's Avatar
trustr888
Old Oct 18, 2014 | 11:27 PM
  #104
KingBaby's Avatar
KingBaby
Hardest Setting
Sounds great...can't wait to finally buy the exhaust...
Old Oct 19, 2014 | 08:22 PM
  #105
trustr888's Avatar
trustr888
Yup, definitely worth every penny! The plus side too is it turns gold and more blue the harder you run it.
Old Oct 29, 2014 | 10:48 PM
  #106
trustr888's Avatar
trustr888
Update: Clutch/Flywheel/Hydraulic setup is all well. No mechanical issues what so ever so that's a plus. The bad news is the rear caliper came off during driving so a new caliper and wheel is being ordered. Anyhow, on a positive note, Top Secret in Japan is making a new shift **** for me courtesy of BulletProof Automotive in LA.
Old Oct 30, 2014 | 04:01 PM
  #107
bmccann101's Avatar
bmccann101
you have THE strangest car problems of anyone ive met lol.
Old Oct 30, 2014 | 06:17 PM
  #108
trustr888's Avatar
trustr888
This wasn't the case unfortunately. The problem was the master tech forgot to tighten up those two bolts holding the caliper, which came loose during driving. All those magic problem gremlins are gone! This was just shear lack of attention to detail.
Old Nov 2, 2014 | 12:56 PM
  #109
trustr888's Avatar
trustr888
Old Nov 3, 2014 | 07:27 AM
  #110
67ZNISMO's Avatar
67ZNISMO
He does, doesn't he? lol
Forgot to tighten the bolts holding the caliper??? that's like saying he forgot to put lug nuts on the wheels!
Old Nov 3, 2014 | 07:40 AM
  #111
Nismo350z#0310's Avatar
Nismo350z#0310
firestone didnt tighten my lugs after an alignment a few years back. started going down the highway and heard horrible humming and vibration and scraping. So much disaster could have in-sued that day!
Old Nov 3, 2014 | 08:41 AM
  #112
terrasmak's Avatar
#1 reason I like to do all my own work. As an aircraft mechanic I don't make those mistakes
Old Nov 3, 2014 | 02:59 PM
  #113
trustr888's Avatar
trustr888
Yeah, pretty stupid if you ask me. He would be in alot of trouble if I ended up wrecking.
Old Nov 3, 2014 | 03:01 PM
  #114
trustr888's Avatar
trustr888
Exactly. To think you could trust a GTR Master Tech who has done multiple AMS pacakges, modifications on the R35, but yet forget the basics with the Z. Sad imho. Having the car sit in my garage for 2-3 weeks already is pissing me off. After this happened, my buddy was going to initially get him to install a set of cams, but not anymore.
Old Nov 3, 2014 | 03:17 PM
  #115
nextcore's Avatar
nextcore
So now I'm contemplating and have been contemplating on a new suspension setup along with a wheel/tire combo. For suspension, I've always told myself that the car would have to be streetable as well as having the ability to take it up to the canyons and on the track. Not really worried about the ride stiffness etc, but I want to be able to adjust. Wheels/Tires, I would like something in the 18 range for lightness, but wouldn't mind a 19 range wheel. Still not sure on offset.
If you don't know already, I drive pretty hard for the most part. I'm sure you can tell since my old potenza's were bald to the secondary rubber. Here's a list of parts for brainstorming.
Suspension:
-Bilstein Ennepetal
-KW CS
-KW V3
-HKS Hipermax IV GT
-Tein coilovers w/edfc module/sensors
Wheels/Tires: (not sure what offset and all those specifics)
-Advan RS-D (Black)
-Volk RE30 (Black, Hyper bronze)
-Volk TE37 (TTA, SL, Ultra)
-Yokohama Neova AD08R's (current setup)
-Toyo R888
Can't believe i missed this thread. Great progress and build so far. As for suspension.. I have KW v3 and its great for street and occasional track. But if you want maximum performance... I recommend the KW CS.. ive driven on these on multiple cars including a z.. it's worlds different to the V3 and in a good performing way.
As for the wheels selections, You really cant go wrong with any of the 3 types you mentioned, aside from the TE37 Ultra.. i believe they are only available in 20's (GTR specs go figure) A better alternative is the te37 RT.. i beleive they are available in the sizes you mentioned.
Keep up the good work man!
Old Nov 3, 2014 | 04:29 PM
  #116
trustr888's Avatar
trustr888
Thanks man! It's definitely a toss up in regards to suspension. If worse comes to worse, I will just get a set of swift spec r springs until I decided other wise. The wheels are the same deal. Hard to choose. We'll see when that part of the build comes along. It just sits here after my rear caliper came off driving.
Old Nov 4, 2014 | 07:26 AM
  #117
vex008's Avatar
vex008
In regards to the wheels I would say the Advan RSD (yes, bias opinion) with the Neova AD08Rs.
but also factoring, not as commonly seen, I have only seen a handful of Zs with them and think only one other Nismo, which he probably has changed his setup by now.
I am sure you are familiar with it, about 15th car down on first post
https://my350z.com/forum/nismo-350z/...om-wheels.html
Old Nov 4, 2014 | 09:56 AM
  #118
trustr888's Avatar
trustr888
I've seen it. It looks really good. What's weird is I ended up getting a set of AD08r's, which is on the car now. I'm not sure what size and offset yet, but I'm leaning towards 19's to fill in the wheel gap.
Old Nov 4, 2014 | 04:49 PM
  #119
trustr888's Avatar
trustr888
Old Nov 4, 2014 | 08:30 PM
  #120
KingBaby's Avatar
KingBaby
Hardest Setting
Nice
Did you have to put the top secret part on or did it come like that?
