New Nismo Owner learning stick question
What's up guys. I've had my car for about a week now and am getting better with shifting but still am having lots of issues getting into first gear (a roll) smoothly. I feel as if I am lugging the engine too by not giving it enough gas. I know what I am supposed to do... find the bite point release slowly as your giving it gas but it's almost as if I can't get my foot placement right to do it consistently. Tbh almost every time I get into a roll I feel the car "buck" because I'm either releasing the clutch too fast or not giving it enough gas (or sometimes both). I understand the Z has a high engagement point and the clutch is stiffer than other cars which makes learning a bit more tricky but if anybody has tips on seating position & foot placement/motion as you're releasing the clutch would be much appreciated! Almost as if once I'm at the bite point I cant bend my heel backwards anymore so I resort to either sliding my leg back or lifting my leg up and it's not getting good results. So grateful to drive a Nismo Z but it's embarrassing when you look like an idiot on the roads lol
Thanks guys
#1132
Thanks guys
#1132
Thanks guys
#1132
Thanks guys
#1132
1st, make sure your seating position allows you to fully depress the clutch pedal completely and still have a slight bend in your knee. I don't know exactly which clutch you're running but if you put your rpms between 15-1800 and release your clutch pedal smoothly at a moderate (neither super-fast nor slowly) pace you should launch without bucking or overheating the clutch.
Another thing that may help-
Muscle memory for your right hand- practice the sequence of depressing your clutch and going through all your gears (including Reverse) at least 25 times in your driveway/parking lot (engine off) so you're confident in your gear choice. You'll be fine and engine-braking into turns before you know it. Gl !
Its not embarrassing. Sounds like you are doing ok. You don't have to give too much gas as this engine is relatively large, you can just slip the clutch slow if flat surface, which you cannot do with something <1.8L. Takes about 5 months to be 100% confident (not scared at every hill start), keep it up!
Hi Ryan, I'm gonna set a good example and provide positive comments-
This Coronavirus has been horrible but having no traffic in bay area has been a godsend for me at this time
hell i have been driving manual cars most of my driving life (almost 30 years) and there are times that i feel like a noob driver. hell just the other day i stalled the vette backing up into a spot
Since your seat is now properly adjusted, here's another hint about the proper use of the dead pedal. Between shifts, your clutch foot should be resting on the dead pedal to the right of the clutch. Not leaving your left foot on the clutch reduces heat and extends clutch life.
Check out "How to Drive Manual Transmission" playlist from TheSmokingTire on YouTube. He has a view of himself and the pedals and goes through the basics, then touches on more advanced moves such as heal-toe.
Thanks for the responses guys, starting to get the hang of it but still looking for methods (foot-motion wise) to release the clutch a little slower at the end getting to a roll. I'm literally lifting my leg up after I'm past the bite point and it feels like its almost too much work. But if I extend my seat back any farther I feel like I have to stretch my leg too much to have clutch in probably w/o much of the slight bend in knee you mentioned. Getting the hang of downshifting mostly from 4th to 3rd, noticed the 2nd gear is hard to get smooth as I've read but when you hit it smooth it feels like money
TenTilFour
Jun 20, 2007 07:58 PM
