Thought I'd Say...
I've been getting alot better since I had wrote my "Having trouble with manual" thread. It is amazing how practicing everyday can make you so much better. I wanted to make this thread because I have already searched about the 1st to 2nd shift that I am still having trouble with getting down perfect, and I found a thread about that.
But my question to you guys is that I am having trouble when I shift, for example I will shift from say 2nd to 3rd. After shifting to third I then let off the clutch, as I feel the clutch get back to the engagement point I start to add gas. My problem is that it is hard to tell when I reach that engagement point, where I can add gas. What I end up doing is shifting then when letting the clutch out, I add gas, and since the Z's engagement point is a little high, I will add gas before the engagement point and i will rev up a few hundred rpms and then it will drop down.
Thanks for any help.
Old Escobar's right. Me? I'm 59, so I picked up an '04 Touring Coupe with an Auto tranny! After a certain age, you learn to s-i-m-p-l-i-f-y your existence.
Diff'rent strokes for diff'rent folks! Good luck on your MT practice!
not sure what advice you need...you already know what you are doing wrong. i guess you could release the clutch a little quicker or don't gas it so early. just practice not doing it. you'll get it eventually
Originally Posted by 350POWER
its kinda hard to drive the Z......after i drive my honda
i would be easier for me to explain quantum physics to you then explain how to drive a stick. i have driven both a manual z and my current auto z. i didn't find the manual z significantly different than other sticks, but i learned on a '69 vette (not mine and no way in hell, now that i know how to drive one, would i let someone "learn" that way again.)
